Author Topic: Problems with Breaking lines and blocks  (Read 6942 times)
ademontis
« on: January 13, 2011, 09:29:28 AM »
Hi everybody, I am a CAD engineer working for a company that handles chemical plants projects, and in my work i often have to insert blocks from a customized ToolPalete (which i created) on a polyline. The bad thing is that everytime i add a block (a valve, a steam trap, etc) I have to break lines by myself at the intersection points and delete the part of line that remains 'under' the block.
I have tried the 'AutoBlockBreak' by Lee Mac and it is very useful except it doesn't allow me to use blocks from my customized Tool Palette; I have also tried th script at:
http://www.theswamp.org/index.php?topic=25808.0
but it doesn't work well with polylines that are made up of more than one segment (I think it is because of the fact that the script only gest StartingPoint and EndPoint).
Is there a way to modify one of these script in order to accomplish the goal?
The best thing would be to add the upmentioned script with the ability to handle all middle points in a polyline.
In the attachment you find an image showing the problem.
Using the BR-LI script from the 'original situation', it doean't recognize the polyline as a 2-segmented route, and deletes a piece of it.
Thanks in advance, i hope someone may help...
it is a very importand matter for all P&IDs drafters :)
Alex
Nibster
Re: Problems with Breaking lines and blocks
« Reply #1 on: January 13, 2011, 09:38:17 AM »
if having not having breaks in the line is ok, have you tried the down-n-dirty method of using a wipeout?  You shouldn't have any troubles with those if you're using tool palettes.
issues have been found when someone tries to copy/paste wipeout'd blocks into a drawing that doesn't already have the block defined (correctly inserted).
alanjt
  • Standby for witty remark...
« Reply #2 on: January 13, 2011, 09:46:26 AM »
Lee did this one a while back...
http://lee-mac.com/autoblockbreak.html
Dropbox
ademontis
« Reply #3 on: January 13, 2011, 09:59:52 AM »
Thank you both, sadly the wipeout solution is not an option because it would mean to 'redefine' every single block, and i am not allowed to.
The script by Lee you have suggested is the same I have tried, it works fine except i am not able to adapt it to take blocks from my tolpalette instead of inserting them manually inserting the blockname.
Nibster
« Reply #4 on: January 13, 2011, 10:01:25 AM »
that is pretty sweet!  I did notice that for dynamic blocks, it defines the trimming boundary as if all geometry is turned on, not just what is visible.  not a big deal to me because having to extend the lines back to the valve symbol is still less work than trimming.
I wonder if that could be modified into a reactor so the tool palette can be used to place the blocks on the correct layer OR manually select blocks....  hmmmmm.....  ;-)
« Reply #5 on: January 13, 2011, 10:05:16 AM »
Thanks guys :-)
If lots of people want it modified I might consider changing the code around so that it may be called with an inserted block and will trim that block... this way, one could call it with (entlast) following a tool palette insertion...
alanjt
« Reply #6 on: January 13, 2011, 10:07:18 AM »
Thanks guys :-)
I think they're trying to do it from Tool Palettes.
Dropbox
Nibster
« Reply #7 on: January 13, 2011, 10:15:21 AM »
Thanks guys :-)
if it's not the last block inserted, could it be modified to work by just picking blocks to trim around?  I also find a lot of piping diagrams where the drafter just placed the symbols and never trimmed the lines in our campus databases.
« Reply #8 on: January 13, 2011, 10:28:53 AM »
Thanks guys :-)
My thoughts would be to create a sub that could be called with whatever the user chooses - a new block or existing - that way the routine has far more flexibility than it currently does.
« Reply #9 on: January 13, 2011, 10:58:32 AM »
IMO ... the mask option seems like the easiest\cleanest route. Why is it that you cannot redefine the blocks? If you have a library of blocks, you spend a day adding the mask then you never have to worry about trimming again.  :-P
In some of my blocks I use a solid background that is color 255 and it has worked well (even better than wipeouts). Attached is an example.
Nibster
« Reply #10 on: January 13, 2011, 11:01:04 AM »
does a plotter's "lines over-write" setting affect this method?
« Reply #11 on: January 13, 2011, 11:19:41 AM »
You know ... I'm not sure  :?. 99% of our deliverables are PDF's and it has worked flawlessly with them.
« Reply #12 on: January 13, 2011, 01:47:35 PM »
I think it depends on the PDF Printer - some people report that wipeouts show up, others don't.
Nibster
« Reply #13 on: January 13, 2011, 01:49:28 PM »
oh yeah, i remember now.  THAT'S why the '255' fix is used, because wipeouts show up as black boxes in the ADOBE & 'dwg to pdf.pc3' drivers.
dgorsman
« Reply #14 on: January 13, 2011, 02:04:42 PM »
Commercial P&ID packages are pretty cheap and will manage all this for you.  I know its tempting to roll your own, but from experience its not worth it.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
