Thanks Mark.
Tread run is also called "Going" and is the distance from face of riser to face of riser.
Riser height is left the same for all risers and is the rise plus the groove depth into the next tread, I set that to 10mm.
Bottom or first riser is left same height so that it can be scribed to the floor if retrofitted or screeded up to (which traps it into the floor) the same is usually done with string ends and newell posts.
'Nosing' is the treads projection from face of riser and is commonly bullnosed and most often the same as the tread thickness.
I am thinking of adding a text box with final dimensions for the stair all listed, rise, going,pitch etc.
Rob.
