Author Topic: Visual Studio as 64bit App.  (Read 2110 times)
SEANT
« on: January 30, 2011, 12:54:44 PM »
I suppose I should have first searched for this type of posting before I took a leap at the “bleeding edge”. :|
http://www.theswamp.org/index.php?topic=33419.0
Some early testing (and all subsequent web searches) reveals that VS.NET “Edit and Continue” is not available for 64bit code.   I don’t suppose something new has developed since that thread?
If that really isn’t available, was there some option I should have been paying attention to that allowed installing VS as a 32bit app?  Would that matter if I’m testing with 64bit AutoCAD?
Sean Tessier
AutoCAD 2016 Mechanical
Jeff H
Re: Visual Studio as 64bit App.
« Reply #1 on: January 30, 2011, 10:11:04 PM »
There is no version of VS2010 64 bit.
You can Edit & Continue on x64 computer  just not on x64 build
So if you need to have it must do a x86 build
SEANT
« Reply #2 on: January 31, 2011, 03:33:34 AM »
Interesting.  Visual Studio distributes the install into both Program Files and Program Files(X86).  There has been so much software installed over the past couple of days that it will take a month to get reacquainted.
As it stands now I’m still using VS 2008 but plan to make a switch to VS2010 soon.  It would have been sooner if something new had materialized along this debugging front.
I’ll have to experiment further to see the best overall workflow.    I do have a laptop with everything setup still as 32bit.
Sean Tessier
