This is copied from
http://www.cadtutor.net/forum/showthread.php?55948-.NET-Getting-a-block-nameI did not know how to insert pictures so posted here
When you change the properties of a dynamic block it creates an anonymous block.
This is a simple example to delete the block references and delete the block references of the anonymous blocks created by the dynamic block.
Is hard-coded for a block named "C"
<CommandMethod("DeleteAllBlockReference")> _
Public Sub DeleteAllBlockReference()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Using trx As Transaction = db.TransactionManager.StartTransaction()
Dim bt As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
Dim btr As BlockTableRecord = bt("C").GetObject(OpenMode.ForRead)
For Each objId As ObjectId In btr.GetBlockReferenceIds(True, True)
Dim ent As Entity = objId.GetObject(OpenMode.ForWrite)
ent.Erase()
Next
Dim anonBlkIds As ObjectIdCollection = btr.GetAnonymousBlockIds
For Each btrObjId As ObjectId In anonBlkIds
Dim anonBtr As BlockTableRecord = btrObjId.GetObject(OpenMode.ForRead)
For Each objId As ObjectId In anonBtr.GetBlockReferenceIds(True, True)
ent.Erase()
Next
Next
trx.Commit()
End Using
End Sub
The first pic shows 10 or so dynamic blocks inserted.
The second pic shows after 4 of the dynamic properties have been changed
