Author Topic: Using VB.Net to Import/Insert a DXF File in Existing Drawing  (Read 30974 times)
Jeff H
Re: Using VB.Net to Import/Insert a DXF File in Existing Drawing
« Reply #45 on: March 27, 2011, 03:57:22 PM »
Or better yet to work on empty and non-empty drawings
Leave the if statement  and move
       Dim lastEnt As ObjectId = AcUtils.EntLast()
up to the top of your code
Jeff H
« Reply #46 on: March 27, 2011, 04:50:49 PM »
I was also making a assumption in last post about EntFirst()
I am not fimilar with Lisp and do not know if EntFirst() acts just like Lisp version, but
does EntFirst() get first entity added to Database in the current Session?
huiz
  • Certified Prof C3D
« Reply #47 on: March 28, 2011, 03:08:55 AM »
I think so because while debugging it loops through all the new inserted objects.
Thanks Jeff for your answers, I'll have a test this evening when I'm home.
« Reply #48 on: March 28, 2011, 05:04:22 AM »
A couple of options to play with ...
"InsDXF7"  Collect the  imported entitys then itterate the collection to change Color
"InsDXF8"  Change Color While iterating the imported entitys .. no collection
"InsDXF9"  Change Color in the temporary Side DataBase
        [CommandMethod("InsDXF7")]
        public void InsDXF7()
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            Database tmpDb = new Database(false, true);
            tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\\ToTest\\Squircle.log");
            Point3d pnt1 = new Point3d(0, 0, 0);
            Point3d pnt2 = new Point3d(1000, 1000, 0);
            double scale = 10.0;
            Vector3d vector = new Vector3d(0, 0, 0);
            Matrix3d transform = Matrix3d.Scaling(scale, pnt2) * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2));
            ObjectId lastEnt = AcUtils.EntLast();
            Autodesk.AutoCAD.Colors.Color newColor = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 1);
            db.Insert(transform, tmpDb, true);
            using( Transaction tr = doc.TransactionManager.StartTransaction() ) {
                // if the db was empty lastent will be null
                try {
                    if( lastEnt == ObjectId.Null ) {
                        lastEnt = AcUtils.EntFirst();
                        idColl.Add(lastEnt);
                    ObjectId nextent = AcUtils.EntNext(lastEnt);
                    while( nextent != ObjectId.Null ) {
                        idColl.Add(nextent);
                        nextent = AcUtils.EntNext(nextent);
                    foreach( ObjectId id in idColl ) {
                        Entity acEntity = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                        acEntity.Color = newColor;
                } catch( Autodesk.AutoCAD.Runtime.Exception exx ) {
                    ed.WriteMessage("\n" + exx.ToString());
                tr.Commit();
        [CommandMethod("InsDXF8")]
        public void InsDXF8()
            ObjectIdCollection idColl = new ObjectIdCollection();
            Entity acEntity;
                try {
                        acEntity = (Entity)tr.GetObject(lastEnt, OpenMode.ForWrite);
                        acEntity = (Entity)tr.GetObject(nextent, OpenMode.ForWrite);
                tr.Commit();
        [CommandMethod("InsDXF9")]
        public void InsDXF9()
            Entity acEntity;
            using( Transaction tr = tmpDb.TransactionManager.StartTransaction() ) {
                try {
                    BlockTable tmpDbBlockTable = (BlockTable)
                     tr.GetObject(tmpDb.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord tmpDbModelSpace = (BlockTableRecord)
                            tr.GetObject(tmpDbBlockTable[ BlockTableRecord.ModelSpace ], OpenMode.ForWrite);
                    foreach( ObjectId id in tmpDbModelSpace ) {
                    tr.Commit();
« Last Edit: March 28, 2011, 05:12:39 AM by Kerry »
huiz
« Reply #49 on: March 28, 2011, 02:32:32 PM »
Thanks Kerry for your code!  :-)  I've tried all three and I only have success if I change the objects in the temporary database, before inserting in the current drawing. I'm not sure what is wrong with the other examples, I've read the instructions of Jeff but the code does not do anything. I don't get errors, there are no exceptions, and while debugging it seems the objects are there, but not available.
But the last example does work very well and the options are endless now to alter the objects before inserting! Thanks!!!  :-)
« Reply #50 on: March 28, 2011, 03:07:47 PM »
huiz,
I probably don't need to say this, but .. the 3 examples work for me in c# from vs2010Pro into AC2011.
I'd guess that your translation may be skewey.
Can you post the VB.net code you used for each or post he solution zipped so I can test it here.
huiz
« Reply #51 on: March 29, 2011, 02:29:24 AM »
I thought they did work in C# but unfortunately not in vb. Here are the examples in vb:
<CommandMethod("InsDXF7")> _
Public Sub InsDXF7()
Dim doc As Document = AcadApp.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim db As Database = doc.Database
Dim tmpDb As New Database(False, True)
tmpDb.DxfIn("K:\ToTest\Squircle.dxf", "K:\ToTest\Squircle.log")
Dim pnt1 As New Point3d(0, 0, 0)
Dim pnt2 As New Point3d(1000, 1000, 0)
Dim scale As Double = 10.0
Dim vector As New Vector3d(0, 0, 0)
Dim transform As Matrix3d = Matrix3d.Scaling(scale, pnt2) * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2))
Dim newColor As Autodesk.AutoCAD.Colors.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 1)
db.Insert(transform, tmpDb, True)
Using tr As Transaction = doc.TransactionManager.StartTransaction()
' if the db was empty lastent will be null
Try
If lastEnt = ObjectId.Null Then
idColl.Add(lastEnt)
End If
Dim nextent As ObjectId = AcUtils.EntNext(lastEnt)
While nextent <> ObjectId.Null
idColl.Add(nextent)
End While
For Each id As ObjectId In idColl
Dim acEntity As Entity = DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
Next
Catch exx As Autodesk.AutoCAD.Runtime.Exception
ed.WriteMessage(vbLf & exx.ToString())
End Try
tr.Commit()
End Using
End Sub
<CommandMethod("InsDXF8")> _
Public Sub InsDXF8()
Dim idColl As New ObjectIdCollection()
Try
acEntity = DirectCast(tr.GetObject(lastEnt, OpenMode.ForWrite), Entity)
End If
acEntity = DirectCast(tr.GetObject(nextent, OpenMode.ForWrite), Entity)
End While
End Try
tr.Commit()
End Using
End Sub
<CommandMethod("InsDXF9")> _
Public Sub InsDXF9()
Using tr As Transaction = tmpDb.TransactionManager.StartTransaction()
Try
Dim tmpDbBlockTable As BlockTable = DirectCast(tr.GetObject(tmpDb.BlockTableId, OpenMode.ForRead), BlockTable)
Dim tmpDbModelSpace As BlockTableRecord = DirectCast(tr.GetObject(tmpDbBlockTable(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
For Each id As ObjectId In tmpDbModelSpace
acEntity = DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
Next
tr.Commit()
End Try
End Using
End Sub
« Reply #52 on: March 29, 2011, 03:35:49 AM »
Give these a run ...
(Code solution .ZIP attached)
Option Explicit On
Option Strict On
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Colors
Imports Utils = Autodesk.AutoCAD.Internal.Utils
<Assembly: CommandClass(GetType(InsertDXF.MyCommands))>
Namespace InsertDXF
    Public Class MyCommands
   '' < snip >
    End Class
End Namespace
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\ToTest\\Squircle.log")
            Dim transform As Matrix3d = (Matrix3d.Scaling(scale, pnt2) _
                                         * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2)))
            Dim lastEnt As ObjectId = Utils.EntLast
            Dim newColor As Color = Color.FromColorIndex(ColorMethod.ByAci, 1)
                Try
                    If (lastEnt = ObjectId.Null) Then
                        lastEnt = Utils.EntFirst
                        idColl.Add(lastEnt)
                    End If
                    Dim nextent As ObjectId = Utils.EntNext(lastEnt)
                    Do While (nextent <> ObjectId.Null)
                        idColl.Add(nextent)
                        nextent = Utils.EntNext(nextent)
                    Loop
                    Dim id As ObjectId
                    For Each id In idColl
                        Dim acEntity As Entity = DirectCast(tr.GetObject( _
                    Next
                    ed.WriteMessage((ChrW(10) & exx.ToString))
                End Try
                tr.Commit()
            End Using
        End Sub
                Try
                        acEntity = DirectCast(tr.GetObject( _
                    End If
                    Loop
                End Try
                tr.Commit()
            End Using
        End Sub
            tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\\ToTest\Squircle.log")
            Dim tr As Transaction = tmpDb.TransactionManager.StartTransaction
            Try
                Dim tmpDbBlockTable As BlockTable = DirectCast(tr.GetObject( _
                Dim tmpDbModelSpace As BlockTableRecord = DirectCast(tr.GetObject( _
                        tmpDbBlockTable.Item(BlockTableRecord.ModelSpace), _
                Dim id As ObjectId
                For Each id In tmpDbModelSpace
                Next
                tr.Commit()
            Finally
                If (Not tr Is Nothing) Then
                    tr.Dispose()
                End If
            End Try
        End Sub
« Last Edit: March 29, 2011, 03:51:28 AM by Kerry »
kaefer
« Reply #53 on: March 29, 2011, 04:18:43 AM »
Option Explicit On
Option Strict On
Does the culprit sit right here?
Cheers, Thorsten (missing bargepole, won't do VB)
« Reply #54 on: March 29, 2011, 04:23:53 AM »
Option Explicit On
Option Strict On
Don't know Thorsten, but it didn't seen correct to me to code with them off .... but that's probably just me :)
I've decided I need to at least be able to read VB and write a little ... as much as I hate the Dim word  :-P
huiz
« Reply #55 on: March 29, 2011, 02:53:37 PM »
All three procedures do work now Kerry. I'll have a closer look what made the difference, as curious as I am. Btw, I've checked the time they need and changing the objects in the temp database is much faster. About half of the time the others need. So I stick with the last piece of code :-)
Btw, I am able to read C# but can't write it, though I don't have trouble with PHP.  Thanks again for your help :-)
