Author Topic: confused on the name of ATTDYNBLOCKREF,please help  (Read 9595 times)
snddd2000
« on: March 08, 2011, 02:38:47 AM »
now i have a block list as below
((-1 . <图元名: 7efc0300>) (0 . "INSERT") (5 . "B9B8") (102 . "{ACAD_XDICTIONARY") (360 . <图元名: 7ed09318>) (102 . "}") (330 . <图元名: 7efa9cf8>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "细实线") (100 . "AcDbBlockReference") (66 . 1) (2 . "*U661") (10 3672.0 784.0 0.0) (41 . 8.0) (42 . 8.0) (43 . 8.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0))
the  (2 . "*U661") should be the name ,but when i defined this block the name is "qq",not "*U661"
why? confuesd long time
thanks
please help me!
my english is not good
 :-o
Tharwat
  • Hypersensitive
Re: confused on the name of ATTDYNBLOCKREF,please help
« Reply #1 on: March 08, 2011, 02:54:17 AM »
I guess this would give the real name of it .
(setq ss (ssget "_+.:S" '((0 . "INSERT"))))
(setq BlkName (vla-get-effectivename  (vlax-ename->vla-object (ssname ss 0))))
Regards,
Tharwat
snddd2000
« Reply #2 on: March 08, 2011, 03:15:19 AM »
the real name ? means what? :oops:
thanks
Tharwat
  • Hypersensitive
« Reply #3 on: March 08, 2011, 03:18:58 AM »
Your Block name before going to become a Dynamic Block
Try the codes and you will find it out .
snddd2000
« Reply #4 on: March 08, 2011, 03:21:56 AM »
when i copy this block to another dwg.
the *U661 would be changed ,and the "qq"  not changed.
press ctrl+1 the name "qq" in the list of properties
snddd2000
« Reply #5 on: March 08, 2011, 03:22:52 AM »
yes the block is Dynamic Block
Dynamic Block name must like this?
thanks
« Reply #6 on: March 08, 2011, 03:24:31 AM »
You do understand with dynamic blocks anytime you change a dynamic property it will create a anonymous block?
snddd2000
« Reply #7 on: March 08, 2011, 03:26:46 AM »
thanks a lot
it works
one question
why add "_+.:" before :S?  :lol:
Tharwat
  • Hypersensitive
« Reply #8 on: March 08, 2011, 03:29:55 AM »
thanks a lot
it works
one question
Because the ssget function is multi-selection set and to add "_+.:S" would force it for single selection set only ( one selection set).
Good luck.
snddd2000
« Reply #9 on: March 08, 2011, 03:31:28 AM »
but why select two diffrent block ,the name is same?
命令: (vlax-get-property (vlax-ename->vla-object  (car (entsel))) 'name)
选择对象: "*U661"
选择对象: "*U661"
snddd2000
« Reply #10 on: March 08, 2011, 03:35:39 AM »
thanks a lot
it works
one question
why add "_+." before :S?  :lol:
Good luck.
how can i filter this name block by ssget?
thanks
pBe
« Reply #11 on: March 08, 2011, 06:54:42 AM »
right after this: (as tharwats suggestion)
Before you processed the block, run this as a test for block name
it will you give you name of the block for your test/cond
(if (eq BlkName "qq") (.... <----- test
But if you're going to select on screen as the example suggest, you dont really need to do this as you already know you're selecting the correct block, but if you have the need for the blockname then you should run the test.
Now if you select the entire database using "_X" (meaning no prompt for selection on the screen)
(setq ss (ssget "_X" '((0 . "INSERT")(2 . "*U*,qq"))))Then you need to run it through the test before you worked on the block
That is just how Dynamic Block behaves (Autodesk needs to do something about this I guess), converting it to an anonymous name
Hope this helps
« Last Edit: March 08, 2011, 07:12:56 AM by pBe »
snddd2000
« Reply #12 on: March 08, 2011, 08:14:05 PM »
Hope this helps
thanks a lot but this (setq ss (ssget "_X" '((0 . "INSERT")(2 . "*U*,qq")))) does not work
canot select any blocks,
now i use below way to do
(setq ss1 (ssget '((0 . "INSERT"))) )
(setq count  (sslength ss1)
      n       0
      n1      0
      zl1     0
      zzl1    0
(repeat count
 (if (/= "qq" (vla-get-effectivename (vlax-ename->vla-object (ssname ss1 n))))
    (ssdel (ssname ss1 n) ss1)
    (setq n (1- n))
 (setq n (1+ n))
i do not know any better way.
thanks all
pBe
« Reply #13 on: March 08, 2011, 10:35:29 PM »
oops my bad
Should be
(setq ss (ssget "_X" '((0 . "INSERT")(2 . "`*U*,qq"))))or
(setq ss (ssget  '((0 . "INSERT")(2 . "`*U*,qq"))))
But anyway, i see you got it figured out
« Last Edit: March 08, 2011, 11:05:30 PM by pBe »
snddd2000
« Reply #14 on: March 08, 2011, 10:48:30 PM »
oops my bad
Should be
Great, it is right , i like your way
thank you very much
