Yep, this'n is a winner. Like Mark said though, it would be nice to be able to add/edit the .mnu file from the proggy........ As is, if you already have 20+ toolbars in the file and want to add another, you need to re-select all of them. Other than that, sweeeet! This is handy if you want to take your toolbar setup with you or move to another station. Some companies don't allow modifying the layout....here we like to be a bit more flexible. Each station is purty much customized to the user, allowing him/her to use those tools that they are most comfortable with. Only drawback is, as I said, moving from one to the other. With this, that is not an issue any more.
