Try it
Test1 - change the layer of polylines that do not have the text inside, at NO-HAVE-TEXT
Test2 - add hatch to this polyline
(defun C:TEST1 ( / ss textlist pllist)
;;;Move polyline to layer NO-HAVE-TEXT
(setq ss (ssget "_X" (list '(0 . "TEXT")(cons 410 (getvar "CTAB")))))
(setq textlist (pickset-to-list ss)) ;_List of text
(setq ss (ssget "_X" (list '(0 . "LWPOLYLINE")(cons 410 (getvar "CTAB")))))
(setq pllist (pickset-to-list ss));_list of boundary
(foreach pl (vl-remove-if-not '(lambda(x)(Is-none-text-inside-polyline x textlist)) pllist)
(entmod (subst (cons 8 "NO-HAVE-TEXT")(assoc 8 (entget pl))(entget pl)))
(defun C:TEST2 ( / ss textlist pllist)
;;;Add hatch
;; Pat - pattern
;; L - list point
;; A - angle hatch
;; N - name pattern
;; S - scale
(entmakex-hatch
(list(massoc 10 (entget pl))) ;_list point
0 ;_Angle hatch
"ANSI31" ;_Name Pattern
1 ;_Scale
(defun Is-none-text-inside-polyline ( polyline textlist / boundary)
;;;Return T if polyline not have text inside
(setq boundary (massoc 10 (entget polyline)))
(apply 'and
(mapcar '(lambda ( text )
(if (In_Figure (cdr(assoc 10 (entget text))) boundary)
nil
polyline
textlist
(defun massoc (key alist)
(mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= key (car x)))) alist)))
(defun pickset-to-list (ss / item lst)
(repeat (setq item (sslength ss)) ;_ end setq
(setq lst (cons (ssname ss (setq item (1- item))) lst))
) ;_ end repeat
lst
) ;_ end of defun
(defun entmakex-hatch (L a n s)
;; By ElpanovEvgeniy
;; L - list of list point
;; A - angle hatch
;; N - name pattern
;; S - scale
;; returne - hatch ename
(entmakex
(apply
'append
(list
(list '(0 . "HATCH")
'(100 . "AcDbEntity")
'(410 . "Model")
'(100 . "AcDbHatch")
'(10 0.0 0.0 0.0)
'(210 0.0 0.0 1.0)
(cons 2 n)
(if (= n "SOLID")
'(70 . 1)
'(70 . 0)
) ;_ if
'(71 . 0)
(cons 91 (length l))
) ;_ list
(apply 'append
(mapcar '(lambda (a)
(apply 'append
(list (list '(92 . 7) '(72 . 0) '(73 . 1) (cons 93 (length a)))
(mapcar '(lambda (b) (cons 10 b)) a)
'((97 . 0))
) ;_ list
) ;_ apply
) ;_ lambda
l
) ;_ mapcar
) ;_ apply
(list '(75 . 0)
'(76 . 1)
(cons 52 a)
(cons 41 s)
'(77 . 0)
'(78 . 1)
(cons 53 a)
'(43 . 0.)
'(44 . 0.)
'(45 . 1.)
'(46 . 1.)
'(79 . 0)
'(47 . 1.)
'(98 . 2)
'(10 0. 0. 0.0)
'(10 0. 0. 0.0)
'(451 . 0)
'(460 . 0.0)
'(461 . 0.0)
'(452 . 1)
'(462 . 1.0)
'(453 . 2)
'(463 . 0.0)
'(463 . 1.0)
'(470 . "LINEAR")
) ;_ list
) ;_ list
) ;_ apply
) ;_ entmakex
) ;_ defun
(defun In_Figure (Point Boundary / FarPoint Check)
;_Проверяет Boundary на условие car и last одна и та же точка
(if (not (equal (car Boundary) (last Boundary) 1e-6))
(setq Boundary (append Boundary (list (car Boundary))))
) ;_ end of if
(setq FarPoint (cons (+ (apply 'max (mapcar 'car Boundary)) 1.0)
(cdr Point)
) ;_ end of cons
) ;_ end of setq
(or
(not
(zerop
(rem
(length
(vl-remove
nil
(mapcar
(function
(lambda (p1 p2) (inters Point FarPoint p1 p2))
) ;_ end of function
Boundary
(cdr Boundary)
) ;_ end of mapcar
) ;_ end of vl-remove
) ;_ end of length
2
) ;_ end of rem
) ;_ end of zerop
) ;_ end of not
(vl-some (function (lambda (x) x))
(mapcar
(function (lambda (p1 p2)
(or Check
(if (equal (+ (distance Point p1)
(distance Point p2)
) ;_ end of +
(distance p1 p2)
1e-3
) ;_ end of equal
(setq Check t)
nil
) ;_ end of if
) ;_ end of or
) ;_ end of lambda
Boundary
(cdr Boundary)
) ;_ end of mapcar
) ;_ end of vl-some
) ;_ end of or
many thanks again it has worked perfectly
it took aproximately 50 minutes to execute but all went well!
Don't know how to thank you enough
By the way your function to check if a point is inside a polyline is helping me a lot in another routine I wanted to write.
I got the function from another page but didn't remember where from.
thanks a lot for your work, I'm gratefull
