Author Topic: Entering Attribute Block Definition to get strings and tags  (Read 6199 times)
Coder
Re: Entering Attribute Block Definition to get strings and tags
« Reply #15 on: March 06, 2011, 07:54:26 AM »
Not bad! A nice attempt, with only a few tweaks:
Thank you so much , so I have been running around the same spot . :-)
The second routine throw an error ...... :-(
Select objects:  ; error: bad argument type: VLA-OBJECT (#<VLA-OBJECT
IAcadAttributeReference 0e3249bc> #<VLA-OBJECT IAcadAttributeReference
0e32469c>)
Coder
« Reply #16 on: March 06, 2011, 08:03:58 AM »
Now it is OK after your last modification which I did not notice while I have been writing my reply .
Anyway , That is really great , specially with the use of (car e) which gives a meaning that the obj is a list , besides that, I tried
it with (cadr e) and It did give me the second string in the Att. Block .
Finally , is the Obj is a list of all the Attributes in the selected block ?
(setq e  (vlax-invoke obj 'GetAttributes))
(print (vla-get-TextString ([color=red]car[/color] e))
(print (vla-get-TextString ([color=red]cadr[/color] e)))
Works like a charm.
Thank you.
« Reply #17 on: March 06, 2011, 08:12:44 AM »
Yup - I missed that in the code too  :oops:
The variable 'obj' points to the VLA Block Reference Object. This object has methods that may be applied to it (see my earlier long explanation). We can view which methods are available using the following code:
(defun c:test ( / e ) (vl-load-com)
  (if (setq e (car (entsel "\nSelect Block: ")))
      (vlax-dump-object (vlax-ename->vla-object e) t)
      (textpage)
Now, if we apply the 'GetAttributes' method, a List of VLA Attribute Objects is returned. This List is bounded to the variable 'e' in your code.
Lee
