Hello all:
I have passed a dwg full of entitys "surface" (0. "SURFACE") ... bahh!, easy! ... "explode" and ok .... no! ...no run.
In 2008 I have only the edges of the surface .... in 2004 the borders and inside several 3DPOLY by defining the irregularities of the surface ... each with a different number of vertices!
Someone knows how to get 3Dfaces, poly-face-mesh, mesh, etc... or something "digestible" ...
I reread the great support of EXPLODE is anything but clean sack me fix the ballot.
If you need to do another version, I also okay ... but I can not prove it.
In the attachment below the original entity ... ... in half, broken in 2008, up to 2004 ....
Thanks in advance
Regards
