Author Topic: shortening a lisp quick question  (Read 3244 times)
diarmuid
« on: February 18, 2011, 06:44:49 AM »
Hi Guys, quick question:
Is there a shorter way of writing this?
(if (or(tblsearch "block" "M-STagLin01")
        (tblsearch "block" "M-STagLin02")
        (tblsearch "block" "M-STagLin03")
        (tblsearch "block" "M-STagLin04"))
            (Alert  (strcat "\nIncorrect Line-tag line in use in this P&ID. Please repair "
                           "\nthe drawing using the Button utility provided. Should you"
                    "\nrequire assisatance please contact tech-ops.")
If you want to win something run the 100m, if you want to experience something run a marathon
ElpanovEvgeniy
  • Moscow (Russia)
Re: shortening a lisp quick question
« Reply #1 on: February 18, 2011, 07:02:07 AM »
(and (vl-some '(lambda (a) (tblsearch "block" (strcat "M-STagLin0" a))) '("1" "2" "3" "4"))
            ) ;_  strcat
     ) ;_  Alert
Pepe
« Reply #2 on: February 18, 2011, 07:04:52 AM »
Maybe this?
(if (vl-some '(lambda (x) (tblsearch "BLOCK" x)) '("M-STagLin01" "M-STagLin02" "M-STagLin03" "M-STagLin04"))
  (Alert "\nIncorrect Line-tag line in use in this P&ID. Please repair\nthe drawing using the Button utility provided. Should you\nrequire assisatance please contact tech-ops.")
Slainte!
« Reply #3 on: February 18, 2011, 04:31:04 PM »
I would roll my own table search function where you could supply a list of names to search for, and either return after it finds one, or have it return an associate list, with the names found, and the block definition entity.
With each ' tblsearch ' call, you are stepping though all block definitions ( or all until the one is found ), and since you might call it multiple times, that is a slow way to do it.
« Reply #4 on: February 18, 2011, 04:50:58 PM »
What about using tblobjname?
dgorsman
« Reply #5 on: February 18, 2011, 05:10:42 PM »
Calling (vla-Item...) on the Blocks collection might be an acceptable substitute (with the (vl-catch-all-apply...) wrappings of course).
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Pepe
« Reply #6 on: February 24, 2011, 05:15:47 AM »
Evgeny:
I didn't see your reply before I posted mine (same ways, but different).
Only a question about (just to improve myself): Why AND instead IF  :? ? (I suppose it's in order to avoid an ELSE, but it could have it's own logic...)
Thanks in advance.
diarmuid
« Reply #7 on: February 24, 2011, 05:24:05 AM »
Thanks for all of the input Guys
go raibh maith agat
diarmuid
« Reply #8 on: February 24, 2011, 10:46:36 AM »
Thanks for the help,
The reason i was getting the help window appearing was my code showed:
(command "explode" "l" "")
This was incorrect, the extra "" at the end was not needed. (sure when you type out the command you need an extra "enter" to exit the comment, but from inside a lisp you dont when you select "last".
Regards
Diarmuid
diarmuid
« Reply #9 on: February 24, 2011, 11:09:25 AM »
Sorry guys, wrong topic, ive posted it to the correct topic
 :lol:
chlh_jd
« Reply #10 on: February 26, 2011, 11:36:43 AM »
just Readily
(if (vl-some '(lambda (x) (tblsearch "BLOCK" (strcat "M-STagLin0" x)))
     '("1" "2" "3" "4")
  (Alert
« Last Edit: February 26, 2011, 11:54:42 AM by chlh_jd »
chlh_jd
« Reply #11 on: February 26, 2011, 11:38:17 AM »
oh Evgeniy  & Pepe has Provided the shorten  :?
« Last Edit: February 26, 2011, 11:55:09 AM by chlh_jd »
