Author Topic: Has anyone used the DisplayRepresentationManager?  (Read 2061 times)
commodore
« on: January 15, 2011, 10:16:17 AM »
I am trying to set the display configuration on a new viewport that I created with my program but I cant get the GetDisplayConfigurationId or SetDisplayConfigurationId methods to show up in intellisense. They appear in the object browser.
My import statement
Imports AecDB = Autodesk.Aec.DatabaseServices
and just to test it Im trying.. Dim aaa As ObjectId = AecDB.DisplayRepresentationManager.GetDisplayConfigurationId(ShtVP.ObjectId)
Am I even going in the right direction to change the display configuration on a viewport?
Jeff H
Re: Has anyone used the DisplayRepresentationManager?
« Reply #1 on: January 19, 2011, 11:35:00 PM »
I have been meaning to learn the AEC API.
This does not work in modelspace
So far you
- create a new instance of the DisplayRepresentationManager object passing in the current database
- use the DisplayConfigurationIdForCurrentViewport property of the DisplayRepresentationManager  to get objectId of current display config
- create a new instance of the DictionaryDisplayConfiguration object passing in the current database to access different Display reps
- Use GetAt and pass in name of Display Config to grab Objectid
- Use SetDisplayConfigurationId passing in The viewportId and Id of display config to change to
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.Aec.DatabaseServices
Imports ObjectId = Autodesk.AutoCAD.DatabaseServices.ObjectId
<Assembly: CommandClass(GetType(AutoCAD_VB_plug_in5.MyCommands))>
Namespace AutoCAD_VB_plug_in5
    Public Class MyCommands
        <CommandMethod("ChangeDisplayConfig")> _
        Public Sub ChangeDisplayConfig()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim disRepMngr As New DisplayRepresentationManager(db)
                Dim currentDisplayConfig As DisplayConfiguration = disRepMngr.DisplayConfigurationIdForCurrentViewport.GetObject(OpenMode.ForRead)
                ed.WriteMessage(vbCrLf & "The current displayConfig is " & currentDisplayConfig.Name)
                Dim dictDisplConfigs As New DictionaryDisplayConfiguration(db)
                If dictDisplConfigs.Has("Electrical - Lighting", trx) Then
                    Dim newDisplyConfigId As ObjectId = dictDisplConfigs.GetAt("Electrical - Lighting")
                    disRepMngr.SetDisplayConfigurationId(ed.ActiveViewportId, newDisplyConfigId)
                End If
                trx.Commit()
            End Using
« Last Edit: January 19, 2011, 11:46:01 PM by Jeff H »
commodore
« Reply #2 on: January 20, 2011, 08:40:12 AM »
Thanks Jeff,
That works great!
Coincidently I had just found the sample "C:\Program Files\AutoCAD MEP 2010\Sample\VB.NET\AecDisplaySampleMgd" this morning, but your example is right to my point.
Jeff H
« Reply #3 on: February 24, 2011, 04:59:16 AM »
Do not know if you figured it out or already knew but,
to work in model space or set model space's
you use the DisplayRepresentationManager.DefaultDisplayConfigurationId property
Code updated and C# code added
    <CommandMethod("ChangeDisplayConfigVB")> _
        Public Sub ChangeDisplayConfigVB()
                    Try
                    Catch ex As System.Exception
                        disRepMngr.DefaultDisplayConfigurationId = newDisplyConfigId
                    End Try
                End If
                currentDisplayConfig = disRepMngr.DisplayConfigurationIdForCurrentViewport.GetObject(OpenMode.ForRead)
                trx.Commit()
            End Using
        [CommandMethod("ChangeDisplayConfigCS")]
        public void ChangeDisplayConfigCS()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction trx = db.TransactionManager.StartTransaction())
                DisplayRepresentationManager disRepMngr = new DisplayRepresentationManager(db);
                DisplayConfiguration currentDisplayConfig = disRepMngr.DisplayConfigurationIdForCurrentViewport.GetObject(OpenMode.ForRead) as DisplayConfiguration;
                ed.WriteMessage("\nThe current displayConfig is " + currentDisplayConfig.Name);
                DictionaryDisplayConfiguration dictDisplConfigs = new DictionaryDisplayConfiguration(db);
                if (dictDisplConfigs.Has("Electrical - Lighting", trx))
                    ObjectId newDisplyConfigId = dictDisplConfigs.GetAt("Electrical - Lighting");
                    try
                        disRepMngr.SetDisplayConfigurationId(ed.ActiveViewportId, newDisplyConfigId);
                    catch (System.Exception)
                        disRepMngr.DefaultDisplayConfigurationId = newDisplyConfigId;
                trx.Commit();
