Apparently I knew about it back in R13 because I set it to 2 back then and haven't loooked at it since. (found it in my stuff)
Also, I've just discovered that setting it above two does weird things with dialog boxes in lisp for older commands. Set at 2, (command ".array" ......) will function at the command line like it did prior to dialog box version. Setting QAFLAGS to 3 or 5 and (command ".array" ......) will call the dialog box. I've repaired the older lisp functions to now include the dash, but with QAFLAGS set to 2 they worked just fine for a couple of decades.
"velly interestink ... but silly"
