Author Topic: My head hurts.. problem with a list  (Read 7073 times)
Brick_top
« on: March 01, 2011, 09:04:52 AM »
Hi, I have a list of several values for example
(10.2757 12.1581 33.2103)
But this list can have a different number of items.
I want to create a new list which would be:
the first element of the original list , and then every next element should be the sum of itself plus the sum of every other item prior to it.
« Last Edit: March 01, 2011, 12:03:38 PM by Brick_top »
Stefan
Re: My head hurts.. problem with a list
« Reply #1 on: March 01, 2011, 09:19:40 AM »
Try this
(defun newlist (l / sum)
  (setq sum 0)
  (mapcar (function (lambda (e) (setq sum (+ e sum)))) l)
Brick_top
« Reply #2 on: March 01, 2011, 09:27:49 AM »
Oh... it was simpler than I though
I figured out a way to do it
(repeat (- (length dl2) 1)
    (setq dl3 (apply '+ dl2))
    (setq dl4 (append (list dl3) dl4))
    (setq dl2 (cdr dl2))
where dl2 is the list, which I have to reverse first
I just have to add the first element when the loop is ended
thanks a lot for your solution aswell!
« Last Edit: March 01, 2011, 12:04:18 PM by Brick_top »
Brick_top
« Reply #3 on: March 01, 2011, 09:55:47 AM »
Try this
  (setq sum 0)
am I doing something wrong or is your function making a sum of all the elements in the list?
« Reply #4 on: March 01, 2011, 11:39:05 AM »
Here's one way to do it:
(setq lst '(10.2757 12.1581 33.2103 45.11 1.1 2.2 3.3))
(cons (car lst) (mapcar (function (lambda (l1 l2) (+ l1 l2))) lst (cdr lst)))
;;returns
;;(10.2757 22.4338 45.3684 78.3203 46.21 3.3 5.5)
« Last Edit: March 01, 2011, 11:44:24 AM by ronjonp »
Brick_top
« Reply #5 on: March 01, 2011, 11:59:29 AM »
Having watched your expertize in other threads I guess I must have not explained myself very well, I'll try again.
example of original list (10 20 30 40 50)
the list I wanted was:
element nº 1 = 10
element nº 2 = (20 + 10)
element nº 3 = (30 + 20 + 10)
element nº 4 = (40 + 30 + 20 + 10)
element nº 5 = (50 + 40 + 30 + 20 + 10)
But anyway my way of doing it is working as I want, thanks a lot for chiming in!
;;returns
« Reply #6 on: March 01, 2011, 12:04:02 PM »
element nš 1 = 10
element nš 2 = (20 + 10)
element nš 3 = (30 + 20 + 10)
element nš 4 = (40 + 30 + 20 + 10)
element nš 5 = (50 + 40 + 30 + 20 + 10)
;;returns
After reading closer "sum of every other item prior to it" I was way off  :-D Sorry ... looks like Vovka is looking at thread ... I'm sure he'll have a one liner for you  8-)
Brick_top
« Reply #7 on: March 01, 2011, 12:07:11 PM »
At least its good to know that my english is not that bad after all  :laugh:
« Reply #8 on: March 01, 2011, 12:08:22 PM »
phanaem answered your question in post 2.  Just pass you list to the ' NewList ' function.
Command: (NEWLIST '(10 20 30 40 50))
(10 30 60 100 150)
Brick_top
« Reply #9 on: March 01, 2011, 12:09:25 PM »
(10 30 60 100 150)
Must have done something wrong while trying the function then
Thanks a lot
« Reply #10 on: March 01, 2011, 12:09:43 PM »
Not pretty but ... Here's my other post modified to do what you want ...
A While version:
(defun whee (lst / n out x)
  (setq n 0.)
  (while (setq x (car lst))
    (setq out (cons (setq n (+ x n)) out)
 lst (cdr lst)
  (reverse out)
(whee '(10.2757 12.1581 33.2103 45.11 1.1 2.2 3.3))
*Edit .. had CDR in wrong place  .. man I need more coffee  :oops:
« Last Edit: March 01, 2011, 12:28:37 PM by ronjonp »
VovKa
  • Ukraine
« Reply #11 on: March 01, 2011, 12:13:24 PM »
and Vovka is still looking.... :)
Brick_top
« Reply #12 on: March 01, 2011, 12:13:45 PM »
(setq tmp 0.
(cons (car lst) (mapcar (function (lambda (l1 l2) (+ (setq tmp (+ l1 tmp)) l2))) lst (cdr lst)))
;;returns
;;(10.2757 22.4338 55.6441 100.754 101.854 104.054 107.354)
thanks a lot, its good to learn how others think.
Unfortunately my solution is not that elegant
« Reply #13 on: March 01, 2011, 12:25:39 PM »
(setq tmp 0.
;;returns
I modified the code above ... should be a bit faster  :-)
« Reply #14 on: March 01, 2011, 12:25:58 PM »
