Author Topic: XREF multiple files at one time  (Read 4744 times)
CADaver
« on: January 18, 2005, 11:52:51 AM »
Before I burn a lot of time, does anyone (Yo, CAB?) have a lisp routine or something that will XREF overlay a bunch of files at once?
whdjr
« Reply #1 on: January 18, 2005, 12:27:42 PM »
;;;Created by Will DeLoach
;;;Description:
;;;Does a multiple attach of selected dwg's.
;;;Usage:
;;;From the dialog box select a dwg and then click on open.
;;;Keep doing this procedure until you have selected all the
;;;files you want to attach, then click cancel to continue with
;;;the attaching of the xref's.
;;;The routine can be modified for insertion point, scale, and
;;;rotation respectively by changing the 3 pause commands.
(defun c:mxattach (/ file files)
  (setq file "")
  (while (setq file (getfiled "Select a file to xref" file "dwg" 128))
    (setq files (cons file files))
  (foreach f (reverse files)
    (vl-bb-set 'name (vl-filename-base f))
    (if (vl-cmdf "-xref" "attach" (vl-bb-ref 'name))
      (command pause pause pause)
This is one I wrote, but it requires alot of user input and it doesn't currently attach overlay. You can change it however you need to or just holler and I will.
HTH,
AfricaAD
« Reply #2 on: January 18, 2005, 01:39:53 PM »
Do a google search for Xtools.
CADaver
« Reply #3 on: January 18, 2005, 02:27:30 PM »
Quote from: AfricaAD
I did, now what??
whdjr
« Reply #4 on: January 18, 2005, 02:40:36 PM »
How are you planning on implementing this?
Are each of your xrefs the same scale or location?
Do you want to select all the files in a folder?
I can make any or all of these options as well as changing from "attach" to "overlay".
Just say the word and give directions.
« Reply #5 on: January 18, 2005, 02:56:46 PM »
Will,
I modified your code so you could attach files ouside the root dir as well.
(defun c:mx (/ file files)
  (setq file "")
    (vl-bb-set 'name (strcat (vl-filename-directory f) "\\" (vl-filename-base f)))
Ron
CADaver
« Reply #7 on: January 18, 2005, 03:29:47 PM »
Thanks AfricaAD, I'll look into it.
Will, I did something similar to what Ron did, but added the insertion point at 0,0,0 and the scales are 1 with a 0 rotation:
  (setq file "")
    (if (vl-cmdf "-xref" "overlay" (vl-bb-ref 'name))
      (command "*0,0,0" "1" "1" "0")
This works pretty well, thanks, I was just hoping to select a range of files with a shift or ctrl, but this works just fine for now.
whdjr
« Reply #8 on: January 18, 2005, 03:49:47 PM »
Quote from: CADaver
ctrl
Unfortunately that is a downside to lisp.  I have been bummed out on this for a while now.
I also have a tool that will search a folder and/or all sub-folders for a string in a filename.  It uses wcmatch selection with wildcards and all.  I will post it if you would like to use it.  It does however require that "acetutil" be loaded from the expresstools..
ELOQUINTET
« Reply #9 on: January 18, 2005, 03:59:34 PM »
there might be something that might do what you want in the latest installment from cadalyst but i didn't try it might wanna check it out
ELOQUINTET
« Reply #10 on: January 18, 2005, 04:01:10 PM »
here try this like i say haven't tried it meself
;;;CADALYST 01/05 Tip2009:  mxrefi.lsp       Multiple Xref       (c) 2005 Leonid Nemirovsky
;; BTN by Leonid Nemirovsky                       2004
(defun c:mxrefi (/ dir pt typ scl ang file lista)
(setq dir (getstring T "X-Ref's Location<Current Folder>: "))
(setq pt (getpoint "\nSelect or Type Insertion Point<0,0>: "))
(if (= pt nil)(setq pt "0,0"))
(initget 1 "Overlay Attach")
(setq typ (getkword "Overlay or Attach <O or A>: "))
(setq scl (getreal "\nScale <1>: "))
(if (= scl nil)(setq scl 1))
(setq ang (getreal "\nRotation Angle<0>: "))
(if (= ang nil)(setq ang 0))
(setq file (getfiled "X-Ref's to attach" dir "dwg" 0))
(command"xref" typ file pt scl scl ang)
(setq lista (list file))
(while
  (setq lista (append (list  file) lista))
CADaver
« Reply #11 on: January 18, 2005, 06:29:03 PM »
I found that one in Cadalyst during lunch, but it's not nearly as good as the one Will posted here already.
The one from XTOOLS, posted by AfricaAD, does exactly what I want, but it has some overhead I need to trim away.
Thanks folks, I appreciate the help.
AfricaAD
« Reply #12 on: January 19, 2005, 12:11:34 PM »
I actually used it for the xref text file export. Since it included everything else, I kept it & use it religiously.
I modified mine a little. I would like to however allow multiple selection in CAD not in the dialogue. Just remember, it requires doslib & it comes with doslib2k. Also, there is 1 command that doesn't work (XM) which requires an outside app.
CADaver
« Reply #13 on: January 19, 2005, 12:38:06 PM »
That's my only problem with the routine, I've been stung in the past by relying on software that becomes unsupported later.
I noticed that too, I wonder what's up with that.
AfricaAD
« Reply #14 on: January 19, 2005, 12:43:07 PM »
From what I noticed, I think doslib is only required for the xref name export to text file & to xref files from a text file (which is a pretty good function).
