Example:
But is this mean we cant ADDREGION by picking a point?
What's the benefit of picking points to get REGION instead of Selection Set ? :realmad:
I think it is possible to do "only picking points", but now the solution is not so perfect.
(1) use command "_boundary" to pick a point , then it would generates some boundary objects
(2) cal each boundary object area
(3) convert all new boundary objects to regions one by one
(4) boolean (the Max area region)-(the other region).
(5) that is what you need?
