Author Topic: please give me advice at this lisp  (Read 2743 times)
Sam
« on: January 15, 2011, 06:16:18 AM »
Dear All,
i'm trying create layer & text style but not create text style & text boundary.
confusion mark is red
;; This Program Created area of pline (@ mm Drawing only)        ;;
(defun c:CA nil (c:CarpetArea))
(defun c:CarpetArea ( / *error* _EndUndo _StartUndo p5 p6 a b c d e f s )
;;                        SubFunctions                        ;;
;;                        Error Handler                       ;;
;;                      © Lee Mac 2010                       ;;
  (defun *error* ( msg )
   [color=red] (if doc (_EndUndo doc))[/color]
 (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
  [color=red](defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)[/color]
;;--------------------- Create Layer & Text Style ------------;;
  (if(not(tblsearch "LAYER" "Tx"))
     (command "-layer" "new" "Tx" "Color" 4 "Tx" "LTYPE" "Continuous" "Tx" "")
     );end if
  (setvar "clayer" "Tx")
  (setvar "celtype" "bylayer")
  (setvar "cecolor" "bylayer")
    (setvar "insunits" 0)
[color=red](if(not(tblsearch "Style" "Tx"))
  (command "-style" "tx" "ARIAL" "0" "1" "0" "" "" ""))
    ; ((0 . "STYLE") (2 . "Tx") (70 . 0) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 0.3) (3 . "txt") (4 . ""))
     );end if
  ;(getvar "textstyle" "rd")[/color]
(if (and (setq s (ssget "_:S:E" '((0 . "LWPOLYLINE"))))
         (setq p5 (getpoint "\nWHERE TO PLACE TEXT: "))
(setq p5 (polar p5 pi 1250))
(setq p6 (polar p5 0 2500))
;(setq fn (getstring t "\nFLAT NO.:"))
(command "._area" "_e" (ssname s 0))
(SETQ A (GETVAR "AREA"))
(setq f (* A 0.000010764))
(setq f (rtos f 2 2))
(SETQ f (strcat f " SQ. FT."))
(SETQ B (/ A 1000000))
(SETQ C (RTOS B 2 2))
(SETQ D "CARPET AREA")
;(setq e (strcat FN " = " C " SQ.MT."))
(setq e (strcat "= " C " SQ.MT."))
(setq F (strcat "= " F))
[color=red](COMMAND "_TEXT" "_S" "standard" "_f" P5 p6 "225" D
         "_text" "" e
         "_text" "" f
         "_.rectangle"
         (mapcar '+ P5 '(-165 440 0))
         (mapcar '+ P6 '(165 -1045 0))[/color]
); end command
); End Progn
(princ "\n   ~¤~            ...Type \"Ca\" to Invoke...               ~¤~   ")
;; Exit Cleanly
;; End defun
;;;;;;;;; ------ End Program ---
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
kruuger
Re: please give me advice at this lisp
« Reply #1 on: January 15, 2011, 06:54:21 AM »
you can use this as a template.
in your code all these ..Undo.. are undo mark, will not work beacuse there is no doc variable. see my template how it works (with ACTOBJ and ACTDOC variable)
[color=RED]([/color][color=BLUE]defun[/color] C:CA [color=RED]([/color][color=BLUE]/[/color] OLDERR ACOBJ ACTDOC[color=RED])[/color]
  [color=RED]([/color][color=BLUE]setq[/color] OLDERR [color=BLUE]*error*[/color] [color=BLUE]*error*[/color] CA_Error
        ACOBJ [color=RED]([/color][color=BLUE]vlax-get-Acad-Object[/color][color=RED])[/color]
        ACTDOC [color=RED]([/color][color=BLUE]vla-get-ActiveDocument[/color] ACOBJ[color=RED])[/color]
  [color=RED]([/color][color=BLUE]vla-endundomark[/color] ACTDOC[color=RED])[/color]
  [color=RED]([/color][color=BLUE]vla-startundomark[/color] ACTDOC[color=RED])[/color]
    [color=RED]([/color][color=DARKRED].[/color][color=DARKRED].[/color]calculation..[color=RED])[/color]
    [color=RED]([/color][color=DARKRED].[/color][color=DARKRED].[/color]create layer..[color=RED])[/color]
    [color=RED]([/color][color=DARKRED].[/color][color=DARKRED].[/color]create text..[color=RED])[/color]
  [color=RED]([/color][color=BLUE]if[/color] OLDERR [color=RED]([/color][color=BLUE]setq[/color] [color=BLUE]*error*[/color] OLDERR[color=RED]))[/color]
[color=#990099]; ============================================================ ;[/color]
[color=#990099]; Error handling                                               ;[/color]
[color=RED]([/color][color=BLUE]defun[/color] CA_Error [color=RED]([/color]Msg[color=RED])[/color]
    [color=RED]([/color][color=BLUE]=[/color] [color=#009900]8[/color] [color=RED]([/color][color=BLUE]logand[/color] [color=#009900]8[/color] [color=RED]([/color][color=BLUE]getvar[/color] [color=#a52a2a]"UNDOCTL"[/color][color=RED])))[/color]
    [color=RED]([/color][color=BLUE]or[/color]
      [color=RED]([/color][color=BLUE]=[/color] Msg [color=#a52a2a]"Function cancelled"[/color][color=RED])[/color]
      [color=RED]([/color][color=BLUE]=[/color] Msg [color=#a52a2a]"quit / exit abort"[/color][color=RED])[/color]
    [color=RED]([/color][color=BLUE]princ[/color] [color=RED]([/color][color=BLUE]strcat[/color] [color=#a52a2a]"\nError: "[/color] msg[color=RED]))[/color]
    [color=RED]([/color][color=BLUE]princ[/color] [color=#a52a2a]" Cancelled. "[/color][color=RED])[/color]
[color=#990099]; Make TEXT                                                    ;[/color]
[color=#990099];   Point  [LIST] - insertion point                            ;[/color]
[color=#990099];   Height  [INT] - text height                                ;[/color]
[color=#990099];   String  [STR] - text string                                ;[/color]
[color=#990099];   Layer   [STR] - text layer                                 ;[/color]
[color=#990099]; ------------------------------------------------------------ ;[/color]
[color=#990099]; (kr:ENT_MakeText '(0 0 0) 6 "tralala" "0")                   ;[/color]
[color=RED]([/color][color=BLUE]defun[/color] kr:ENT_MakeText [color=RED]([/color]Point Height String Layer[color=RED])[/color]
  [color=RED]([/color][color=BLUE]entmakex[/color]
    [color=RED]([/color][color=BLUE]list[/color]
      [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]0[/color] [color=#a52a2a]"TEXT"[/color][color=RED])[/color]
      [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]10[/color] [color=RED]([/color][color=BLUE]trans[/color] Point [color=#009900]1[/color] [color=#009900]0[/color] [color=BLUE]t[/color][color=RED]))[/color]
      [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]8[/color] Layer[color=RED])[/color]
      [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]40[/color] Height[color=RED])[/color]
      [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]1[/color]  String[color=RED])[/color]
[color=#990099]; Make LAYER                                                   ;[/color]
[color=#990099];   Name  (STR) - layer name                                   ;[/color]
[color=#990099];   Color (INT) - layer color                                  ;[/color]
[color=#990099];   Ltype (STR) - layer linetype                               ;[/color]
[color=#990099]; (kr:ENT_MakeLayer "Line" 6 "CONTINUOUS")                     ;[/color]
[color=RED]([/color][color=BLUE]defun[/color] [color=BLUE]kr:ENT_MakeLayer[/color] [color=RED]([/color]Name Color Ltype[color=RED])[/color]
        [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]0[/color] [color=#a52a2a]"LAYER"[/color][color=RED])[/color]
        [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]100[/color] [color=#a52a2a]"AcDbSymbolTableRecord"[/color][color=RED])[/color]
        [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]100[/color] [color=#a52a2a]"AcDbLayerTableRecord"[/color][color=RED])[/color]
        [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]2[/color] Name[color=RED])[/color]
        [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]62[/color] [color=RED]([/color][color=BLUE]if[/color] Color Color [color=#009900]7[/color][color=RED]))[/color]
        [color=RED]([/color][color=BLUE]cons[/color] [color=#009900]6[/color]
          [color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]and[/color] Ltype [color=RED]([/color][color=BLUE]tblsearch[/color] [color=#a52a2a]"LTYPE"[/color] Ltype[color=RED]))[/color]
            Ltype
            [color=#a52a2a]"CONTINUOUS"[/color]
kruuger
Sam
« Reply #2 on: January 17, 2011, 01:14:48 AM »
            Ltype
kruuger
Dear Sir,
thx for help
 (..calculation..) please specify calculation opation
    (..create layer..)
    (..create text..)
« Last Edit: January 17, 2011, 01:29:54 AM by Sam »
kruuger
« Reply #3 on: January 17, 2011, 02:44:51 AM »
Dear Sir,
thx for help
    (..create layer..)
    (..create text..)
calculation (my english sucks) i mean all your SETQ
kruuger
Sam
« Reply #4 on: January 17, 2011, 02:52:37 AM »
Dear Sir,
thx for help
    (..create layer..)
    (..create text..)
kruuger
Dear Sir
thx
