Author Topic: {Challenge} for {Challenges}  (Read 1814 times)
Jeff H
« on: January 28, 2011, 08:38:54 PM »
I understand this section of the forum is geared toward the AutoCAD API, but wanted to get your ideas about doing some challenges
There are alot of extremely smart people who hang out here and thought not only can we all learn from their knowledge of the API, but also learn how they would solve a problem.
I read alot of your post's and wish I could ask you a 1000 questions, but maybe seeing how you solve a problem would not be as annoying.
Was wondering if any you thought it would be a good idea to start doing some challenges?
If it is not AutoCAD oriented would it be better to do it in the General Programming forum?
I got alot to learn and thought this would help.
Re: {Challenge} for {Challenges}
« Reply #1 on: January 28, 2011, 08:48:12 PM »
That sounds like a great idea Jeff ....
This forum would probably be best ie ".NET"
Probably a good idea to make it plain in the first post which API is the intended Target.
... the target range is expanding regularly :)
I probably have more to learn than I can contribute but would enjoy participating as time allows.
