Author Topic: getting attributes of a DB using LISP  (Read 1303 times)
soory
« on: February 08, 2011, 11:48:39 AM »
I'm trying to write my first code to insert a DB and get attributes of it. I wrote this:
(defun c:abcd (/ p1 blkname en eo dblist dbprops)
(setq blkname "prac2")
(setq p1 (getpoint "\ninsert piont:"))
(command "insert"
BlkName
1.0
1.0
1.0
0.0
(setq en (entsel "\nselect block:"))
(setq eo (vlax-ename->vla-object (car en)))
(setq dblist (vlax-invoke eo 'GetDynamicBlockProperties))
The block inserted properly but getting attributes does not go through.
Any help would be appriciated.
<edit: CAB - code tags added>
« Last Edit: February 08, 2011, 12:55:01 PM by CAB »
Re: getting attributes of a DB using LISP
« Reply #1 on: February 08, 2011, 12:56:33 PM »
Welcome to the Swamp.  8-)
alanjt
  • Standby for witty remark...
« Reply #2 on: February 08, 2011, 01:07:11 PM »
(vlax-invoke (vlax-ename->vla-object (car (entsel))) 'GetAttributes)
Dropbox
