I wonder if anyone can help me decide variable to set if R2NO exists. If R2NO is blank, then use R1NO. Here is the code. Thanks.
;COND IF R2NO IS BLANK
(setq tags
("R2NO" . hyperlinkbase);REVA
;ELSE USE R1NO
(setq tags
("R1NO" . hyperlinkbase);REVA
(if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "REVBLOCKA")))); REPLACE TITLEBLOCK HERE!!!!
(mapcar
(function
(lambda ( attrib / prop )
(if (setq prop (cdr (assoc (strcase (vla-get-TagString attrib)) tags)))
(vlax-put-property sum prop (vla-get-TextString attrib))
(vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'GetAttributes)
