Author Topic: Overriding a single dimension.  (Read 2662 times)
Krushert
  • FREE BEER Tomorrow!!
« on: March 07, 2011, 12:55:20 PM »
Okay I got one half of the puzzle put together.  I want to move the text of the dimension and then change the vertical position of the dim text.  Right now I have to select the text and right click the mouse to move and then select the text again, right click again in order to center it.  A pain if I have more that a couple of dimensions to process.
I have the move part down, that was simple enough.  But the center part is not working.  if I used the command line command [_ai_dim_textcenter] after doing the right click method and tossing that into my code, it spits up unknown command.  IMO, it acts as if it is a transparent command.   So that is not working.
I did a search with the DXF codes that reflect the DIMTAD variable but how do I use it.
    (1070 . 77) (1070 . 1)
Or is there a better way?
BlackBox
Re: Overriding a single dimension.
« Reply #1 on: March 07, 2011, 01:29:08 PM »
My two cents...
If you need to modify dimensions often, why not simply use a selection set, and modify the ActiveX properties as necessary?
For more information about the properties and methods available, use the vlax-dump-object function, or see the developer documentation.
Edit: If you still need help, try posting your code?
Hope this helps!
alanjt
  • Standby for witty remark...
« Reply #2 on: March 07, 2011, 01:32:13 PM »
(c:ai_dim_textcenter)
Dropbox
Krushert
« Reply #3 on: March 07, 2011, 02:23:18 PM »
Okay I can get that to work in the code but I can not get that to work with  aidimtextmove.  Each one will work fine by themselves but when I try to combine them it gives me the number one sign.  This is the close to working as I got it.
(defun c:DTM ()
(SETQ DIMOBJ (ENTLAST))
(VL-CMDF "aidimtextmove" "1"  DIMOBJ )
); END OF ROUTINE
