Author Topic: MATCHPROP command settings  (Read 6912 times)
« on: March 09, 2011, 10:03:55 AM »
Does anyone know where/how to set or reset the properties used by the MATCHPROP command?
My quick search came up empty.  :-(
Re: MATCHPROP command settings
« Reply #1 on: March 09, 2011, 10:20:04 AM »
Select an object, then type 'Settings' ?
[ in 2010 anyway ]
alanjt
  • Standby for witty remark...
« Reply #2 on: March 09, 2011, 10:20:19 AM »
Wasn't it's original name PAINTER?
Dropbox
alanjt
« Reply #3 on: March 09, 2011, 10:20:46 AM »
[ in 2010 anyway ]
I think he meant with code.
Dropbox
« Reply #4 on: March 09, 2011, 10:21:48 AM »
[ in 2010 anyway ]
Oops! Most likely!  :oops:
BlackBox
« Reply #5 on: March 09, 2011, 10:23:46 AM »
[ in 2010 anyway ]
 :lmao:
(command "._matchprop" pause "Settings")
alanjt
« Reply #6 on: March 09, 2011, 10:24:57 AM »
[ in 2010 anyway ]
 :lmao:
Dropbox
Tharwat
  • Hypersensitive
« Reply #7 on: March 09, 2011, 10:25:51 AM »
And it is still goes on .
Matchprop + painter = the same  :-)
alanjt
« Reply #8 on: March 09, 2011, 10:26:48 AM »
I meant that as another possible search option.
Dropbox
BlackBox
« Reply #9 on: March 09, 2011, 10:31:36 AM »
« Reply #10 on: March 09, 2011, 10:33:51 AM »
I don't think the settings are stored in the registry since it seems they are local to the application, i.e. when ACAD is closed, the settings are reset. However, settings are available between documents, so maybe blackboard namespace?
« Last Edit: March 09, 2011, 10:56:49 AM by Lee Mac »
« Reply #11 on: March 09, 2011, 12:08:10 PM »
I'm back.
Yes I wanted to be able to RESET/SET the properties with code.
So no one has found them yet?
3dwannab
« Reply #12 on: June 26, 2023, 04:26:27 PM »
I stand on the shoulders of giants but I feel like one now  :2funny:
MATCHMODE
Used RegScanner for items changed in the last 5 minutes and saw this little variable hanging about in:
HKCU\SOFTWARE\Autodesk\AutoCAD\RXX.X\ACAD-XXXX:XXX\Profiles\2020 ARG Settings\Variables
I was searching the command line with *mode* but nothing came up. I guess it follows SELECTSIMILARMODE but they forgot to expose it as a variable. After all, it's in the same reg path as MATCHMODE.
Edit:
Does anyone know how to suppress the message from (command "_.matchprop"...)
Current active settings:  Color Layer Ltype Ltscale Lineweight Transparency Thickness Dim Text Hatch Polyline Viewport Table Material Multileader Center object"?
« Last Edit: June 26, 2023, 05:47:30 PM by 3dwannab »
ribarm
  • Marko Ribar, architect
« Reply #13 on: June 27, 2023, 06:44:48 AM »
When MATCHPROPs is an issue, I have to pinpoint that this routine comes to my mind - make properties current from picked entity...
https://www.cadtutor.net/forum/topic/77773-make-current-line-properties-routine-lsp/?do=findComment&comment=620080
HTH., M.R.
M.R. on Youtube
