Author Topic: Automatically load .dll file in 2010?  (Read 7333 times)
deathman20
« on: February 28, 2011, 09:48:06 AM »
Ok trying to make an installer for my dll, easier to deploy in my little department.  Though having issues trying to get the correct registry settings to make it automatically load the DLL?
So far the registry entry is.
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8005:409\Applications\ConveyorDept]
"DESCRIPTION"="Layout Department Ribbon Bar"
"LOADER"="C:\\Program Files\\AutoCAD RibbonBar\\BottleConveyorRibbon.dll"
"MANAGED"=dword:00000001
"LOADCTRLS"=dword:00000002
Yet it doesn't load.  Was trying to follow what others have done but just doesn't seem to be working.  Any suggestions?
I know it loads it in memory, because the commandline paramaters I use work (though incorrectly) but the ribbon bar I have doesn't load up.  It works perfectly fine if I run "netload" though.
vegbruiser
Re: Automatically load .dll file in 2010?
« Reply #1 on: February 28, 2011, 10:02:51 AM »
I've not done that much work with the Ribbon Bar in AutoCAD, but might it be related to the profile you're using? i.e. what ribbons are loaded and when.
Failing that, have you checked out Kean's posts regarding demand loading? - It's how I got around having to work with AutoCAD 2009 and the Ribbon Bar for the tool(s) I've created; AutoCAD 2009 didn't (unless I'm mistaken) have the combined Ribbon-specific libraries that newer versions have.
Which version of AutoCAD are you using by the way? It always helps make finding the answer easier.
(Do any of the admins know if there's a "useful info to post when looking for an answer" post?)
deathman20
« Reply #2 on: February 28, 2011, 10:12:11 AM »
Ah shoot thought I had put it in there, using AutoCAD 2010.  Well its a Mechanical install but just using plain AutoCAD.
Just tried another way.  Different spot in the registry and failed so the location I had it before is working just not fully loaded the module.
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8001:409\Applications\ConveyorDept]
"DESCRIPTION"="Test"
"LOADCTRLS"=dword:0000000e
As for Kean's post... now that you show the search that way, was just hitting up a few of those, there is some new ones I didn't see there yet.
vegbruiser
« Reply #3 on: February 28, 2011, 10:39:22 AM »
RE: the search, I was quite surprised that "demand loading" shows up that much too. :)
As it is AutoCAD Mechanical you're using, I'd definitely recommend you check what profile you're using when starting AutoCAD - that may be affecting your tool and what it loads.
deathman20
« Reply #4 on: February 28, 2011, 10:44:52 AM »
Well strange glitch per say I guess, it actually is loaded but I have to click on my workspace (what ever one I want) and it will show up then.
Didn't try that before so not sure if its the RegDL I got from http://through-the-interface.typepad.com/through_the_interface/2010/02/creating-demand-loading-entries-for-net-modules-outside-of-autocad.html or if my registry entry was making it run.  Edit: Actually notice that is using the exact same registry settings that I had, so it was running before just not showing up in the workspace properly.
I know I spend a few hours on Friday working with this and wasn't getting anywhere.  Maybe its dealing with the code for the ribbon bar where its not launching properly?  I believe this is the code for how its inserted into the workspace.
   Public Sub TrapWSCurrentChange(ByVal sender As Object, _
                                   ByVal e As cadAppSrvs.SystemVariableChangedEventArgs)
        If e.Name.Equals("WSCURRENT") Then createRibbon()
    End Sub
vegbruiser
« Reply #5 on: February 28, 2011, 10:53:03 AM »
That's an interesting (and seemingly obvious) method you've got there - would you mind sharing how you implement it? I'm guessing you're simply trapping the (and I'm making this up off the top of my head) "Workspace_changed" event to call TrapWSCurrentChange()?
Thanks,
Alex.
deathman20
« Reply #6 on: February 28, 2011, 10:57:14 AM »
Im not 100% sure exactly whats going on with it.  The code is copied from others that I've gotten but here is a bigger snip it, minus the main ribbon button area.  Though here is majority of the code dealing with the ribbon bar itself.
Imports System.Drawing
Imports System.Drawing.Imaging
Imports System.IO
Imports System.Runtime.InteropServices
Imports System.Windows.Media.Imaging
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.Windows
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports cadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports cadAppSrvs = Autodesk.AutoCAD.ApplicationServices
Public Class BottleConveyorRibbon
    Public Shared BlockName As String
    End Sub
    'Creates the Ribbon Tabs
    Public Sub createRibbon()
        Dim ribCntrl As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon
        If ComponentManager.Ribbon Is Nothing Then
            Return
        End If
        For i As Integer = 0 To ribCntrl.Tabs.Count - 1
            If ribCntrl.Tabs(i).Id.Equals("My_Rib_ID") Then
                Return
            End If
        Next
        'Creates a tab
        Dim mbc1Tab As New RibbonTab()
        mbc1Tab.Title = "Bottle Conveyor Mattop 1-10"
        mbc1Tab.Id = "Bottle_Conveyor_Mattop_1_10"
        ribCntrl.Tabs.Add(mbc1Tab)
        Dim mbc2Tab As New RibbonTab()
        mbc2Tab.Title = "Bottle Conveyor Mattop 12-20"
        mbc2Tab.Id = "Bottle_Conveyor_Mattop_12_20"
        ribCntrl.Tabs.Add(mbc2Tab)
        Dim bcmiscTab As New RibbonTab()
        bcmiscTab.Title = "Bottle Conveyor Misc"
        bcmiscTab.Id = "Bottle_Conveyor_Misc"
        ribCntrl.Tabs.Add(bcmiscTab)
        'Create and add the panels
        'Bottle Conveyor Mattop 1-10
        addmbc1c(mbc1Tab)
        addmbc2c(mbc1Tab)
        addmbc3c(mbc1Tab)
        addmbc4c(mbc1Tab)
        addmbc5c(mbc1Tab)
        addmbc6c(mbc1Tab)
        addmbc7c(mbc1Tab)
        addmbc8c(mbc1Tab)
        addmbc10c(mbc1Tab)
        'Bottle Conveyor Mattop 12-20
        addmbc12c(mbc2Tab)
        addmbc14c(mbc2Tab)
        addmbc16c(mbc2Tab)
        addmbc18c(mbc2Tab)
        addmbc20c(mbc2Tab)
        'Bottle Conveyor Misc
        addmbcFM(bcmiscTab)
        addmbcclean(bcmiscTab)
        addmbcAccum(bcmiscTab)
        addssbcAccum(bcmiscTab)
        addmbcWF(bcmiscTab)
        'set as active tab
        mbc1Tab.IsActive = True
    End Sub
    Private Sub removeRibbon()
        'find the custom tab using the Id
            If ribCntrl.Tabs(i).Id.Equals("Mattop_Bottle_Conveyor") Then
                ribCntrl.Tabs.Remove(ribCntrl.Tabs(i))
                Return
            End If
        Next
    End Sub
  ''' Bunch of Ribbon Bar Buttons :)
    'Imaging Information
    Public Function getBitmap(ByVal image As Bitmap) As BitmapImage
        Dim stream As New MemoryStream()
        image.Save(stream, ImageFormat.Png)
        Dim bmp As New BitmapImage()
        bmp.BeginInit()
        bmp.StreamSource = stream
        bmp.EndInit()
        Return bmp
    End Function
End Class
Public Class AdskCommandHandler
    Implements System.Windows.Input.ICommand
    Public Function CanExecute(ByVal parameter As Object) _
    As Boolean Implements System.Windows.Input.ICommand.CanExecute
        Return True
    End Function
    Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) _
    Implements System.Windows.Input.ICommand.CanExecuteChanged
    Public Sub Execute(ByVal parameter As Object) _
    Implements System.Windows.Input.ICommand.Execute
        Dim ribBtn As RibbonButton = TryCast(parameter, RibbonButton)
        If ribBtn IsNot Nothing Then
            BottleConveyorRibbon.BlockName = ribBtn.Text
            cadApp.DocumentManager.MdiActiveDocument.SendStringToExecute( _
                ribBtn.CommandParameter, True, False, True)
        End If
    End Sub
End Class
Another Piece of the code that deals with the trap function.
Imports Autodesk.AutoCAD.Runtime
<Assembly: ExtensionApplication(GetType(BottleConveyorRibbonApp.IntialEnd))>
Namespace BottleConveyorRibbonApp
    Public Class IntialEnd
        Implements IExtensionApplication
        Public Sub Initialize() Implements IExtensionApplication.Initialize
            Dim cnvrRib As New BottleConveyorRibbon
            cnvrRib.createRibbon()
            AddHandler cadApp.SystemVariableChanged, AddressOf cnvrRib.TrapWSCurrentChange
        End Sub
        Public Sub Terminate() Implements IExtensionApplication.Terminate
        End Sub
    End Class
End Namespace
vegbruiser
« Reply #7 on: February 28, 2011, 11:21:01 AM »
So, from your last post; what isn't working as expected?
deathman20
« Reply #8 on: February 28, 2011, 11:32:12 AM »
It loads, but...  I have to click the (first image) workspace for it to pop up.
(Second image) this is what it shows up on loading autocad
(Third image) this is what it looks like after I click the workspace button and load or reload a workspace
It can be any workspace but you have to click one for it to show.  As well it defaults as it should to the ribbon tab as it should, as done when manually loading it.
vegbruiser
« Reply #9 on: February 28, 2011, 11:57:36 AM »
From your description and the screenshots, it seems like it's working as designed - i.e. Your Ribbon Bar is only created when you click the Workspace button which fires the "SystemVariableChangedEvent" the TrapWSCurrentChange() method is looking for.
I'd suggest you rethink how/when your add-in is loaded - unless you only need it in a specific workspace; which as far as I can tell from your code isn't the case? You're not filtering for a specific workspace name, only whether the current workspace has changed?!
deathman20
« Reply #10 on: February 28, 2011, 01:22:19 PM »
Yeah noticing that now.  I'd like it to load on startup of autocad like everything else without any interaction.
Right now deploying it via a executable file, just for ease of doing so.  Figured the registry method would of been the best for this, and hopefully some tweaking of the code will fix it.
Glenn R
« Reply #11 on: February 28, 2011, 03:07:50 PM »
There is a sysvar called 'WSCURRENT' if I remember correctly - maybe that needs setting in an acad/acaddoc.lsp startup file? I'm only guessing as i haven't touched ribbon stuff before.
vegbruiser
« Reply #12 on: March 01, 2011, 04:08:15 AM »
Thanks Glenn,
The "WSCURRENT" sysvar is what the TrapWSCurrentChange() routine is watching and when it's value changes that's when the Ribbon Bar is loaded.
I think targeting a specific workspace is the way forward, but I don't know of a solution to that..
Glenn R
« Reply #13 on: March 01, 2011, 05:03:20 AM »
Whoops! Sorry about that - I was only skimming through the thread.
vegbruiser
« Reply #14 on: March 01, 2011, 05:51:36 AM »
Hey, No worries Glenn!
At least it proves that I understand what he's trying to do.. Which makes a nice change. :)
