Author Topic: Find duplicate points  (Read 15624 times)
dann.boy.001
Re: Find duplicate points
« Reply #15 on: January 26, 2011, 07:05:15 AM »
Thank you very much guys  :wink:!!!
Tonight I will test it... Seems problem solved  :-)
Best regards
Danijel
gile
  • Marseille, France
« Reply #16 on: January 29, 2011, 10:44:25 AM »
Here's a F# solution which seems to be very much faster on big collections than the C# solutions i gave before.
type Point3dComparer(pt : Point3d, tol) =
    member this.Pt = pt
    member this.Equals(tPt : Point3dComparer) = this.Pt.IsEqualTo(tPt.Pt, tol)
let removeDuplicate pts tol =
    new Point3dCollection(
        pts
        |> Seq.cast
        |> Seq.distinctBy (fun p -> new Point3dComparer(p, tol))
        |> Seq.toArray)
gile
  • Marseille, France
« Reply #17 on: January 29, 2011, 11:11:14 AM »
I ran some little benchs using 100 random points.dwg
RemoveDuplicate(sorted List)
Removed 2 duplicate in a 10000 items collection
Ellapsed milliseconds : 9.0005
RemoveDuplicate2 (override Contains)
Ellapsed milliseconds : 9766.5586
removeDuplicate (F#)
Ellapsed milliseconds : 7.0004
Removed 383 duplicate in a 10381 items collection
Ellapsed milliseconds : 231.0133
Ellapsed milliseconds : 9677.5535
Ellapsed milliseconds : 6.0004
Removed 4378 duplicate in a 14376 items collection
Ellapsed milliseconds : 2150.123
Ellapsed milliseconds : 9665.5528
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: January 29, 2011, 12:29:41 PM »
how does this compare?
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
#endregion
[assembly: CommandClass(typeof(ExecMethod.Commands))]
namespace ExecMethod
  public class Point3dComparer : IEqualityComparer<Point3d>
    Tolerance m_tol;
    public Point3dComparer(Tolerance tol)
      m_tol = tol;
    public bool Equals(Point3d a, Point3d b)
      return a.IsEqualTo(b, m_tol);
    public int GetHashCode(Point3d pnt)
      return (pnt.X.GetHashCode() ^ pnt.Y.GetHashCode() ^ pnt.Z.GetHashCode());
  public class Commands
    [CommandMethod("doit")]
    public void doit()
      List<Point3d> pointsList = new List<Point3d>();
      Document doc = AcAp.Application.DocumentManager.MdiActiveDocument;
      Database db = AcDb.HostApplicationServices.WorkingDatabase;
      Editor ed = doc.Editor;
      AcDb.TransactionManager tm = doc.TransactionManager;
      using (Transaction tr = tm.StartTransaction())
        BlockTableRecord btr = tr.GetObject
          (db.CurrentSpaceId, OpenMode.ForRead, false) as BlockTableRecord;
        foreach (ObjectId id in btr)
          DBPoint dbpoint = tr.GetObject(id, OpenMode.ForRead, false) as DBPoint;
          if (dbpoint != null)
            pointsList.Add(dbpoint.Position);
        tr.Commit();
        Tolerance tol = new Tolerance();
        var hash = new HashSet<Point3d>(pointsList, new Point3dComparer(tol));
        ed.WriteMessage("{0}-{1}", pointsList.Count, hash.Count);
« Last Edit: January 29, 2011, 12:49:07 PM by __assume »
gile
  • Marseille, France
« Reply #19 on: January 29, 2011, 01:23:18 PM »
Nice trick Dan  8-)
It seems to be a little faster than my F#code (but very closed to).
I didn't know the HashSet class, one more time, thank you to teatch me a new thing.
Here're the method and the class I used (each other method requires an returns a Point3dCollection).
        private Point3dCollection DanRemDup(Point3dCollection pts, Tolerance tol)
            Point3dCollection result = new Point3dCollection();
            Point3d[] ptArr = new Point3d[pts.Count];
            pts.CopyTo(ptArr, 0);
            HashSet<Point3d> hash = new HashSet<Point3d>(ptArr, new Point3dComparer(tol));
            foreach (Point3d p in hash)
                result.Add(p);
            return result;
            private Tolerance _tol;
            public Point3dComparer()
                _tol = Tolerance.Global;
                _tol = tol;
                return a.IsEqualTo(b, _tol);
« Last Edit: January 29, 2011, 01:36:37 PM by gile »
kaefer
« Reply #20 on: January 29, 2011, 01:53:47 PM »
Nice trick Dan
Sorry, boys, it's still slower than Linq's Distinct<T>(IEqualityComparer) extension, at least around here...
... and when there's a real Tolerance involved, other than 0.0 or Double.Epsilon. I have the nagging suspicion that this kind of HashCode calculation doesn't quite work in our scenario; it will gladly let false negatives pass, when the delta is actually below the threshold but the coordinates are sufficiently different.
BTW, in F# there's a helper to create an IEqualityComparer from lambdas, very fast it is not.
   let myEqualityComparer =
        HashIdentity.FromFunctions
            (fun _ -> 0)
            (fun (a: Point3d) b -> a.IsEqualTo(b, new Tolerance(eps, eps)))
Cheers, Thorsten
kaefer
« Reply #21 on: January 29, 2011, 06:26:50 PM »
Here's my data for "100 random point.dwg" with Tolerance(1, 1) :
DistinctHashSet
Found 2 duplicate(s) in a 10000 items collection.
Elapsed milliseconds : 5150.0162
DistinctEnumerable
Elapsed milliseconds : 3502.6673
Sure, setting the HashCode to 0 is cheating, as is the creation of a sequence where the Current property is never touched.
   public class MyEqualityComparer : IEqualityComparer<Point3d>
        Tolerance m_tol;
        public MyEqualityComparer(Tolerance tol)
            m_tol = tol;
            return 0;
        [CommandMethod("DistinctEnumerable")]
        public void DistinctEnumerable() { cmd("DistinctEnumerable"); }
        [CommandMethod("DistinctHashSet")]
        public void DistinctHashSet() { cmd("DistinctHashSet"); }
        private void cmd(string what)
            Editor ed = acApp.DocumentManager.MdiActiveDocument.Editor;
            PromptDoubleResult pdr = ed.GetDouble("Tolerance: ");
            if (pdr.Status != PromptStatus.OK) return;
            SelectionFilter sf = new SelectionFilter(new TypedValue[] { new TypedValue((int)DxfCode.Start, "POINT") });
            PromptSelectionResult psr = ed.GetSelection(sf);
            if (psr.Status != PromptStatus.OK) return;
            int numin, numout;
            long ticks;
            dupPts(what, pdr.Value, psr.Value, out numin, out numout, out ticks);
            ed.WriteMessage(
                "\n{0} " +
                "\nFound {1} duplicate(s) in a {2} items collection. " +
                "\nElapsed milliseconds : {3} ",
                what,
                numin - numout,
                numin,
                (double)ticks / (double)TimeSpan.TicksPerMillisecond);
        private void dupPts(string what, double eps, SelectionSet sset, out int numin, out int numout, out long ticks)
            Database db = acApp.DocumentManager.MdiActiveDocument.Database;
                Point3dCollection pts = new Point3dCollection();
                foreach (SelectedObject so in sset)
                    DBPoint dbp = (DBPoint)tr.GetObject(so.ObjectId, OpenMode.ForRead);
                    pts.Add(dbp.Position);
                Tolerance tol = new Tolerance(eps, eps);
                numin = pts.Count;
                Stopwatch sw = Stopwatch.StartNew();
                if (what == "DistinctEnumerable")
                    IEnumerable<Point3d> enumerable = pts.Cast<Point3d>().Distinct<Point3d>(new MyEqualityComparer(tol));
                    numout = enumerable.Count<Point3d>();
                else if (what == "DistinctHashSet")
                    HashSet<Point3d> hash = new HashSet<Point3d>(pts.Cast<Point3d>(), new MyEqualityComparer(tol));
                    numout = hash.Count;
                else numout = 0;
                sw.Stop();
                ticks = sw.Elapsed.Ticks;
                tr.Commit();
It's Alive!
  • Retired
  • AKA Daniel
« Reply #22 on: January 29, 2011, 10:40:06 PM »
Nice, although the times are about the same on my box
DistinctEnumerable
Found 20002 duplicate(s) in a 30000 items collection.
Elapsed milliseconds : 7844.7255
Command: DistinctHashSet
Tolerance: 1
Select objects: all
30000 found
Select objects:
DistinctHashSet
Elapsed milliseconds : 7775.5968
Jeff H
« Reply #23 on: January 29, 2011, 11:00:38 PM »
My results are very close like yours Daniel
Command: DISTINCTENUMERABLE
Tolerance: 1
Select objects: all
10000 found
Select objects:
DistinctEnumerable
Elapsed milliseconds : 2680.2491
Command: DISTINCTHASHSET
Tolerance: 1
Select objects: all
10000 found
Select objects:
DistinctHashSet
Elapsed milliseconds : 2653.0955
dann.boy.001
« Reply #24 on: January 30, 2011, 08:03:53 AM »
Hello,
Gile's code (wich he posted in one of previous posts) seems very fast for me.
I am sending that code, litle modified.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Module DuplicatePoints
    <System.Runtime.CompilerServices.Extension()> _
    Public Sub RemoveDuplicate(ByVal pts As Point3dCollection)
        pts.RemoveDuplicate(Tolerance.[Global])
    End Sub
    Public Sub RemoveDuplicate(ByRef pts As Point3dCollection, ByVal tol As Tolerance)
        Dim ptlst As New List(Of Point3d)()
        Dim n As Integer = pts.Count
        For i As Integer = 0 To n - 1
            ptlst.Add(pts(i))
        Next
        ptlst.Sort(Function(p1, p2) p1.X.CompareTo(p2.X))
        Dim m As Integer = ptlst.Count
        For i As Integer = 0 To m - 2
            Dim j As Integer = i + 1
            While j < ptlst.Count
                If (ptlst(j).X - ptlst(i).X) > tol.EqualPoint Then
                    Exit While
                End If
                If ptlst(i).IsEqualTo(ptlst(j), tol) Then
                    pts.Remove(ptlst(j))
                    ptlst.RemoveAt(j)
                Else
                    j += 1
                End If
            End While
        Next
    End Sub
    Public Sub RemoveDuplicate(ByRef dbpts As List(Of DBPoint), ByRef ListDuplicatePoints As List(Of ObjectId), ByVal tol As Tolerance)
        ListDuplicatePoints = New List(Of ObjectId)
        Dim ptlst As New List(Of DBPoint)()
        Dim n As Integer = dbpts.Count
            ptlst.Add(dbpts(i))
        Next
        ptlst.Sort(Function(p1, p2) p1.Position.X.CompareTo(p2.Position.X))
                If (ptlst(j).Position.X - ptlst(i).Position.X) > tol.EqualPoint Then
                    Exit While
                End If
                If ptlst(i).Position.IsEqualTo(ptlst(j).Position, tol) Then
                    ListDuplicatePoints.Add(ptlst(j).ObjectId)
                    ptlst.RemoveAt(j)
                Else
                    j += 1
                End If
            End While
        Next
    End Sub
End Module
Public Class Test
    <CommandMethod("DPOINTS")> _
    Public Sub DPOINTS()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        'Get points
        Dim SelectedPoints As IEnumerable = SelectPoints()
        If SelectedPoints Is Nothing Then Exit Sub
        'Get tolerance
        Dim pdr As PromptDoubleResult = ed.GetDouble("Tolerance: ")
        If pdr.Status <> PromptStatus.OK Then Exit Sub
        'Open transaction for reading points (or to later erase double points)
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Using tr
            DeleteDuplicatePoints3(SelectedPoints, tr, 0)
            tr.Commit()
        End Using
    End Sub
    Public Function SelectPoints() As IEnumerable
        Dim acTypValAr(0) As TypedValue
        acTypValAr.SetValue(New TypedValue(DxfCode.Start, "POINT"), 0)
        Dim sf As New SelectionFilter(acTypValAr)
        Dim pso As New PromptSelectionOptions()
        pso.MessageForAdding = "Select points: "
        pso.AllowDuplicates = False
        Dim psr As PromptSelectionResult = ed.GetSelection(pso, sf)
        If psr.Status <> PromptStatus.OK Then
            Return Nothing
        Else
            Return psr.Value.GetObjectIds
        End If
    End Function
    Public Sub DeleteDuplicatePoints3(ByVal o As IEnumerable, ByVal t As Transaction, ByVal Tol As Double)
        'Get list of points
        Dim ListPoints As New List(Of DBPoint)
        For Each id As ObjectId In o
            Dim dbpt As DBPoint = DirectCast(t.GetObject(id, OpenMode.ForRead), DBPoint)
            'Add point to list
            ListPoints.Add(dbpt)
        Next
        'Here add duplicate points (if exist)
        Dim ListDuplicatePoints As New List(Of ObjectId)
        Dim sw As Stopwatch = Stopwatch.StartNew()
        'Get duplicate points
        DuplicatePoints.RemoveDuplicate(ListPoints, ListDuplicatePoints, New Tolerance(Tol, Tol))
        sw.Stop()
        MsgBox("Found " + ListDuplicatePoints.Count.ToString + " duplicate(s) in a " + ListPoints.Count.ToString + " items collection. Elapsed milliseconds : " + (CDbl(sw.Elapsed.Ticks) / CDbl(TimeSpan.TicksPerMillisecond)).ToString)
    End Sub
End Class
Regards
Danijel
« Last Edit: January 30, 2011, 08:08:47 AM by dann.boy.001 »
gile
  • Marseille, France
« Reply #25 on: January 30, 2011, 09:06:25 AM »
First, thanks again to all, I learned a lot with this topic.
Finally, as dann.boy.001 said the sorted list route seems to be really faster with large collections than the IEnumerable and HashSet ones (which are very closed).
Using Thorsen's test commands (mine returned false results...) in which I add 'SortList' one:
                else if (what == "SortList")
                    List<Point3d> lst = SortList(pts, tol);
                    numout = lst.Count;
This command calls a method which returns a List<Point3d> object.
        private List<Point3d> SortList(Point3dCollection pts, Tolerance tol)
            List<Point3d> ptlst = new List<Point3d>();
            for (int i = 0; i < pts.Count; i++)
                ptlst.Add(pts[i]);
            ptlst.Sort((p1, p2) => p1.X.CompareTo(p2.X));
            for (int i = 0; i < ptlst.Count - 1; i++)
                for (int j = i + 1; j < ptlst.Count; )
                    if ((ptlst[j].X - ptlst[i].X) > tol.EqualPoint)
                        break;
                    if (ptlst[i].IsEqualTo(ptlst[j], tol))
                        ptlst.RemoveAt(j);
                    else
                        j++;
            return ptlst;
Here're the results with 10000 points
DistinctEnumerable
Elapsed milliseconds : 3072.7459
DistinctHashSet
Elapsed milliseconds : 2999.9208
SortedList
Elapsed milliseconds : 18.9593
With 20000 points
DistinctEnumerable
Found 10002 duplicate(s) in a 20000 items collection.
Elapsed milliseconds : 6106.0164
DistinctHashSet
Elapsed milliseconds : 5996.8205:
SortedList
Elapsed milliseconds : 317.208
With 40000 points
DistinctEnumerable
Found 20004 duplicate(s) in a 40000 items collection.
Elapsed milliseconds : 18422.6259
DistinctHashSet
Elapsed milliseconds : 18053.2102
SortedList
Elapsed milliseconds : 1260.4816
gile
  • Marseille, France
« Reply #26 on: January 30, 2011, 01:48:04 PM »
I ran the provious tests on AutoCAD 2007 32 bits.
The same tests with AutoCAD 2011 64 bits gives very different results:
10000 points
DistinctEnumerable
Found 0 duplicate(s) in a 10000 items collection.
Elapsed milliseconds : 2.4629
DistinctHashSet
Elapsed milliseconds : 2.5144
SortList
Elapsed milliseconds : 7.4756
20000 points
DistinctEnumerable
Found 10000 duplicate(s) in a 20000 items collection.
Elapsed milliseconds : 6.8504
DistinctHashSet
Elapsed milliseconds : 6.0844
SortList
Elapsed milliseconds : 222.6415
40000 points
DistinctEnumerable
Found 20000 duplicate(s) in a 40000 items collection.
Elapsed milliseconds : 14.7062
DistinctHashSet
Elapsed milliseconds : 14.3403
SortList
Elapsed milliseconds : 895.1789
Jeff H
« Reply #27 on: January 30, 2011, 03:57:11 PM »
Did on 2011 64 bit and I am showing duplicates matching test on 2011 32 bit unlike your tests
LE3
« Reply #28 on: January 30, 2011, 04:44:23 PM »
And for reference a way in C++/ARX
bool operator < (const AcGePoint3d& pt1, const AcGePoint3d& pt2)
if (pt1.x == pt2.x)
if (pt1.y == pt2.y)
return (pt1.z < pt2.z);
else
return (pt1.y < pt2.y);
else
return (pt1.x < pt2.x);
static void ArxCmdsTester_DuplicatePointsFinder(void)
std::vector<AcGePoint3d> pts;
AcDbObjectId objId;
ads_name ename;
ads_name ss;
resbuf* rbFilter;
rbFilter = acutBuildList(RTDXF0, _T("POINT"), RTNONE);
TCHAR* intersPrompts[] = {_T("Select points: "), _T("Remove points: ")};
if (acedSSGet(_T(":$"), intersPrompts, NULL, rbFilter, ss) != RTNORM)
acutRelRb(rbFilter);
return;
long len = 0;
if ((acedSSLength(ss, &len) != RTNORM) || (len == 0))
acedSSFree(ss);
return;
for (int i = 0; i < len; i++)
if (acedSSName(ss, i, ename) == RTNORM)
if (acdbGetObjectId(objId, ename) == Acad::eOk)
AcDbObjectPointer<AcDbPoint> pPoint(objId, AcDb::kForRead);
if (pPoint.openStatus() == Acad::eOk)
pts.push_back(pPoint->position());
acedSSFree(ss);
acutPrintf(_T("\nPoints before unique: %ld "), pts.size());
std::sort(pts.begin(), pts.end());
pts.erase(std::unique(pts.begin(), pts.end()), pts.end());
acutPrintf(_T("\nPoints after unique: %ld "), pts.size());
pts.clear();
pkohut
« Reply #29 on: January 31, 2011, 03:34:23 AM »
Nice trick Dan
Also, returning a 32 bit int hash from a 64 bit double isn't going to guarantee unique values, let alone 192 bits worth of doubles. Worse yet XOR'ing the hash values reduces the uniqueness even further.
For example: 1 ^ 2 ^ 3 = 0
ps, also from the .Net docs
The default implementation of the GetHashCode method does not guarantee unique return values for different objects. Furthermore, the .NET Framework does not guarantee the default implementation of the GetHashCode method, and the value it returns will be the same between different versions of the .NET Framework. Consequently, the default implementation of this method must not be used as a unique object identifier for hashing purposes.
New tread (not retired) - public repo at https://github.com/pkohut
