Author Topic: How to trsanslate mns to cui  (Read 9308 times)
xiaxiang
« on: January 28, 2011, 01:27:49 AM »
I just ask a question---who can trsanslate file mns to cui? or  there is some software to do this automatic,maybe ^-^
post a sample, and I hope to get the answer.
Thank you :-)
Re: How to trsanslate mns to cui
« Reply #1 on: January 28, 2011, 03:19:44 AM »
At the AutoCAD Commandline enter MENULOAD
Select the .MNS file you want to load
The .CUI or CUIX will be created depending on your AutoCAD version.
at the AutoCAD Commandline enter MENULOAD
Unload the Menu.
xiaxiang
« Reply #2 on: January 28, 2011, 04:56:00 AM »
When I Select the .MNS file that want to load ,some error appeared
,and I couldn't  tansfer it to cui
« Reply #3 on: January 28, 2011, 05:12:37 AM »
What Version are you using ??
Loadiing a .MNS works for me in ACADM2011
I recall it worked in previous versions as well
Attached is a piccy ..
Crank
« Reply #4 on: January 28, 2011, 07:11:41 AM »
Here you go.
xiaxiang
« Reply #5 on: January 29, 2011, 03:07:58 AM »
I use acad2006,and I couldn't do that like your animation?
What can I do?
xiaxiang
« Reply #6 on: January 29, 2011, 03:14:10 AM »
Here you go.
Thank you Crank! 8-)
And how to do this like your sample? Maybe manually?Or can you show me the way to translate?
I can not see the Chinese character
« Reply #7 on: January 29, 2011, 03:16:40 AM »
What can I do?
I don't know a solution for you.
Mine looks like the attached, I imagine the CUI posted by Crank looksa the same.
Crank
« Reply #8 on: January 29, 2011, 06:20:11 AM »
Yes, my version looks the same. I compiled the .mns in an english version of Acad2008, but I think the .cui should also work in 2006.
If the steps from Kerry don't work for you, there must be a bug in the Chinese version of 2006 or your installation is corrupt.
xiaxiang
« Reply #9 on: January 29, 2011, 08:09:45 AM »
I think that I should compile the .mns in an chinese version of Acad2008.Thank you ,kerry and Crank!
HasanCAD
« Reply #10 on: May 18, 2011, 04:09:56 AM »
See attached
xiaxiang
« Reply #11 on: May 22, 2011, 08:54:14 PM »
See attached
Thanks Hasan.I've got it :-)
