Author Topic: Would like to ask some question about my code  (Read 1562 times)
cadman6735
« on: January 31, 2011, 05:47:36 PM »
I have some questions about my code.
(defun C:test ( / LayerBin)
  (setq
    acadObject (vlax-get-acad-object)
    acadActiveDocument (vla-get-ActiveDocument acadObject)
(setq
    acadLayers (vla-get-Layers acadActiveDocument)
  (vlax-for eachLockedLayer acadLayers
      (= (vla-get-Lock eachLockedLayer) :vlax-true)
(setq LayerBin (cons eachLockedLayer LayerBin))
(vla-put-Lock eachLockedLayer :vlax-false)
{work done here}
 (vlax-for eachLayer LayerBin
   (vla-put-Lock eachLayer :vlax-true)
The first (vlax-for) works just fine but the second one does not.  I guess my quesion is  "What is LayerBin in my second (vlax-for) statement?"
I am assuming that I need a sset to work with and in my case LayerBin is only a list (guessing), LayerBin is my container symbol so I can unlock all layers, work on the layer then lock them back when done.  The names are there in LayerBin so why will my second vlax-for statment not work.
Re: Would like to ask some question about my code
« Reply #1 on: January 31, 2011, 05:50:52 PM »
First, welcome the theSwamp.
LayerBin = a list created by you.
To work on a regular list, use ' foreach ' instead of ' vlax-for ', which is used to step through an ActriveX collection.
cadman6735
« Reply #2 on: January 31, 2011, 06:13:06 PM »
Thanks for welcoming, I am happy to be here.
LayerBin = list
Happy that I guessed right, frustrated that I have more work ahead of me.
with my new found knowledge, I will play with my code and see if I can't get it to do what I want it to do.
Thanks for the helping me.
cadman6735
« Reply #3 on: February 01, 2011, 09:57:28 AM »
t.willey
I was wrong, not much work ahead of me at all...  It worked great switching the vlax-for to foreach.  Took me about 2 hours to figure out that I do not have to change the ename to an object tho... :oops:
Anyway, learned a concept off of this one, thanks
Got another question:
Would LayerBin be considered a selection set?  Even though it is a list, it holds Layer names and I did not create it thru the conventional manner using selection set functions?
« Reply #4 on: February 01, 2011, 11:13:11 AM »
A selection set is a very specific variable type.  It is only achieved with ' ss ' something calls.  Ie ' ssget ' or ' ssadd '.  You are creating a list in your code, so that is what makes the ' LayerBin ' variable a list type.  If you want to see what type of variable you have, you can just print it to the command line in the middle of your code like:
(print (type LayerBin))
Hope that helps, and you're welcome.
cadman6735
« Reply #5 on: February 01, 2011, 11:36:41 AM »
As a selection set is a collection of elements, specified by the ss functions
my list, LayerBin, is a collection of layer names used to restore my layers after being worked on.
Though they are not the same thing in variable type, they are both a collection of something, either elements from a sset
or
Names from a layer table in list form.
Sorry for wording out my thoughts, just trying to grab a concept.
