Author Topic: Font file issues  (Read 10748 times)
Re: Font file issues
« Reply #15 on: February 08, 2011, 05:33:59 PM »
What error do you get, if any?
Thanks to Lee, again.
Here is what I got:
#<VLA-OBJECT IAcadTextStyle 000000002b774a68>
Sorry, that is not an error - that is the TextStyle object, indicating that the code has succeeded.
MeasureUp
« Reply #16 on: February 08, 2011, 06:33:07 PM »
Thanks Lee.
I will come back to your reply.
MeasureUp
« Reply #17 on: February 08, 2011, 06:46:11 PM »
How to improve the filter to show only "arial.ttf" if it exists?
Now I modify this line:
(_filter (GetTTFs) "*ARIAL*")
to
(_filter (GetTTFs) "Arial (TrueType)")
It looks fine.
It returns:
(("Arial (TrueType)" . "arial.ttf"))
Am I right?
The next question is how to subtract the "arial.ttf" from above line?
Then I can write something like:
(setq ArialFont ...)  ;[color=red]need help in this line[/color]
(if (eq ArialFont "arial.ttf")
DoSomethingHere
« Last Edit: February 08, 2011, 06:50:02 PM by MeasureUp »
alanjt
  • Standby for witty remark...
« Reply #18 on: February 08, 2011, 07:22:36 PM »
(cdr <List>)
But I don't understand the point of what you're trying to accomplish. You aren't wanting a list, you are wanting one particular font, but you are basically getting out what you are putting into the sub.
Dropbox
MeasureUp
« Reply #19 on: February 08, 2011, 07:37:39 PM »
(cdr <List>)
Thanks Alan, again.
I am going to create a new text style & this is alright to me.
But I found the problem which the font file name has been changed & the code return an error message, as I mensioned before.
So I want to do something like this:
1) Check if the normal font name exists in the windows registry.
2) If the font is found, then create the text style, otherwise give user a warning message.
« Reply #20 on: February 08, 2011, 07:40:29 PM »
Updated mine to give a 'warning message':
(defun CreateTextStyle ( style font / result fontfile )
  (defun _GetSpecialFolder ( name / wshShell specialFolders result )
    ; MP
    (vl-catch-all-apply
       '(lambda (  )
            (setq
                wshShell       (vlax-create-object "WScript.Shell")
                specialFolders (vlax-get wshShell 'SpecialFolders)
                result         (vlax-invoke specialFolders 'Item name)
    (if specialFolders (vlax-release-object specialFolders))
    (if wshShell (vlax-release-object wshShell))
    result
  (if (setq fontfile (findfile (strcat (_GetSpecialFolder "Fonts") "\\" font)))
    (vla-put-Fontfile
      (setq result
        (vla-Add
          (vla-get-TextStyles
            (vla-get-ActiveDocument (vlax-get-acad-object))
          style
      fontfile
    (princ (strcat "\n** " font " not found **"))
[ I still think a nil return was better... ]
alanjt
« Reply #21 on: February 08, 2011, 07:45:34 PM »
(cdr <List>)
Thanks Alan, again.
This might be better (untested)...
(defun doesTTFexist (ttf)
  ((lambda (reg ttf)
     (vl-some (function (lambda (x / n) (if (eq (setq n (vl-registry-read reg x)) ttf) n)))
              (vl-registry-descendents reg "")
    "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\Fonts"
    (strcase ttf)
eg.
(doesTTFexist "ARIAL.TTF")
ditto
Dropbox
MeasureUp
« Reply #22 on: February 08, 2011, 08:15:15 PM »
Thanks, Alan.
ditto
I need to think again.
alanjt
« Reply #23 on: February 08, 2011, 08:16:41 PM »
Dropbox
MeasureUp
« Reply #24 on: February 08, 2011, 08:18:32 PM »
Here is what I got:
Thanks, Lee.
How to get the font file name at this point?
« Reply #25 on: February 08, 2011, 08:20:40 PM »
Here is what I got:
Thanks, Lee.
The font file has already been assigned to the TextStyle at that point (using vla-put-fontfile in the code) - if you check the newly created TextStyle after running the code, is the Font assigned correctly?
This line:
Constructs the FontFile path.
MeasureUp
« Reply #26 on: February 08, 2011, 08:50:39 PM »
Thanks, Lee.
MeasureUp
« Reply #27 on: February 08, 2011, 08:59:41 PM »
  ((lambda (reg ttf)
    (strcase ttf)
eg.
(doesTTFexist "ARIAL.TTF")...
Now the "arial.ttf" exists in registry.
But when I paste this line to command line it returns "nil".
Did I miss something?
alanjt
« Reply #28 on: February 08, 2011, 09:13:48 PM »
  ((lambda (reg ttf)
    (strcase ttf)
eg.
Only that I said it was untested. ATM, I don't have AutoCAD on my home machine.
Dropbox
MeasureUp
« Reply #29 on: February 08, 2011, 11:39:47 PM »
I tried again. I can't figure it out.
Could you please check it when you are at work?
Thanks.
