Author Topic: How can I stop my application, from a method?  (Read 2007 times)
teslaxx
« on: January 26, 2011, 05:28:16 AM »
So, how can I exit my application, from a method?  :)
[CommandMethod("myApp")]
public static void Kilometreaza54()
    sub();
private static void sub()
   // here I want to stop my application in Autocad
Jeff H
Re: How can I stop my application, from a method?
« Reply #1 on: January 26, 2011, 05:44:11 AM »
This is one way, but probably a better way
            sub();
            Autodesk.AutoCAD.ApplicationServices.Application.Quit();
dan.glassman
« Reply #2 on: January 26, 2011, 01:32:04 PM »
Your application is a separate .exe outside AutoCAD?
Look into System.Diagnostics.Process
Something like...
Process[] myRunningApps = Process.GetProcessByName("myapplicationname");
foreach (Process p in myRunningApps)
   if (p.HasExited) continue;
   if (p.CloseMainWindow())
      p.Close()
   else
      try
         p.Kill()
      catch
         // meh
-drg
