Author Topic: Weird LISP error - after loading, I get this error...help!!  (Read 4194 times)
kameron1967
« on: February 02, 2011, 11:33:20 AM »
Can anyone tell me why I'm getting this error on just a simple lisp?
Command: KA
Unknown command "F".  Press F1 for help.
Unknown command "*KEYPLAN|*PATT-*".  Press F1 for help.
Unknown command "KA".  Press F1 for help.
Unknown command "X*|S-GRID*MAT**".  Press F1 for help.
Unknown command "T".  Press F1 for help.
Unknown command "*KEYPLAN|*PATT-A".  Press F1 for help.
Unknown command "X*|S-GRID*MAT*-A".  Press F1 for help.
Unknown command "*KEYPLAN|*PATT-NOTE".  Press F1 for help.
THIS IS THE CODE FOR KA.LSP
(defun c:KA ()
 (command "layer" "f" "*keyplan|*patt-*" "")
 (command "layer" "f" "X*|s-grid*mat**" "")
 (command "layer" "T" "*keyplan|*patt-A" "")
 (command "layer" "T" "X*|s-grid*mat*-A" "")
 (command "layer" "T" "*keyplan|*patt-NOTE" "")
[\CODE]
Nibster
Re: Weird LISP error - after loading, I get this error...help!!
« Reply #1 on: February 02, 2011, 11:43:43 AM »
"-layer"
you forgot the hyphen, and you can shorten it up...
(defun c:KA ()
 (command "-layer"
« Last Edit: February 02, 2011, 11:47:58 AM by Nibster »
kameron1967
« Reply #2 on: February 02, 2011, 01:24:42 PM »
Quote from: HAWDesigner
Also, have you tried entering each line directly into the command line to see if you get the same error?
For instance:
Command: (command "layer" "f" "*keyplan|*patt-*" "")
This is what I got...
nil
Do you suppose the autocad utility is not being loaded..??  Like acaddoc.lsp, etc..??
Nibster
« Reply #3 on: February 02, 2011, 01:28:20 PM »
For instance:
nil
um, did you look at the post above this one that I am quoting?  :?
alanjt
  • Standby for witty remark...
« Reply #4 on: February 02, 2011, 01:29:57 PM »
(defun c:KA (/)
  (command "_.-layer" "_freeze" "*keyplan|*patt-*,X*|s-grid*mat*,*keyplan|*patt-A" "_thaw"
           "X*|s-grid*mat*-A,*keyplan|*patt-NOTE" ""
Dropbox
Nibster
« Reply #5 on: February 02, 2011, 01:35:07 PM »
(defun c:KA (/)
:roll: i would have gotten there eventually...  :wink:
alanjt
« Reply #6 on: February 02, 2011, 01:40:48 PM »
(defun c:KA (/)
I know. :)
VL option (runs transparently)...
(defun c:KA (/ name)
  (vlax-for x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
    (and (wcmatch (setq name (strcase (vla-get-name x)))
                  "*KEYPLAN|*PATT-*,X*|S-GRID*MAT*,*KEYPLAN|*PATT-A"
         (vla-put-freeze x :vlax-true)
    (and (wcmatch name "X*|S-GRID*MAT*-A,*KEYPLAN|*PATT-NOTE") (vla-put-freeze x :vlax-false))
Dropbox
« Reply #7 on: February 02, 2011, 01:45:20 PM »
Vanilla method :wink:
(defun c:ka ( / _FreezeThawLayer frzestring thawstring layerdef layer )
  (setq frzestring "*keyplan|*patt-*,X*|s-grid*mat*,*keyplan|*patt-A"
        thawstring "X*|s-grid*mat*-A,*keyplan|*patt-NOTE"
  (defun _FreezeThawLayer ( layer freeze )
    (if (setq layer (tblobjname "LAYER" layer))
      ( (lambda ( elist ) (entmod (subst (cons 70 (boole (if freeze 7 4) 1 (cdr (assoc 70 elist)))) (assoc 70 elist) elist)))
        (entget layer)
  (while (setq layerdef (tblnext "LAYER" (null layerdef)))
    (setq layer (cdr (assoc 2 layerdef)))
      ( (wcmatch layer frzestring)
        (_FreezeThawLayer layer t)
      ( (wcmatch layer thawstring)
        (_FreezeThawLayer layer nil)
kameron1967
« Reply #8 on: February 02, 2011, 01:51:09 PM »
Love it when the programming gurus get together.  Unfortunately, it has not solved my initial problem.  :lol:
kameron1967
« Reply #9 on: February 02, 2011, 01:54:26 PM »
Lee, so if I have sectors A-K, how I can do this in one routine - without copying over and over to make one for each sector?  Thanks!
        (entget layer)
Nibster
« Reply #10 on: February 02, 2011, 01:59:17 PM »
Love it when the programming gurus get together.  Unfortunately, it has not solved my initial problem:lol:
are you sure?  you asked about errors.  :-P
Command: KA
(defun c:KA ()
[\CODE]
alanjt
« Reply #11 on: February 02, 2011, 02:07:16 PM »
FYI: -Layer is not case sensitive, wcmatch is.
Dropbox
kameron1967
« Reply #12 on: February 02, 2011, 02:17:10 PM »
Nibster - you're right.  I did not try this.  The "-layer" does do the track.  But I've never had that problem before.  Could that be that the  "CMDDIA" needs to be set to "0" always, then?
"-layer"
(defun c:KA ()
 (command "-layer"
Nibster
« Reply #13 on: February 02, 2011, 02:31:24 PM »
"-layer"
(defun c:KA ()
 (command "-layer"
what was your previous ACAD version?
