Afternoon everyone,
I am writing a script to activate the currently running AutoCAD program on any given machine and then run a LiSP.
I am stuck on how to determine which version is currently running in order to make it active.
If I'm trying to do this:
Set WSO = WScript.CreateObject("WScript.Shell")
Function ActivateACAD()
WSO.AppActivate "AutoCAD Map 3D 2011" [color=green]' What if the user is running "AutoCAD Map 3D 2010"[/color]
Would I just use an IF statement?
IF NOT WSO.AppActivate "AutoCAD Map 3D 2010" Then
End If
Thank you for the help.
