Author Topic: Need your help,Object Connect&Draw pline  (Read 11396 times)
xiaxiang
Re: Need your help,Object Connect&Draw pline
« Reply #30 on: April 05, 2011, 08:46:31 PM »
Serious Support !
H/V connections is easy to get , just help yourself .
OK,I will try it this afternoon.I hope that it is as simple as you say.
xiaxiang
« Reply #31 on: April 10, 2011, 09:39:59 PM »
Hi,chlh_jd
I failed once again,even though I've try my best.
So I post my sample dwg to clarify.
The red polyline is what I got from using your code ,and the yellow one is what I what.
Please,check it for me.
xia
chlh_jd
« Reply #32 on: April 11, 2011, 03:13:38 AM »
today have no time to do much . see the gif
xiaxiang
« Reply #33 on: April 11, 2011, 04:11:56 AM »
excellent! Nice solution!
Keep watching...
chlh_jd
« Reply #34 on: April 11, 2011, 01:26:42 PM »
here's A e.g.
;;; function : to union rectangulars with a given span range
;;; the span(dis) must be a number which can connect wanted rects  and don't connect rects you do not want .
;;; so it's just a way for example , to suit for all conds you must take the span [from ~ to] into recursion .
;;; by GSLS(SS) 2011-4-12
(defun c:test (/ dis ss ssobj doc ms os ob a b pda)
  (or dis
      (setq dis (getreal "\nPlease input joined max-distance<25>:"))
      (setq dis 25.)
  ) ;_here is just a way , it must be [from ~ to] to check is suit for .
  (setq ssobj (ss2lst (ssget '((0 . "LWPOLYLINE"))) T))
  (setq os (getvar "OSMODE"))
  (setvar "OSMODE" 0)
  (setq doc (vla-get-activedocument
      (vlax-get-acad-object)
ms  (vla-get-modelspace doc)
ob  nil
ss  (ssadd)
  (foreach a ssobj
    (setq b (ss-Offset a (- dis)))
    (if (not (vl-catch-all-error-p b))
(setq b (car
  (vlax-safearray->list
    (vlax-variant-value
      b
(vla-addregion
  ms
  (vlax-safearray-fill
    (vlax-make-safearray vlax-vbObject '(0 . 0))
    (list b)
(if (vlax-erased-p b)
  nil
  (vla-delete b)
(setq ss (ssadd (entlast) ss))
  (command "union" ss "")
  (command "explode" (entlast))
  (setq ss (ssget "p"))
  (vl-catch-all-apply
    (quote
      (lambda nil
(if (setq pda (getvar "peditaccept"))
    (setvar "peditaccept" 1)
    (command "_pedit" "m" ss "" "j" "j" "b" 1e-6 "")
    (setvar "peditaccept" pda)
  (command "_pedit" "m" ss "" "y" "j" "j" "b" 1e-6 "")
  (ss-Offset (setq b (vlax-ename->vla-object (entlast))) dis)
  (vla-delete b)
  (setvar "OSMODE" os)
(defun ss-Offset (obj d / b p ret)
    ((= "16" (substr (getvar "acadver") 1 2))
     (setq p (vlax-3D-point (vlax-curve-getstartpoint obj)))
     (vla-move obj p (vlax-3D-point (list 0 0 0)))
     (setq ret (VL-CATCH-ALL-APPLY (quote vla-Offset) (list obj d)))
     (vla-move obj (vlax-3D-point (list 0 0 0)) p)
     (if (not (vl-catch-all-error-p ret))
       (vla-move (car (vlax-safearray->list (vlax-variant-value ret)))
p
     ret
    (t
(defun ss2lst (ss vla / a e i)
  (setq i -1)
  (while (setq e (ssname ss (setq i (1+ i))))
    (if vla
      (setq e (vlax-ename->vla-object e))
    (setq a (cons e a))
chlh_jd
« Reply #35 on: April 11, 2011, 01:37:36 PM »
Keep watching...
It's your homework , not mines . so don't keep wathching ... get over by yourself until your 'Need your help' .    :|
xiaxiang
« Reply #36 on: April 11, 2011, 09:26:12 PM »
Keep watching...
OK.Try it by myself.
m4rdy
« Reply #37 on: April 12, 2011, 02:00:31 PM »
;; Original from Gile
;; modification from chlh_jd
(defun c:test1 (/ dist n ss ent lst pt p Minpt Maxpt pt1 ssad1 reg ss2 pda)
  (setq dist (getdist "\nMax distance :")
ssadd1 nil
reg nil
ss2 nil)
  (if (setq n  -1
    ;;ss (ssget '((0 . "POINT")));_==>> extracted from polylines
    ss (ssget '((0 . "LWPOLYLINE")))
    (while (setq ent (ssname ss (setq n (1+ n))))
      (setq lst (append (polycoords ent) lst))
  (setq ssad1 (ssadd))
  (while lst
    (setq pt  (car lst)
  lst (cdr lst)
    (foreach p lst
      (if (and (<= (distance pt p) dist)
       (/= (distance pt p) 0.00)
       (or (equal (MeCalcTheta pt p) 90.0)
   (equal (MeCalcTheta pt p) 0.0)
   (equal (MeCalcTheta pt p) 180.0)
   (equal (MeCalcTheta pt p) 270.0)
(entmake (list '(0 . "LINE") (cons 10 pt) (cons 11 p)))
(ssadd (entlast) ssad1))
  );_end while
  (vl-cmdf "region" ssad1 "")
  (princ "SELECT AGAIN ")
  (setq reg (ssget '((0 . "REGION"))));_==> i'm sure there's another better way
  (vl-cmdf "erase" ssad1 "")
  (vl-cmdf "union" reg "")
  (setq ss2 (ssget "p"))
  (vl-catch-all-apply
    (quote
      (lambda nil
    (command "_pedit" "m" ss2 "" "j" "j" "b" 1e-6 "")
  (command "_pedit" "m" ss2 "" "y" "j" "j" "b" 1e-6 "")
);_defun
;; Jurg menzi
(defun MeCalcTheta (Pt1 Pt2 / X__Abs Y__Abs X__Dif Y__Dif TheVal)
 (setq X__Dif (- (car Pt2) (car Pt1))
       Y__Dif (- (cadr Pt2) (cadr Pt1))
       X__Abs (abs X__Dif)
       Y__Abs (abs Y__Dif)
       TheVal (if (equal (+ X__Abs Y__Abs) 0.0 1E-8)
               0.0
               (/ Y__Dif (+ X__Abs Y__Abs))
 (if (< X__Dif 0)
  (setq TheVal (- 2.0 TheVal))
  (if (< Y__Dif 0) (setq TheVal (+ 4.0 TheVal)))
 (* 90.0 TheVal)
;; Get coordinate
;; using vlax-curve* functions.
;; Works with all curve polylines types (lw, 2d, 3d) returns WCS coordinates.
;; Gile
;; http://www.cadtutor.net/forum/showthread.php?51700-Vertices-of-a-Polyline
(defun polyCoords (pl / n l)
  (setq pl (vlax-ename->vla-object pl))
  (setq n (if (vlax-curve-IsClosed pl)
            (fix (vlax-curve-getEndParam pl))
            (1+ (fix (vlax-curve-getEndParam pl)))
  (while (/= 0 n)
    (setq l (cons (vlax-curve-getPointAtParam pl (setq n (1- n))) l))
i'm still learning (and lurking..  :-D) vlisp.
m4rdy
Autocad 2007, Windows XP
xiaxiang
« Reply #38 on: April 12, 2011, 11:29:49 PM »
m4rdy
Hi,m4rdy
It works. But surplus region has not been deleted.
BTW,I will show my code this afternoon.
m4rdy
« Reply #39 on: April 13, 2011, 01:22:42 AM »
Hi,m4rdy
In your case from post #31 it works fine.
Or do you have other dwg for test?
Let me know.
m4rdy
xiaxiang
« Reply #40 on: April 13, 2011, 02:31:53 AM »
Hi,m4rdy
The surplus region has not been deleted,as my animation that has been posted.
And how can I decide the max distance in your code?
I used "25" in my sample dwg from post #31 ,then it's OK.
If I used "50" ,the result is not the same.
xia
xiaxiang
« Reply #41 on: April 13, 2011, 02:39:50 AM »
So I post my code even it is ugly and Imperfect.
For the reason of proving I've done something for my homework.
Special Thanks to chlh_jd . :-)
m4rdy
« Reply #42 on: April 13, 2011, 07:22:11 AM »
I guess you've missed the second selection on "SELECT AGAIN"
It can be the largest between the distance of plines or length of pline segments.
or am i missing something here?
m4rdy
