...(5) that is what you need?...
...(4) boolean (the Max area region)-(the other region)....
How to sort object refer to its area?Quote from: qjchen on January 24, 2011, 07:02:25 AM...(4) boolean (the Max area region)-(the other region)....
Could I call a command then use VLA-***
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "your command string")
