Author Topic: Working with Section planes in .NET  (Read 4951 times)
willmswamp
« on: March 08, 2011, 06:28:33 PM »
To all,
I have been playing around with the sectioning capabilities in .NET, but have hit a snag.
When working manually in AutoCAD , you can create a section plane (SECTIONPLANE command) and then by right-clicking on the section plane you can create a 2D section of the solids that are cut by the section plane.  In the settings, you can then turn on background geometry and turn off hidden lines, this will create a 2D section that shows background geometry but hides lines that are hidden behind other solids.
The .NET API provides access to these same capabilities.  However, I cannot achieve what is described above. It appears as though the GenerateSectionGeometry method can only be applied to a single solid, one-at-a-time. Therefore, when this method is used with the visiblity of background geometry set to true and the visibilty of hiddenlines set to false, it does hide lines on the backside of a solid but lines on a solid that should be hidden behind another solid are still visible.  The desired behavior is that these lines-hidden-behind-solids should not be visible.  Is this functionality achievable with the .NET API?  I hope so.
I have attached my source code below.  Please let me know if you see what I am doing wrong.
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
<Assembly: CommandClass(GetType(Autodesk.AutoCAD.SectionTest.SOMRClass))>
Namespace Autodesk.AutoCAD.SectionTest
    Public Class SOMRClass
        <CommandMethod("view2d")> _
        Public Sub SectionTest()
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Dim acDocEd As Editor = acDoc.Editor
            'set up prompt selection options
            Dim acPromptSelOpt As PromptSelectionOptions = New PromptSelectionOptions()
            acPromptSelOpt.MessageForAdding = vbLf & "Select entities to section: "
            acPromptSelOpt.MessageForRemoval = vbLf & "Select entities to remove from selection set: "
            acPromptSelOpt.RejectObjectsFromNonCurrentSpace = True
            'create a typed value array to define the filter criteria, filter for 3dSolids and BlockReferences
            Dim acTypValAr(2) As TypedValue
            acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "<or"), 0)
            acTypValAr.SetValue(New TypedValue(DxfCode.Start, "3dsolid"), 1)
            acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "or>"), 2)
            'assign filter criteria to a selectionfilter object
            Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
            'ask the user to select an entity to section
            Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection(acPromptSelOpt, acSelFtr)
            If acSSPrompt.Status = PromptStatus.OK Then
                'save selection set to acSS
                Dim acSSet As SelectionSet = acSSPrompt.Value
                'ask the user to select points to be used to define the section plane
                Dim acPtsColl As Point3dCollection = New Point3dCollection()
                Dim acPtPrompt As PromptPointResult = acDocEd.GetPoint(vbLf & "Pick first point for section: ")
                If acPtPrompt.Status = PromptStatus.OK Then
                    acPtsColl.Add(acPtPrompt.Value)
                    Dim acPromptPtOpt As PromptPointOptions = New PromptPointOptions(vbLf & "Pick end point for section: ")
                    acPromptPtOpt.BasePoint = acPtPrompt.Value
                    acPromptPtOpt.UseBasePoint = True
                    acPtPrompt = acDocEd.GetPoint(acPromptPtOpt)
                        Try
                            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                                'now let's create our section object
                                Dim acSect As Section = New Section(acPtsColl, Vector3d.ZAxis)
                                acSect.State = SectionState.Plane
                                acSect.SetHeight(SectionHeight.HeightAboveSectionLine, 3.0)
                                acSect.SetHeight(SectionHeight.HeightBelowSectionLine, 1.0)
                                'get modelspace
                                Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                Dim acModelSp As BlockTableRecord = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                                'the section must be added to the drwing
                                Dim acSectObjId As ObjectId = acModelSp.AppendEntity(acSect)
                                acTrans.AddNewlyCreatedDBObject(acSect, True)
                                'get the section settings for the section object
                                Dim acSecSettings As SectionSettings = acTrans.GetObject(acSect.Settings, OpenMode.ForWrite)
                                'set the section type
                                acSecSettings.CurrentSectionType = SectionType.Section2d
                                'get the object ID collection of all entities in the selection set
                                Dim acObjIdCol As ObjectIdCollection = SS2IdCol(acSSet)
                                'set the source objects
                                acSecSettings.SetSourceObjects(SectionType.Section2d, acObjIdCol)
                                'set all visibility settings to false to start with
                                acSecSettings.SetVisibility(SectionType.Section2d, SectionGeometry.BackgroundGeometry, False)
                                acSecSettings.SetVisibility(SectionType.Section2d, SectionGeometry.CurveTangencyLines, False)
                                acSecSettings.SetVisibility(SectionType.Section2d, SectionGeometry.ForegroundGeometry, False)
                                acSecSettings.SetVisibility(SectionType.Section2d, SectionGeometry.IntersectionFill, False)
                                acSecSettings.SetHiddenLine(SectionType.Section2d, SectionGeometry.BackgroundGeometry, False)
                                acSecSettings.SetHiddenLine(SectionType.Section2d, SectionGeometry.ForegroundGeometry, False)
                                acSecSettings.SetHatchVisibility(SectionType.Section2d, SectionGeometry.IntersectionFill, False)
                                'prompt user to select options for the visibility section settings
                                Dim pKeyOpts As PromptKeywordOptions = New PromptKeywordOptions("")
                                pKeyOpts.Message = vbLf & "Show background: "
                                pKeyOpts.Keywords.Add("Yes")
                                pKeyOpts.Keywords.Add("No")
                                pKeyOpts.AllowNone = False
                                Dim pKeyRes As PromptResult = acDocEd.GetKeywords(pKeyOpts)
                                If pKeyRes.Status = PromptStatus.OK Then
                                    If pKeyRes.StringResult = "Yes" Then
                                        'turn on visibility of background geometry
                                        acSecSettings.SetVisibility(SectionType.Section2d, SectionGeometry.BackgroundGeometry, True)
                                        'The user chose to show background, therefore ask the user whether they want to show hidden lines
                                        Dim pKeyOpts2 As PromptKeywordOptions = New PromptKeywordOptions("")
                                        pKeyOpts2.Message = vbLf & "Show hidden lines: "
                                        pKeyOpts2.Keywords.Add("Yes")
                                        pKeyOpts2.Keywords.Add("No")
                                        pKeyOpts2.AllowNone = False
                                        Dim pKeyRes2 As PromptResult = acDocEd.GetKeywords(pKeyOpts2)
                                        If pKeyRes2.Status = PromptStatus.OK Then
                                            If pKeyRes2.StringResult = "Yes" Then
                                                'the user chose to show hidden lines
                                                acSecSettings.SetHiddenLine(SectionType.Section2d, SectionGeometry.BackgroundGeometry, True)
                                            End If
                                        End If
                                    End If
                                End If
                                'set generation options
                                acSecSettings.SetGenerationOptions(SectionType.Section2d, SectionGeneration.SourceSelectedObjects Or SectionGeneration.DestinationNewBlock)
                                'create a block that will store our generated section drawing
                                Dim sectblock As BlockTableRecord = New BlockTableRecord()
                                'set the name of the block to the next available block name in the form "2D_Section_###"
                                sectblock.Name = GetNextBlkName(acBlkTbl)
                                'upgrade the blocktable to allow changes
                                acBlkTbl.UpgradeOpen()
                                'add the new block to the block table
                                Dim sectBlockId As ObjectId = acBlkTbl.Add(sectblock)
                                acTrans.AddNewlyCreatedDBObject(sectblock, True)
                                For Each acObjId As ObjectId In acObjIdCol
                                    Try
                                        'get the entity, exception occurs heer
                                        Dim acEnt As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead)
                                        'generate the section geometry
                                        Dim flEnts As Array
                                        Dim bgEnts As Array
                                        Dim fgEnts As Array
                                        Dim ftEnts As Array
                                        Dim ctEnts As Array
                                        acSect.GenerateSectionGeometry(acEnt, flEnts, bgEnts, fgEnts, ftEnts, ctEnts)
                                        'add the geometry to the block
                                        For Each flEnt As Entity In flEnts
                                            sectblock.AppendEntity(flEnt)
                                            acTrans.AddNewlyCreatedDBObject(flEnt, True)
                                        Next
                                        For Each bgEnt As Entity In bgEnts
                                            sectblock.AppendEntity(bgEnt)
                                            acTrans.AddNewlyCreatedDBObject(bgEnt, True)
                                        Next
                                        For Each fgEnt As Entity In fgEnts
                                            sectblock.AppendEntity(fgEnt)
                                            acTrans.AddNewlyCreatedDBObject(fgEnt, True)
                                        Next
                                        For Each ftEnt As Entity In ftEnts
                                            sectblock.AppendEntity(ftEnt)
                                            acTrans.AddNewlyCreatedDBObject(ftEnt, True)
                                        Next
                                        For Each ctEnt As Entity In ctEnts
                                            sectblock.AppendEntity(ctEnt)
                                            acTrans.AddNewlyCreatedDBObject(ctEnt, True)
                                        Next
                                    Catch ex As System.Exception
                                        acDocEd.WriteMessage(vbLf & "Error: " & ex.Message)
                                    End Try
                                Next
                                'insert the block into model space
                                Dim insertSuccess As Boolean = InsertSection(sectBlockId)
                                'commit the transaction
                                acTrans.Commit()
                            End Using
                        End Try
                    End If
                End If
            End If
        End Sub
        'function to insert the created block into modelspace
        Public Function InsertSection(ByVal acBlkTabRecId As ObjectId) As Boolean
            Dim acEd As Editor = acDoc.Editor
            Dim success As Boolean = True
            Try
                    Dim pPtRes As PromptPointResult
                    Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
                    'prompt for the insertion point of the section block
                    pPtOpts.Message = vbLf & "Pick the insertion point for the section block: "
                    pPtRes = acEd.GetPoint(pPtOpts)
                    If pPtRes.Status = PromptStatus.OK Then
                        'extract the point
                        Dim BlkInsertPt As Point3d = pPtRes.Value
                        'create the block reference
                        Dim acNewBlkRef As BlockReference = New BlockReference(BlkInsertPt, acBlkTabRecId)
                        'prompt user for the scale factor
                        Dim pDblRes As PromptDoubleResult
                        Dim pDblOpts As PromptDoubleOptions = New PromptDoubleOptions("")
                        pDblOpts.Message = vbLf & "Enter the scale factor: "
                        pDblOpts.AllowNegative = False
                        pDblOpts.AllowZero = False
                        pDblOpts.DefaultValue = 1
                        pDblRes = acEd.GetDouble(pDblOpts)
                        If pDblRes.Status = PromptStatus.OK Then
                            'calculate the scale factor
                            Dim ScaleFact As Double = pDblRes.Value
                            'create the transformation matrix
                            Dim matTransform As Matrix3d = Matrix3d.Scaling(ScaleFact, BlkInsertPt)
                            'scale the block
                            acNewBlkRef.TransformBy(matTransform)
                            'get modelspace
                            'add teh block reference to the layout block table record
                            acModelSp.AppendEntity(acNewBlkRef)
                            'add the block reference to the transaction
                            acTrans.AddNewlyCreatedDBObject(acNewBlkRef, True)
                        End If
                    End If
                    acTrans.Commit()
                End Using
                acEd.WriteMessage(vbLf & "Error:" & ex.Message)
                success = False
            End Try
            Return success
        End Function
        'function to take a selectionset and return an object id collection
        Private Function SS2IdCol(ByVal acSSet As SelectionSet) As ObjectIdCollection
            Dim acOBjIdColl As ObjectIdCollection = New ObjectIdCollection()
                For Each acSSObj As SelectedObject In acSSet
                    acOBjIdColl.Add(acSSObj.ObjectId)
                Next
            End Using
            Return acOBjIdColl
        End Function
        'function to get the next available block name in the form "2D_Section_###"
        Private Function GetNextBlkName(ByVal acBlkTable As BlockTable) As String
            Dim startString As String = "001"
            Do While acBlkTable.Has("2D_Section_" & startString)
                Dim nextInt As Integer = CInt(startString) + 1
                startString = nextInt.ToString("000")
            Loop
            startString = "2D_Section_" & startString
            Return startString
        End Function
    End Class
End Namespace
bikelink
Re: Working with Section planes in .NET
« Reply #1 on: March 13, 2011, 03:09:32 PM »
in order to obtain a section You can use the "section" object.  with this You can process more solids.
some like this
Autodesk.AutoCAD.DatabaseServices.Section se = new Section(ptsez, asseverticale);
                        se.TopPlane = limiteSup;
                        se.BottomPlane = limiteInf;
                        Array ents;
                        using (Transaction tr = d.Database.TransactionManager.StartTransaction())
                            // creazione linea sezione
                            BlockTable bt = (BlockTable)tr.GetObject(d.Database.BlockTableId, OpenMode.ForRead);
                            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                            btr.AppendEntity(se);
                            tr.AddNewlyCreatedDBObject(se, true);
                            // riapertura oggettoa
                            se = tr.GetObject(se.ObjectId, OpenMode.ForWrite) as Section;
                            se.State = SectionState.Plane;
                            //---------SETTAGGI SEZIONE
                            SectionSettings ss = (SectionSettings)tr.GetObject(se.Settings, OpenMode.ForWrite);
                            // Impostazione tipo sezione
                            ss.CurrentSectionType = st;
                            // We only set one additional option if "Live"
                            if (st == SectionType.LiveSection)
                                se.EnableLiveSection(true);
                            else
                        Array ents;
                            else
                                // Non-live (i.e. 2D or 3D) settings
                                ObjectIdCollection oic = new ObjectIdCollection();
                                idsolido = B2UtilCad.b2Handle.GetHandleAsObjectID(d, hnOggettoDaSezionare);
                                oic.Add(idsolido);
                                ss.SetSourceObjects(st, oic);
                                if (st == SectionType.Section2d)
                                    // 2D-specific settings
                                    ss.SetVisibility(st, SectionGeometry.BackgroundGeometry, true);
                                    ss.SetHiddenLine(st, SectionGeometry.BackgroundGeometry, false);
                                else if (st == SectionType.Section3d)
                                    // 3D-specific settings
                                    ss.SetVisibility(st, SectionGeometry.ForegroundGeometry, true);
                                // Finish up the common 2D/3D settings
                                ss.SetGenerationOptions(st, SectionGeneration.SourceSelectedObjects | SectionGeneration.DestinationFile);
                                oic.Add(idsolido);
willmswamp
« Reply #2 on: March 15, 2011, 03:40:11 PM »
Dear bikelink,
I am sorry, but, from your code example, I cannot see that your implementation of the section object addresses my problem (or is that different from what I have done in my code).  Perhaps the code example you gave me is incomplete.  Perhaps you could explain more.
My code works well for 2d sections of multiple solids when background geometry is turned off.  What it does not do is hide lines that should be hidden behind other solids when background geometry is turned on (and hidden line visibility is set to false).  This is what I want to achieve.
Thanks,
Will
zero.half
  • Mosquito
« Reply #3 on: November 27, 2019, 08:59:43 AM »
Hello,
Sorry for digging out that old topic, but seems that this issue is still not resolved.
Has anyone found some workaround? Would be deeply appreciated.
