Author Topic: Using VB.Net to Import/Insert a DXF File in Existing Drawing  (Read 28850 times)
Re: Using VB.Net to Import/Insert a DXF File in Existing Drawing
« Reply #30 on: March 17, 2011, 10:08:54 AM »
Database.DxfIn
I'm blind as well as stupid !!
Thanks Philippe at ADN.
        [CommandMethod("netInsertDxf")]
        static public void netInsertDxf()
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            Database TmpDb = new Database(false, true);
            TmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\\ToTest\\Squircle.log");
            Matrix3d Transform = Matrix3d.Identity;
            db.Insert(Transform, TmpDb, true);
and I just noticed that kaefer was using it in Post Reply #24
« Last Edit: March 17, 2011, 10:19:49 AM by Kerry »
Glenn R
« Reply #31 on: March 17, 2011, 12:14:08 PM »
...at my suggestion from post reply #14
« Reply #32 on: March 17, 2011, 02:49:58 PM »
Glenn,
At the time I read that as  “AcadDocument.Import” method on the DXF file into a side db. ... which I know does work.
« Last Edit: March 17, 2011, 03:02:27 PM by Kerry »
Glenn R
« Reply #33 on: March 17, 2011, 04:45:48 PM »
Apologies Kerry - I just re-read what I posted and it might have come across as a bit...terse - not my intention. Also, I wouldn't suggest the use of that...nasty COM stuff :evil:, unless absolutely necessary  :-D
« Reply #34 on: March 17, 2011, 05:07:15 PM »
No pain for me ... except that I completely missed the reference ... that's just embarrassing  :oops:
huiz
  • Certified Prof C3D
« Reply #35 on: March 22, 2011, 05:40:01 AM »
I have tried some things with importing dxf files but I cannot continue. There is not many information about this subject to find.
This is the code till now (thanks to Kerry):
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class clsImportDXF
  <CommandMethod("InsertDxf")> _
  Public Sub InsertDxf()
    Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
    Dim db As Database = doc.Database
    Dim ed As Editor = doc.Editor
    Dim TmpDb As Database = New Database(False, True)
    TmpDb.DxfIn("G:\\test.dxf", "G:\\test.log")
    Dim pnt1 As New Point3d(0, 0, 0)
    Dim pnt2 As New Point3d(1000, 1000, 0)
    Dim Transform As Matrix3d = Matrix3d.Displacement(pnt1.GetVectorTo(pnt2))
    db.Insert(Transform, TmpDb, True)
End Class
This code does insert a dxf and moves it to a new location. But I also want to scale all entities. How can I add a scale in this code? Can I extend Transform with a Scale?
Further I want to select all entities from the dxf and place them on another layer. How do I select all entities?
huiz
« Reply #36 on: March 22, 2011, 05:58:03 AM »
If I combine Matrix3D options, then they are ignored:
    Dim scale As Double = 10
    Dim Transform As New Matrix3d
    Transform = Matrix3d.Scaling(scale, pnt1)
    Transform = Matrix3d.Displacement(pnt1.GetVectorTo(pnt2))
End Class
« Reply #37 on: March 22, 2011, 06:26:00 AM »
I think you will need to Multiply the matrix's together ...
WAG
                Transform = Matrix3d.Scaling(scale, pnt1) * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2))
added :
This works in C# anyway :)
            Transform = Transform * Matrix3d.Scaling(5.0, Point3d.Origin);
« Last Edit: March 22, 2011, 06:35:56 AM by Kerry »
huiz
« Reply #38 on: March 22, 2011, 06:39:48 AM »
Cool! I didn't know that this was possible :-) How is this method called?
I have now:
    Transform = Matrix3d.Scaling(scale, pnt2) * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2))
I had to use the displacement point as scale location (pnt2) instead of the origin.
Btw, how do I get all placed entities so I can change the objects layer? Or should I iterate all objects in the TmpDB first?
kaefer
« Reply #39 on: March 22, 2011, 06:53:51 AM »
You could read further upthread:
ObjectAppended event approach http://www.theswamp.org/index.php?topic=37409.msg424558#msg424558
EntLast()/EntNext() approach http://www.theswamp.org/index.php?topic=37409.msg424652#msg424652
WblockCloneObjects approach http://www.theswamp.org/index.php?topic=37409.msg424709#msg424709
Have fun
huiz
« Reply #40 on: March 22, 2011, 07:34:25 AM »
Have fun
Thanks! How did I overlook this... :-)
huiz
« Reply #41 on: March 27, 2011, 06:35:00 AM »
Uhmm, weird... I have the following code:
Imports AcUtils = Autodesk.AutoCAD.Internal.Utils
    TmpDb.DxfIn("G:\\test.dxf", IO.Path.GetTempFileName)
    Dim vector As New Vector3d(0, 0, 0)
' Change object color -----------------------------
    Dim lastEnt As ObjectId = AcUtils.EntLast()
    Dim idColl As New ObjectIdCollection()
    Using tr As Transaction = doc.TransactionManager.StartTransaction()
      If lastEnt = ObjectId.Null Then
        lastEnt = AcUtils.EntFirst()
        idColl.Add(lastEnt)
      End If
      Dim nextent As ObjectId = AcUtils.EntNext(lastEnt)
      While nextent <> ObjectId.Null
        idColl.Add(nextent)
        nextent = AcUtils.EntNext(nextent)
      End While
      For Each id As ObjectId In idColl
        Dim acEntity As Entity = TryCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
        acEntity.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 1)
      Next
      tr.Commit()
    End Using
After inserting the dxf I try to change the color of the objects. While debugging it loops through all the inserted elements but it does not change the color. I get this error while debugging:
"Cannot evaluate expression because we are stopped in a place where garbage collection is impossible, possibly because the code of the current method may be optimized."
kaefer
« Reply #42 on: March 27, 2011, 09:39:41 AM »
Can't help you there, but aren't you supposed to to get the last entity before the insert operation? That is, switch the order of the two statements quoted.
Another optimization may be using the ColorIndex method...
huiz
« Reply #43 on: March 27, 2011, 02:15:42 PM »
I assume the last entity is what I'v just inserted. While debugging it loops through all the inserted objects but I can't change color or layer or any other property. So getting the inserted items as last entity is correct, but why can't I access them?
« Reply #44 on: March 27, 2011, 03:47:50 PM »
Hey Huiz, I tested your code real quik and here is what I noticed
Using a new drawing(empty drawing)
This would get the last entity added from 'DxfInsert' called
Then this would make it null
so this is never called
To get it to work
Using a new drawing(empty drawing) and removing the if statement
                    idColl.Add(lastEnt)
                End If
changed to
                idColl.Add(lastEnt)
Now lastEnt  is the ObjectId of the first entity added from calling 'DxfInset' of course with a empty drawing
