Author Topic: [Challenge] Pascal's triangle  (Read 11232 times)
gile
  • Marseille, France
« on: January 13, 2011, 04:37:02 PM »
A purpose for a little challenge around Pascal's triangle.
Define a function which returns the a Pascal's triangle to its nth row:
(foo 4) => ((1) (1 1) (1 2 1) (1 3 3 1) (1 4 6 4 1))
and/or a function which returns the nth row:
(foo 6) => (1 6 15 20 15 6 1)
Re: [Challenge] Pascal's triangle
« Reply #1 on: January 13, 2011, 04:58:38 PM »
Excellent challenge! I love it  :lol:
Quick & Dirty attempt at the first one:
(defun pascalntable ( n )
  (if (< n 1)
   '(( 1 ))
      (lambda ( x )
        (append x (list (mapcar '+ (cons 0 (last x)) (append (last x) '( 0 )))))
      (pascalntable (1- n))
Iterative:
(defun pascalntable_iter ( n / x )
  (repeat (setq x '(( 1 )) n n)
    (setq x (append x (list (mapcar '+ (cons 0 (last x)) (append (last x) '( 0 ))))))
  x
And tweaked for the second:
(defun pascalnth ( n )
  (if (< 0 n)
    ( (lambda ( x ) (mapcar '+ (cons 0 x) (append x '( 0 )))) (pascalnth (1- n)))
   '( 1 )
Iterative:
(defun pascalnth_iter ( n / x )
  (repeat (setq x '( 1 ) n n)
    (setq x (mapcar '+ (cons 0 x) (append x '( 0 ))))
  x
« Last Edit: January 13, 2011, 06:52:09 PM by Lee Mac »
« Reply #2 on: January 13, 2011, 06:32:49 PM »
Well that was fun (Python 3.x):
def:
def pascals_triangle(n):
    x=[[1]]
    for i in range(n-1):
        x.append([a+b for a,b in zip([0]+x[-1],x[-1]+[0])])
    return x
call:
for x in pascals_triangle(10):
    print('{0:^39}'.format(x))
output:
                  [1]
                [1, 1]
               [1, 2, 1]
             [1, 3, 3, 1]
            [1, 4, 6, 4, 1]
         [1, 5, 10, 10, 5, 1]
       [1, 6, 15, 20, 15, 6, 1]
     [1, 7, 21, 35, 35, 21, 7, 1]
   [1, 8, 28, 56, 70, 56, 28, 8, 1]
[1, 9, 36, 84, 126, 126, 84, 36, 9, 1]
:lol:
Thanks Gile!!!
« Reply #3 on: January 13, 2011, 06:47:02 PM »
Mine looks like Lee's, but not recursive.
(defun tmw_PascalTriangle ( num / lst)
    (repeat num
        (setq lst
            (cons
                (if lst
                    (mapcar (function +) (cons 0 (car lst)) (append (car lst) (list 0)))
                    (list 1)
                lst
    (reverse lst)
« Reply #4 on: January 13, 2011, 07:02:03 PM »
Mild variant:
    x=[[1]]
        x.append([sum(i) for i in zip([0]+x[-1],x[-1]+[0])])
    return x
Python rocks.
« Reply #5 on: January 13, 2011, 07:53:34 PM »
Another [slow] one:
(defun pascalnth_fact ( n / _fact k n! l )
  (defun _fact ( i )
    (if (< i 2) 1 (* i (_fact (1- i))))
  (setq k -1 n! (_fact n))
  (repeat (1+ n) (setq l (cons (/ n! (* (_fact (setq k (1+ k))) (_fact (- n k)))) l)))
  l
gile
  • Marseille, France
« Reply #6 on: January 14, 2011, 02:49:25 AM »
Very nice guys !!!
While I was sleeping, you were not...
So, not so many place left for LISP solutions.
Here's one using another algorithm to avoid using append.
(defun pascalTriangle (n / f1 f2)
  (defun f1 (l n)
    (if (< 0 n)
      ((lambda (x)
(cons (cons 1 x) (f1 x (1- n)))
(f2 (cons 1 l))
  (defun f2 (l)
    (if (cdr l)
      (cons (+ (car l) (cadr l)) (f2 (cdr l)))
      '(1)
  (cons '(1) (f1 nil n))
(defun pascalRow (n / f1 f2)
  (defun f1 (l n)
    (if (< 0 n)
      (f1 (f2 (cons 1 l)) (1- n))
      (cons 1 l)
  (defun f2 (l)
    (if (cdr l)
      '(1)
  (f1 nil n)
And a F# one (the first one uses an infinite lazy sequence)
let pascalTriangle n =
    let foo l = List.map2 (+) (0 :: l) (List.append l [0])
    Seq.unfold (fun l -> Some(l, foo l)) [1] |> Seq.take (n + 1) |> Seq.toList
let pascalRow n =
    List.fold (fun l i -> foo l) [1] [1 .. n]
gile
  • Marseille, France
« Reply #7 on: January 14, 2011, 04:43:19 AM »
No need to use a sequence, I found a List.scan function:
    List.scan(fun l i -> List.map2 (+) (0 :: l) (List.append l [0])) [1] [1 .. n]
« Last Edit: January 14, 2011, 04:47:16 AM by gile »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: January 14, 2011, 09:04:38 AM »
my version triangle:
(defun f (n / f1)
 (defun f1 (l) (append l (list (append '(1) (mapcar '+ (last l) (cdr (last l))) '(1)))))
 (cond ((< n 1) '((1)))
       ((f1 (f (1- n))))
my version NTH:
(defun f (n / f1)
 (defun f1 (l) (append '(1) (mapcar '+ l (cdr l)) '(1)))
 (cond ((< n 1) '(1))
       ((f1 (f (1- n))))
ps. This time, I could not write the shortest code...
You're the best!  :-)
« Reply #9 on: January 14, 2011, 12:42:48 PM »
Awesome coding guys, thanks for sharing your expertise and approach to problem solving.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #10 on: January 14, 2011, 02:18:51 PM »
my new version triangle:
(defun f (n / f1)
 (if (>= n 0)
  (cons '(1) (mapcar 'f1 (f (1- n))))
« Reply #11 on: January 14, 2011, 02:38:46 PM »
I should imagine that's quite inefficient as you are repeating the (f1) calculation for all items at every level of the recursion, but still beautiful code  :-)
« Reply #12 on: January 14, 2011, 02:41:47 PM »
what I read:
what I heard:
that's ugly code but still beautiful code
:lol:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: January 14, 2011, 02:42:46 PM »
I'm trying algorithm in other ways...
« Reply #14 on: January 14, 2011, 02:46:28 PM »
'ugly' algorithm, beautifully concise code to achieve the desired result  :-)
« Reply #15 on: January 14, 2011, 04:49:02 PM »
note to self: probably shouldn't share "the voices"
doh, did it again
:-D
« Reply #16 on: January 14, 2011, 05:34:26 PM »
doh, did it again
:-D
I undestand about the 'voices' ....
I've started to discuss issues with one of the back verandah posts ... If it ignores me I don't post critiques ..
« Reply #17 on: January 16, 2011, 01:23:37 PM »
lol, figured out another by accident (was working on some thing else and went 'hey wait a second'):
    # python 3.x
    x=[[1]]
        x.append(list(map(sum,zip([0]+x[-1],x[-1]+[0]))))
    return x
python
« Reply #18 on: January 16, 2011, 02:30:55 PM »
works too:
    x=[[1]] ; f = lambda *a: list(map(sum,zip(*a)))
    for i in range(n-1): x.append(f([0]+x[-1], x[-1]+[0]))
    return x
gile
  • Marseille, France
« Reply #19 on: January 17, 2011, 03:01:22 PM »
Another F#
let rec foo l =
    match l with
    | h :: [] -> [1]
    | h :: t  -> h + t.Head :: foo t
let pascalTri n = List.scan(fun l i -> 1 :: foo l) [1] [1 .. n]
let pascalRow n = List.fold(fun l i -> 1 :: foo l) [1] [1 .. n]
Works too with :
let rec foo (l : int list) =
    if l.Tail = [] then [1] else l.Head + l.Tail.Head :: foo l.Tail
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #20 on: January 19, 2011, 07:40:18 AM »
my new version NTH:
(defun f_nth (n / f)
 (defun f (a b c)
  (if (>= b 0)
   (cons a (f (* a (/ b c)) (1- b) (1+ c)))
 (f 1. n 1.)
« Reply #21 on: January 19, 2011, 09:01:08 AM »
Fantastic Evgeniy!
A much better method to simplify the factorials than what I did here:-)
Here's how I understand your code:
Binomial Coefficient is given by:
   n!
k!(n-k)!
Your code operating on the (k-1)th iteration:
       n!              n-(k-1)         n!
----------------  x   ---------  =  --------
(k-1)!(n-(k-1))!          k         k!(n-k)!
« Last Edit: January 19, 2011, 10:10:39 AM by Lee Mac »
« Reply #22 on: January 19, 2011, 08:26:18 PM »
cool thread is cool 8-)
chlh_jd
« Reply #23 on: January 20, 2011, 12:05:02 PM »
Great!
I found (f 1. n 1.)
that the dot is very important,othewise it will take a mistake 'negative' results ,
just like
(pascalrow 1000)
gile
  • Marseille, France
« Reply #24 on: February 15, 2011, 01:33:22 PM »
Some new ways implementing fold, scan and unfold F# functions in LISP.
EDIT: new definitions so that the functions require a *quoted* function as argument (as others 'higher order' LISP functions as apply, mapcar, ...)
gc:fold
gc:fold
Returns the final state of an accumulator which initial state is changed
by applying a function to the accumulator and each item of a list.
Arguments
fun: a function (lambda or defun) which takes a state and a list item as arguments
     and returns the modified state
acc : accumulator initial state
lst ; list
(defun gc:fold (fun acc lst)
  (foreach n lst (setq acc ((eval fun) acc n)))
gc:scan
gc:scan
Returns the list of all intermediates states mor final state of an accumulator
which initial state is changed by applying a function to the accumulator and
Arguments
lst ; list
(defun gc:scan (fun acc lst)
  (cons acc (mapcar '(lambda (x) (setq acc ((eval fun) acc x))) lst))
gc:unfold
gc:unfold
Generates a list from a calculation function which takes a state
and modify it to product the next item.
Arguments
fun: a function (lambda or defun) which takes a state as argument and
     returns a list of type: (result next_state) or nil (requiered stop condition).
state: the initial state
(defun gc:unfold (fun state)
  ((lambda (r)
     (if r
       (cons (car r) (gc:unfold fun (cadr r)))
    ((eval fun) state)
(gc:fold '(lambda (a l) (mapcar '+ (cons 0 a) (append a '(0)))) '(1) '(1 2 3 4 5))returns: (1 5 10 10 5 1)
(gc:scan '(lambda (a l) (mapcar '+ (cons 0 a) (append a '(0)))) '(1) '(1 2 3 4 5))returns: ((1) (1 1) (1 2 1) (1 3 3 1) (1 4 6 4 1) (1 5 10 10 5 1))
(gc:unfold '(lambda (a)
      (if (<= (length a) 6)
(list a (mapcar '+ (cons 0 a) (append a '(0))))
   '(1)
« Last Edit: March 04, 2011, 04:33:39 PM by gile »
chlh_jd
« Reply #25 on: February 16, 2011, 08:22:50 AM »
Excellent Gile !
how can change the following code into 'gc:unfold method ?
(defun get-Ndim-IA-lst (l / a b c d e i)
  (if (< (length l) 2)
    l
      (setq a nil
   i 1
      (while (setq b (nth i l))
(if (null a)
 (setq a (car l))
(setq e nil)
(foreach c b
 (foreach d a
   (if (<= (if (listp c)
 (car c)
 c
(if (listp d)
 (car d)
 d
     (setq e
    (cons
      (if (and (null (listp c)) (listp d))
(cons c d)
(if (and (null (listp c)) (null (listp d)))
  (list c d)
  (append c d)
      e
(setq a e)
(setq i (1+ i))
      a
arg :
(setq l '((0.95 0.9 0.85 0.8 0.75 0.7 0.65 0.6 0.55 0.5) (0.95 0.9 0.85 0.8 0.75 0.7 0.65 0.6 0.55 0.5 0.45)
 (0.95 0.9 0.85 0.8 0.75 0.7 0.65 0.6 0.55 0.5 0.45 0.4) (0.95 0.9 0.85 0.8 0.75 0.7 0.65 0.6 0.55 0.5 0.45 0.4 0.35)
 (0.95 0.9 0.85 0.8 0.75 0.7 0.65 0.6 0.55 0.5 0.45 0.4 0.35 0.3)))
Returns :
((0.3 0.8 0.85 0.9 0.95) (0.3 0.75 0.8 0.9 0.95) (0.3 0.75 0.8 0.85 0.95) (0.3 0.75 0.8 0.85 0.9)
(0.3 0.75 0.85 0.9 0.95) (0.3 0.7 0.75 0.9 0.95) (0.3 0.7 0.75 0.85 0.95)...)
« Last Edit: February 16, 2011, 09:19:54 AM by chlh_jd »
krampaul82
« Reply #26 on: February 24, 2011, 05:25:29 PM »
Sigh..... :-(
« Reply #27 on: February 24, 2011, 07:13:01 PM »
