(defun c:join (/ csnaps pt1 pt2 pt3 pt4 pt5) (setq csnaps (getvar 'osmode)) (setvar "osmode" 0) (initget 1) (setq pt1 (getpoint "\nSelect arc start point:")) (initget 1) (setq pt2 (getpoint pt1 "\nSelect arc midpoint:")) (initget 1) (setq pt3 (getpoint pt2 "\nSelect arc endpoint:")) (command ".pline" pt1 "a" "s" pt2 pt3 "") (initget 1) (setq pt4 (getpoint pt3 "\nSelect second arc midpoint:")) (initget 1) (setq pt5 (getpoint pt4 "\nSelect second arc endpoint:")) (command ".pline" pt3 "a" "s" pt4 pt5 "") (command ".pedit" "last" "join" "cr" pt1 pt5 "" "") (setvar "osmode" csnaps) (princ))
