Author Topic: [Challenge] Intersection of line & circle  (Read 7328 times)
chlh_jd
« on: January 25, 2011, 03:36:56 AM »
Intersection of line & circle in plane :lol:
line : p1 p2
circle : cen rad
(fun p1 p2 cen rad)
Here's your most efficient codes   :lol:
« Last Edit: January 25, 2011, 06:05:48 AM by chlh_jd »
ElpanovEvgeniy
  • Moscow (Russia)
Re: [Challenge] Intersection of line & circle
« Reply #1 on: January 25, 2011, 03:49:35 AM »
check only one plane?
chlh_jd
« Reply #2 on: January 25, 2011, 06:05:20 AM »
Hi ElpanovEvgeniy
I'm sorry to forget the cond 'just plane'
qjchen
  • Best wishes to all
« Reply #3 on: January 25, 2011, 08:51:39 AM »
Here is my code and testing code. for study a little about trans.
It add a parameter at the end, realint? if nil then virtural intersection will be allowed
The code can be used in 3d ucs plane.
But it is too long code, I will try to shorten it. :-D
;;;by qjchen@gmail.com
;;;;vec plus constant
(defun q:vec:*c(v a)  (mapcar '(lambda(x) (* x a)) v))
;;;;vec dot product
(defun q:vec:dot*(v1 v2)  (apply '+ (mapcar '* v1 v2)))
;;;;Normalize a vec
(defun q:vec:Norm(v / l) (if (not (zerop (setq l (distance '(0 0 0) v)))) (mapcar '(lambda(x) (/ x l)) v)))
;;;; Intersection of line and circle
;;;; qjchen@gmail.com
(defun q:geo:line-int-cir1(p1 p2 c r realint? / n pv f d2)
 (setq n (q:vec:Norm (mapcar '- p2 p1)))
 (setq pv (mapcar '+ p1 (q:vec:*c n (q:vec:dot* (mapcar '- c p1) n))))
 (defun f(p p1 p2 n) (if (< (* (- (caddr (trans p 0 n)) (caddr (trans p1 0 n))) (- (caddr (trans p 0 n)) (caddr (trans p2 0 n)))) 0.0) p))
 (if (< (setq d2 (- (expt r 2.) (expt (distance c pv) 2.))) 0.)
   (list nil nil)
   (if realint?
    (list (f (mapcar '+ pv (q:vec:*c n (sqrt d2))) p1 p2 n) (f (mapcar '- pv (q:vec:*c n (sqrt d2))) p1 p2 n))
    (list (mapcar '+ pv (q:vec:*c n (sqrt d2))) (mapcar '- pv (q:vec:*c n (sqrt d2))))
;;;;for test
(defun c:test( / c p1 p2 r res)
  (setq p1 (getpoint "1st point\n") p2 (getpoint "2nd point\n") c (getpoint "3rd point\n") r (getdist "distan\n"))
  (setq res (q:geo:line-int-cir1 p1 p2 c r T))
  (if (car res) (grdraw (list 0 0 0) (car res) 1) )
  (if (cadr res) (grdraw (list 0 0 0) (cadr res) 2))
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
« Reply #4 on: January 25, 2011, 09:16:53 AM »
I have this, but it considers the Line infinite in length... I'm sure there's a better way
(defun IntersLineCircle ( p1 p2 c r  / p d v )
  (setq p (ProjectPointonLine c p1 p2)
        d (distance c p)
        v (v1 (mapcar '- p2 p1))
    ( (> d r) nil )
    ( (equal d r 1e-8) (list p) )
    ( (setq v (vxs v (sqrt (- (* r r) (* d d)))))
      (list (mapcar '+ p v) (mapcar '- p v))
(defun ProjectPointonLine ( pt p1 p2 )
    (lambda ( n )
      (setq pt (trans pt 0 n))
      (trans (list (car pt) (cadr pt) (caddr (trans p1 0 n))) n 0)
    (v^v
      (mapcar '- p2 p1)
      (mapcar '- (mapcar '+ p1 (v^v (mapcar '- p2 p1) (mapcar '- pt p1))) p1)
(defun v^v ( u v )
  (list
    (- (* (cadr u) (caddr v)) (* (cadr v) (caddr u)))
    (- (* (car  v) (caddr u)) (* (car  u) (caddr v)))
    (- (* (car  u) (cadr  v)) (* (car  v) (cadr  u)))
(defun vxs ( v s )
  (mapcar '(lambda ( n ) (* n s)) v)
(defun v1 ( v )
  ( (lambda ( n ) (if (not (equal n 0.0 1e-14)) (vxs v (/ 1.0 n))))
    (distance '(0. 0. 0.) v)
Test function:
(defun c:test ( / _p p1 p2 c r )
  (defun _p ( p ) (entmakex (list (cons 0 "POINT") (cons 10 p))))
    (and
      (setq p1 (getpoint "\nLine Start: "))
      (setq p2 (getpoint "\nLine End: "))
      (setq c  (getpoint "\nCircle Center: "))
      (setq r  (getdist c "\nCircle Radius: "))
    (mapcar '_p (IntersLineCircle (trans p1 1 0) (trans p2 1 0) (trans c 1 0) r))
« Reply #5 on: January 25, 2011, 09:41:10 AM »
I think I got hooked on that trans method a bit too much...
(defun IntersLineCircle ( p1 p2 c r onseg  / p d v )
  (setq v (v1 (mapcar '- p2 p1)) p (mapcar '+ p1 (vxs v (vxv (mapcar '- c p1) v)))
        d (distance c p)
    ( (> d r) nil )
    ( (equal d r 1e-8) (list (inters p1 p2 c p onseg)))
      (list
        (inters p1 p2 c (mapcar '+ p v) onseg)
        (inters p1 p2 c (mapcar '- p v) onseg)
(defun v1 ( v )
(defun vxv ( u v ) (apply '+ (mapcar '* u v)))
(defun vxs ( v s ) (mapcar '(lambda ( n ) (* n s)) v))
qjchen
« Reply #6 on: January 25, 2011, 09:47:08 AM »
:) Lee, we use almost the same method~
but your
is better than mine.
I use a self define function f to judge it, I should have use inters instead:)
And it should be
;;;after lee mac's good method
(defun q:geo:line-int-cir2(p1 p2 c r realint? / n pv d2)
   (list nil nil)
   (list (inters p1 p2 c (mapcar '+ pv (q:vec:*c n (sqrt d2))) realint?)(inters p1 p2 c (mapcar '- pv (q:vec:*c n (sqrt d2))) realint?))
« Last Edit: January 26, 2011, 06:10:31 AM by qjchen »
« Reply #7 on: January 25, 2011, 09:57:27 AM »
With my first code I overlooked the easier method of using the dot product to project the circle center onto the line, as, from that other thread I could only think about using trans and ended up constructing a plane perpendicular to the line/circle...  :oops:
« Reply #8 on: January 25, 2011, 07:28:25 PM »
Of course, there is the lazy-man's method  :-D
(defun IntersLineCircle ( p1 p2 c r onseg / return e1 e2 ) (vl-load-com)
  (setq return
    (LM:GroupByNum
      (vlax-invoke
        (vlax-ename->vla-object
          (setq e1 (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))))
        'IntersectWith
          (setq e2 (entmakex (list (cons 0 "CIRCLE") (cons 10 c) (cons 40 r))))
        (if onseg acExtendNone acExtendthisEntity)
      3
  (mapcar 'entdel (list e1 e2))
  return
;;-----------------=={ Group by Number }==--------------------;;
;;  Groups a list into a list of lists, each of length 'n'    ;;
;;  Author: Lee Mac, Copyright © 2010 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  l - List to process                                       ;;
;;  n - Number of elements by which to group the list         ;;
;;  Returns:  List of lists, each of length 'n'               ;;
(defun LM:GroupByNum ( l n / r)
  ;; © Lee Mac 2010
  (if l
    (cons
      (reverse
        (repeat n (setq r (cons (car l) r) l (cdr l)) r)
      (LM:GroupByNum l n)
qjchen
« Reply #9 on: January 25, 2011, 07:50:00 PM »
But certainly if the curve is more complicate, this is the best method in Autolisp. :)
« Reply #10 on: January 25, 2011, 07:51:31 PM »
It's certainly more practical.  :-)
chlh_jd
« Reply #11 on: January 26, 2011, 12:15:39 AM »
Hi qjchen , Hi Lee Mac  :-)
I learn a lot from your codes through Vetor Method
Here's my first code
;;;Through general Geometric convertion
(defun LIC (pt1 pt2 cen rad / pt dis ang d)
  (setq pt  (inters
      cen
      (polar cen (+ (/ pi 2.) (angle pt1 pt2)) 1.)
      pt1
      pt2
      nil
dis (distance pt cen)
    ((equal rad dis) (list pt))
    ((> rad dis)
     (list (polar pt
  (setq ang (angle pt1 pt2))
  (setq d (sqrt (- (* rad rad) (* dis dis))))
   (polar pt
  (+ pi ang)
  d
I try to use the 'intersectwith method , But it run so slow
;;;Through 'intersectwith
;;;To get intersection of two curves
;;;____0  non EX ,1 first EX  2 second EX ,3 both EX___________________
;;;________BY__GSLS(SS)_______________2010.08.05_____________________
(defun ss-interpts (e1 e2 lim / obj1 obj2 mid end mid1)
  (setq obj1 (vlax-ename->vla-object e1)
obj2 (vlax-ename->vla-object e2)
  (setq mid (vla-IntersectWith obj1 obj2 lim))
  (vlax-release-object obj1)
  (vlax-release-object obj2)
  (if (not
(minusp
  (vlax-safearray-get-u-bound (vlax-variant-value mid) 1)
      (setq mid (vlax-safearray->list (vlax-variant-value mid)))
      (setq end nil)
      (repeat (/ (length mid) 3)
(setq mid1 (list (car mid) (cadr mid) (caddr mid))
      mid  (cdddr mid)
      end  (cons mid1 end)
      (reverse end)
    nil
;;;use the intersectwith , But it sacrifices a lot of efficiency
(defun LICa (pt1 pt2 cen rad / en1 en2 pts)
  (setq en1 (entmakex (list (cons 0 "LINE") (cons 10 pt1) (cons 11 pt2)))
en2 (entmakex (list (cons 0 "CIRCLE") (cons 10 cen) (cons 40 rad)))
  (setq pts (ss-interpts en1 en2 3))
  (entdel en1)(entdel en2)
  pts
Fun for test
;;;test
(defun c:test(/ en1 en2 pt1 pt2 cen rad pts)
  (setq en1 (car (entsel "Select a Line :"))
en2 (car (entsel "\nSelect a Circle :"))
pt1 (cdr (assoc 10 (entget en1)))
pt2 (cdr (assoc 11 (entget en1)))
cen (cdr (assoc 10 (entget en2)))
rad (cdr (assoc 40 (entget en2)))
  (setq pts (LIC pt1 pt2 cen rad))
  (check-pt pts)
;;;Auxiliary Function to  Check the Point Set
(defun check-pt (ptlst / i)
  (setq i 0)
  (mapcar (function
    (lambda (x)
      (entmake
(list (cons 0 "LINE") (cons 10 (list 0 0 0)) (cons 11 x) (cons 62 (setq i (1+ i))))
  ptlst
chlh_jd
« Reply #12 on: January 26, 2011, 12:47:43 AM »
Hi Lee Mac
I can't understand , this Statement not equal
(v^v (mapcar '- p2 p1) (mapcar '- pt p1)) ?
chlh_jd
« Reply #13 on: January 26, 2011, 03:11:35 AM »
Another way : Use trigonometric funs and polar coors
But it's less than use vectors,I'm not sure It can be rewrited into 'trans method ?
(defun LICb (pt1 pt2 cen rad / ang p1 p2 anl x y d anp anq pts)
  (setq ang (angle '(0 0 0) cen)
p1  (gsls-xy->ab pt1 cen ang)
p2  (gsls-xy->ab pt2 cen ang)
anl (- (angle pt1 pt2) ang)
  (while (> anl pi)
    (setq anl (- anl pi))
  (setq x (car (inters '(0 0 0) (list rad 0 0) p1 p2 nil))
y (cadr (inters '(0 0 0) (list 0 rad 0) p1 p2 nil))
d (/ (* x y) (sqrt (+ (* x x) (* y y))))
  (cond ((equal d rad 1e-8)
(if (>= x 0)
  (setq anp (- anl (/ pi 2.)))
  (setq anp (+ anl (/ pi 2.)))
(setq pts (list (list (* rad (cos anp)) (* rad (sin anp)) 0)))
((< d rad)
(if (>= x 0)
  (setq anp (+ (atan (* (sqrt (- 1. (* (/ d rad) (/ d rad)))) (/ rad d)))
  anl
  (/ pi -2.)
anq (- (* 2. anl) anp pi)
  anl
  (/ pi 2.)
(list (* rad (cos anq)) (* rad (sin anq)) 0)
  (if pts
    (mapcar (function (lambda (p)
(gsls-ab->xy p cen ang)
   pts
Use Fun
;;;trans UCS 2Dcoors into wcs,the UCS which orrgin on PT0,X-aixs angle is ANG
;;;X=X0+AcosR0-BsinR0
;;;Y=Y0+AsinR0+BcosR0
(defun gsls-AB->XY (pt pt0 ANG / X Y)
  (setq X (+ (car pt0)
    (* (car pt) (cos ANG))
    (* -1 (cadr pt) (sin ANG))
Y (+ (cadr pt0)
    (* (car pt) (sin ANG))
    (* (cadr pt) (cos ANG))
  (list X Y 0.0)
;;;trans wcs 2Dcoors into ucs,the UCS which orrgin on PT0,X-aixs angle is ANG
;;;A=(X-X0)cosR0+(Y-Y0)sinR0
;;;B=(Y-Y0)cosR0-(X-X0)sinR0
(defun gsls-XY->AB (pt pt0 ANG / A B)
  (setq A (+ (* (- (car pt) (car pt0)) (cos ANG))
    (* (- (cadr pt) (cadr pt0)) (sin ANG))
B (- (* (- (cadr pt) (cadr pt0)) (cos ANG))
    (* (- (car pt) (car pt0)) (sin ANG))
  (list A B 0.0)
« Last Edit: January 26, 2011, 04:19:18 AM by chlh_jd »
« Reply #14 on: January 26, 2011, 11:12:04 AM »
Hi Lee Mac
Indeed it is  :oops:  The method in my first code is laughable...
