Author Topic: SDS Programming  (Read 4968 times)
ramkumar
SDS Programming
« on: February 03, 2011, 06:22:04 AM »
Hi all,
Can any one help me out to make my first Application on intellicad using SDS with C++.
Thanks,
Kumar.
It's Alive!
  • BricsCAD
  • AKA Daniel
Re: SDS Programming
« Reply #1 on: February 03, 2011, 08:30:29 AM »
Welcome to the swamp!
I think there are a few samples laying around, are you doing Intellicad?
ramkumar
Re: SDS Programming
« Reply #2 on: February 03, 2011, 10:53:34 PM »
Yes I am doing intellicad.
To make my routines faster i want to step in to SDS from lisp.
But I am not getting good tutorial where to start.
« Last Edit: February 04, 2011, 12:36:50 AM by ramkumar »
It's Alive!
  • BricsCAD
  • AKA Daniel
Re: SDS Programming
« Reply #3 on: February 04, 2011, 12:07:31 PM »
Start here...
http://www.engr.uvic.ca/~mech410/ACAD_and_C/ads_tutorials.html
it's a bit dated but it will get you started, just switch the ADS prefix with SDS.
post if you have questions along the way.
ramkumar
Re: SDS Programming
« Reply #4 on: February 07, 2011, 10:01:53 AM »
HI,
Thanks for the link.
I seems good. I will go through this and back with questions (if any).
Kumar. :lol:
ramkumar
Re: SDS Programming
« Reply #5 on: February 25, 2011, 12:21:27 AM »
I wrote my first program in sds successfully.
I am able to write functions that return values.
But i am not clear how to pass arguments to the sds functions and how to use the those in program.
all my functions are working when i used like this
static int Ess_chkdir(struct sds_resbuf *rb)
if i pass arguments in place of sds_resbuf, my function getting error.
Is there a way to pass arguments through the result buffer and grab those values & use in program.
Thanks,
Kumar.
It's Alive!
  • BricsCAD
  • AKA Daniel
Re: SDS Programming
« Reply #6 on: February 26, 2011, 01:15:41 AM »
How are you building/reading your resbuf?
ramkumar
Re: SDS Programming
« Reply #7 on: February 28, 2011, 04:03:12 AM »
I am not building any result buff here.
I am just using as shown below.
code here
Form your reply i understood that we need to build a result buff based on the arguments we need to pass.
If i am not wrong please tell me, how to build a result buff to read an entity and a point from lisp and use in sds programs.
Thanks,
Kumar.
ramkumar
Re: SDS Programming
« Reply #8 on: March 11, 2011, 03:00:32 AM »
Good news :lol:
I got a template for intellicad sds programming.
Just follow the test file in the attachment.
While creating a new project it will have an option for sds application.
It automatically creates dataentrypoint and main functions. You just need to write your command functions.
Cheers....
Kumar.
ramkumar
Re: SDS Programming
« Reply #9 on: March 11, 2011, 03:04:23 AM »
Sorry i have not mentioned about editor.
You need to use VC++ 6.0 editor to work intellicad wizard.
Thanks,
Kumar
