Author Topic: My first programming exercise for college  (Read 15792 times)
uncoolperson
Re: My first programming exercise for college
« Reply #30 on: January 19, 2011, 09:16:42 PM »
I got a fun one coming up... just gotta wait for it to be assigned (the for me to do it), and I'll post it here as a challenge.
(involves recursion!!!)
I ain't doin' ya homewerk buddy
that's why I was going to wait until I was done.
« Reply #31 on: January 19, 2011, 09:20:47 PM »
:-P  :-P
uncoolperson
« Reply #32 on: January 19, 2011, 09:24:01 PM »
just trust me dude... it'll be a lot more entertaining then hello world in a couple of languages
« Reply #33 on: January 19, 2011, 11:35:10 PM »
Hey now ... I was at least a bit creative and used Klingon (I hope the instructor has a sense of humor)
Jeff H
« Reply #34 on: January 19, 2011, 11:44:37 PM »
I was going to post that probably some nerd wrote a computer language in klingon, but decided to google it and was right.
Klingon computer programming language
Var'aq is a programming language for those that speak Klingon. Here's "Hello world" in var'aq:
~ nuqneH { ~ 'u' ~ nuqneH disp disp } name
nuqneH
Roughly translated, it means "What do you want, universe?"
http://kottke.org/03/01/klingon-computer-programming-language
http://www.trektoday.com/news/070800_05.shtml
uncoolperson
« Reply #36 on: January 20, 2011, 12:05:15 AM »
I don't care that no one ever see's it, inserting fun is well... just fun.
FUNCTION Tales_From_The_Cryption_Keeper
Put("Sorry Jack Ryan, you don't have high enough clearance for that");
« Reply #37 on: January 20, 2011, 12:39:40 AM »
nuqneH
Well, your source is close ... the actual text would be
nuqneH qo'
nuqneH: what do you want? Greetings (excl.)
qo':  world, realm (n)
But then I also took the liberty of changing the other text on the form as well ... for example, instead of "Exit" I put
Qaw' ngoqDe'
Qaw': destroy (v)
ngoqDe': code - encoded message (n)
So, basically telling the user to "destroy encoded message"
It isn't exactly 100%, but any person capable of understanding Klingon would understand the phrase.
Another little thing I added was to change the window title to the language of choice. The instructor said to put our name in the title along with the Hello World phrase. In English it would be "Hello World - By Keith™" but in Klingon it is as so:
nuqneH qo' - ghajwI' Keith™
ghajwI':  one/thing which is/does/   have, possess (v)
Roughly translated to: Hello World - Owner Keith™
It was quite fun ;-) I think maybe I'll do more Klingon stuff in the future ... as long as this doesn't backfire on me ;-)
uncoolperson
« Reply #38 on: February 08, 2011, 07:36:20 PM »
just turned in my recursive soduko solver...
« Reply #39 on: February 09, 2011, 12:13:38 AM »
So, my instructor gave me 100/100 on the first two assignments - hello world and some other bizarre application that displays different text depending on which radiobutton and checkbox you pick. For my last four projects, I have taken considerable liberty with my programming. I've introduced things that aren't in the scope of the class ... things like GDI printing, structs, enums and <gasp> even data driven error control.
I find it to be laziness when programmers users rely on Try/Catch blocks to prevent invalid data from being entered.
The textbook says to use a Try/Catch block to prevent a user from entering text in a numeric textbox. I prefer to simply find out if the text is numeric before I try to act on it ...
Why would I use
Try
  ThisVar = Cint(TextBox1.Text)
Catch ex As Exception
  MsgBox(e.Message)
End Try
When this will give a better result and allow you to filter stuff as you go.
If IsNumeric(TextBox1.Text) Then
Else
  MsgBox("TextBox1 can contain only numbers")
End If
Maybe it is just me, but I hate like hell seeing those errors line up in the immediate window ..
Heck, I even use Option Strict and treat all warnings as errors ... in the end, the code is much more stable.
Oh well, such is life.
pkohut
« Reply #40 on: February 09, 2011, 01:08:13 AM »
Well Keith, have to agree with the book on this one. Since CInt throws an error, it makes sense to use the try catch block. It's by design. Also, the approach you suggest doubles the work load if the value is numeric, by first checking, then converting. If the input data needs validation between a range, then try/catch/finally is the proper solution.
New tread (not retired) - public repo at https://github.com/pkohut
dan.glassman
« Reply #41 on: February 09, 2011, 09:26:20 AM »
Your code contains a bug.  Enter "2,147,483,648" into the TextBox, and you should get an OverflowException.
It may also be a bug because the value of the TextBox isn't under your sole control, and may change between the If and the CInt.  I'm not sure if that's true in this case, but this (for example) would definitely be a bug:
if (File.Exists(f))
   File.Open(f)
-drg
« Reply #42 on: February 09, 2011, 09:41:19 AM »
We will have to agree to disagree here ... the workload is doubled on the programmer perhaps in writing code, but the processor workload is negligibly impacted by the extra call to IsNumeric.
Using that logic, it would be ok to use a loop and then a "On Error Resume Next" simply because .. well, it must not be what we wanted so lets just ignore it.
if (File.Exists(f))
   File.Open(f)
-drg
It doesn't when the box is limited to 5 characters ... its all about design. Understand what can be entered and then you can understand the minimum code needed to handle it.
Incidently the text actually insists that all numbers are parsed using the Parse method of the expected type ... whether that is Decimal, Integer, Double or Long ..
It's Alive!
  • Retired
  • AKA Daniel
« Reply #43 on: February 09, 2011, 10:04:58 AM »
pkohut
« Reply #44 on: February 09, 2011, 10:17:27 AM »
More along the lines of don't have redundant code. In the provided example, try/catch is the proper way to convert the input to an int. Why fight the language and API?
