Author Topic: Using VB.Net to Import/Insert a DXF File in Existing Drawing  (Read 30977 times)
MGorecki
« on: March 09, 2011, 10:17:51 AM »
Hello,
I've looked all over for information on how to insert a DXF file into an existing drawing, but cannot find anything that works.
Does someone have a way to insert a DXF file into an existing drawing using VB.Net?  I've updated my references to include the AuoDesk.AutoCAD.Interop and Interop.Common, but still cannot work out a way to insert a DXF file.
Thanks in advance for any help or at least pointing me in the right direction.
Jeff H
Re: Using VB.Net to Import/Insert a DXF File in Existing Drawing
« Reply #1 on: March 09, 2011, 01:21:25 PM »
Have you looked at Database.DxfIn()
Jeff H
« Reply #2 on: March 09, 2011, 01:37:05 PM »
Sorry, Mixed up forget the DxfIN
 seems I have done it with Regular Insert
Jeff H
« Reply #3 on: March 09, 2011, 01:40:13 PM »
I remember now, post at Autodesk fourms
This code is from Kerry Brown at http://www.theswamp.org/index.php?topic=34982.0 with a litle a change so thank him.
[CommandMethod("ImportDXF")]
          public void ImportDXF()
            AcadDocument comDoc = (Autodesk.AutoCAD.Interop.AcadDocument)doc.AcadDocument;
            double myScale = 1;
            Point3d p1 = Point3d.Origin;
            double[] ptArray = p1.ToArray();
            comDoc.Import(@"C:\Users\Jeff\My Documents\XrefTest.dxf", (object)ptArray, myScale);
kaefer
« Reply #4 on: March 10, 2011, 11:00:58 AM »
Is it just me or can't the insertion point be set? (Scale factor works fine btw.)
        let ppr = ed.GetPoint "Insertion point"
        if ppr.Status = PromptStatus.OK then
            let pdr = ed.GetDouble "Scale factor"
            if pdr.Status = PromptStatus.OK then
                let objs = new ResizeArray<_>()
                    use objectAppended =
                        db.ObjectAppended
                        |> Observable.subscribe
                            (fun e -> objs.Add e.DBObject.ObjectId)
                    doc.AcadDocument?Import(dialog.FileName, ppr.Value.ToArray(), pdr.Value)
                objs |> Array.ofSeq |> ed.SetImpliedSelection
Jeff H
« Reply #5 on: March 10, 2011, 05:13:38 PM »
Was keeping it simple
kaefer
« Reply #6 on: March 11, 2011, 04:26:09 AM »
Kerry (thx) kept it simple too. Me wants complicated.
What exactly needs to be passed to the Import method to influence the insertion point? (System.Double[] likely doesn't cut it)
« Reply #7 on: March 11, 2011, 09:01:54 AM »
kaefer ,
I'm unsure of the f# syntax, and how much goes on behind the scenes regarding typing, but
I think you will need to cast the array of doubles to an object.
kaefer
« Reply #8 on: March 11, 2011, 04:45:20 PM »
Oh, sorry. I think its the same as in C#, autoboxing when assigning to object[].
My problem doesn't seem to be the missing cast, but an unintuative interpretation of "insertion point" by the Import method. The following C# code exhibits the same weird behaviour: treating the insertion point as 0,0,0 when the scale factor is 1.0, else do something, but not what I'd expect.
   public class MyDxfInCmdClass
        IList<ObjectId> objs;
        [CommandMethod("MyDxfIn")]
        public void MyDxfInCmd()
            objs = new List<ObjectId>();
            Document doc = AcApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            var dialog = new System.Windows.Forms.OpenFileDialog{
                    CheckFileExists = true,
                    CheckPathExists = true,
                    DefaultExt = "dxf",
                    DereferenceLinks = true,
                    Filter = "DXF Files (*.dxf)|*.dxf|All files (*.*)|*.*" ,
                    Title = "Select dxf file" };
            if(dialog.ShowDialog() != System.Windows.Forms.DialogResult.OK)
                return;
            var ppr = ed.GetPoint("Insertion point");
            if(ppr.Status != PromptStatus.OK)
                return;
            var pdr = ed.GetDouble("Scale factor");
            if(pdr.Status != PromptStatus.OK)
                return;
            db.ObjectAppended += new ObjectEventHandler(ObjectAppended);
            try
                object[] args = new object[] {
                Invoke(doc.AcadDocument, "Import", args);
       finally
       db.ObjectAppended -= new ObjectEventHandler(ObjectAppended);
            ObjectId[] ids = new ObjectId[objs.Count];
            objs.CopyTo(ids, 0);
            ed.SetImpliedSelection(ids);
        void ObjectAppended(object sender, ObjectEventArgs e)
            objs.Add(e.DBObject.ObjectId);
        static object Invoke(object o, string name, params object[] args)
            return o.GetType().InvokeMember(name, System.Reflection.BindingFlags.InvokeMethod, null, o, args);
« Last Edit: March 11, 2011, 04:48:40 PM by kaefer »
« Reply #9 on: March 11, 2011, 09:58:11 PM »
The attached piccy shows my testing routine.
There seems to be a bug in the  Autodesk.AutoCAD.Interop.Import()
comDoc.Import(fn, (object)ptArray, insScale);If I insert at 100,200,0 with a scale of 1 the dxf comes in at 0,0,0 at 1:1
If I insert at 100,200,0 with a scale of 2 the dxf comes in at -100,-200,0 at 2:1
If I insert at 100,200,0 with a scale of 3 the dxf comes in at -200,-400,0 at 3:1
I'm sure you see the progression :)
I'll do some more testing and report it to the ADN.
« Reply #10 on: March 11, 2011, 10:23:44 PM »
One workaround may be :
Identify the last entity in the DataBase.
Collect the FileName, Location, Scale.
Import at 0,0,0 @ scale.
Build a collection of entitys in the Database after the previously identified last entity.
Move the collection from 0,0,0 to Location(factored).
« Reply #11 on: March 12, 2011, 03:23:00 AM »
Thinking about this while I was out ...
Another workaround may be :
Identify and save UCS information ; either Name or Coordinates.
Change the UCS Origin
Restore the Previous UCS
kaefer
« Reply #12 on: March 12, 2011, 04:57:34 AM »
Lots of "thank you!" for confirming my suspicions.
Won't do, because Import lives in world coordinates.
This is the way to go, then. The ObjectAppended event may be helpful to collect the entities and a transformation matrix build of displacement and rotation (extra bonus) does the work.
« Reply #13 on: March 12, 2011, 05:38:25 AM »
I've reported the anomolie.
I'll have a play tomorrow if I can make time ... unless 'someone' posts a solution in the meantime :)
I have code in Lisp for doing what is needed so I know the idea works.
Glenn R
« Reply #14 on: March 12, 2011, 05:23:50 PM »
Has anybody tried:
1. New 'side database'
2. DxfIn method on new 'side database' to insert dxf file into new pristine database
3. insert the new 'side database' with dxf info into current drawing
