Author Topic: Is there something better than vl-string-subst?  (Read 8073 times)
Krushert
  • FREE BEER Tomorrow!!
« on: January 07, 2011, 01:21:03 PM »
I have more crashes with vl-string-subst function because it looking for a specific value.  I really do not care what the value is or where it is located.  I just want to swap out the last folder name for the new folder name.  Is there a better function or can I reconfigure the mess below.
OLD   :// server //Some spiraling downward path of folders // drawings folder // XYZ-file  This never has a consistent folder name or path.
NEW  :// server //Some spiraling downward path of folders // transfer-outgoing-folder // XYZ-file
(defun StrPath (/ CTABNAME NewDwgPreFix OldDwgPreFix)
  (setq CTABNAME (getvar "ctab"))
  (setq OldDwgPreFix (getvar "dwgprefix"))
; Extracts the Drawing Location
  (setq NewDwgPreFix
(vl-string-subst ; Swaps folders from teh existing path
  "\\Transfer-Outgoing\\"
  "\\Drawings\\"    [color=red]<== I really do not care what this folder is named[/color][/b]
  OldDwgPreFix
  (today) ; Calls the Today's Date Sub-Function
  (setq NewFileName (strcat NewDwgPreFix Dates CTABNAME))
; Text String for New File Name
  (vl-mkdir NewDwgPreFix) ; checks to see if new folder is present and if not creates.
Re: Is there something better than vl-string-subst?
« Reply #1 on: January 07, 2011, 01:30:09 PM »
Something along these lines?
(defun StrPath ( / path )
  (setq path (vl-string-translate "/" "\\" (getvar 'DWGPREFIX)))
  (if (eq "\\" (substr path (strlen path)))
    (setq path (substr path 1 (1- (strlen path))))
  (setq path (strcat (substr path 1 (vl-string-position 92 path nil t)) "\\Transfer-Outgoing\\"))
  (vl-mkdir path)
Krushert
« Reply #2 on: January 07, 2011, 02:23:39 PM »
OKay I see what you are doing, A little bit.  Thanks
How does 92 play in with the vl-string-position?
« Reply #3 on: January 07, 2011, 02:25:58 PM »
Hint:
Command: (chr 92)
Krushert
« Reply #4 on: January 07, 2011, 03:01:19 PM »
Hint:
Command: (chr 92)
Aha!  Where does one find the secrete decoder ring for these numbers?
« Reply #5 on: January 07, 2011, 03:17:32 PM »
Try something like this:
(defun c:getascii (/ x)
  (while (and (setq x (grread)) (/= (car x) 3))
    (princ "\rPress a key any key ... pick a point to exit loop")
    (and (= (car x) 2) (alert (strcat (chr (cadr x)) " = " (itoa (cadr x)))))
(c:getascii)
« Reply #6 on: January 07, 2011, 03:58:36 PM »
fwiw ... a quick & dirty little proggy:
(defun c:ASCII ( / _rset _chr spacer1 spacer2 i j k )
    (defun _rset ( x len )
        (setq x (vl-princ-to-string x))
        (while (< (strlen x) len)
            (setq x (strcat " " x))
        x
    (defun _chr ( code )
        (if (member code '(129 141 143 144 157 160 173))
            (chr code)
    (setq
        i        31
        spacer1  " "
        spacer2  "        "
    (princ "Codes 1 to 31 are control codes, some notable ones:\n\n")
    (princ
        (strcat
            "  7 bell\n"
            "  9 tab\n"
            " 10 line feed\n"
            " 13 carriage return\n"
            " 27 escape\n\n"
    (princ "7 Bit ASCII codes:\n\n")
    (repeat 32
        (setq i (1+ i) j -32)
        (repeat 3
            (princ
                (strcat
                    (_rset (setq k (+ i (setq j (+ j 32)))) 3)
                    spacer1
                    (_chr k)
                    spacer2
        (princ "\n")
    (princ "\nExtended ASCII codes:\n\n")
    (setq i 127 spacer2 "    ")
    (repeat 16
        (setq i (1+ i) j -16)
        (repeat 8
            (princ
                (strcat
                    (_rset (setq k (+ i (setq j (+ j 16)))) 3)
                    spacer1
                    (_chr k)
                    spacer2
        (princ "\n")
Prints out:
ASCII Codes 1 to 31 are control codes, some notable ones:
  7 bell
  9 tab
 10 line feed
 13 carriage return
 27 escape
7 Bit ASCII codes:
 32           64 @         96 `
 33 !         65 A         97 a
 34 "         66 B         98 b
 35 #         67 C         99 c
 36 $         68 D        100 d
 37 %         69 E        101 e
 38 &         70 F        102 f
 39 '         71 G        103 g
 40 (         72 H        104 h
 41 )         73 I        105 i
 42 *         74 J        106 j
 43 +         75 K        107 k
 44 ,         76 L        108 l
 45 -         77 M        109 m
 46 .         78 N        110 n
 47 /         79 O        111 o
 48 0         80 P        112 p
 49 1         81 Q        113 q
 50 2         82 R        114 r
 51 3         83 S        115 s
 52 4         84 T        116 t
 53 5         85 U        117 u
 54 6         86 V        118 v
 55 7         87 W        119 w
 56 8         88 X        120 x
 57 9         89 Y        121 y
 58 :         90 Z        122 z
 59 ;         91 [        123 {
 60 <         92 \        124 |
 61 =         93 ]        125 }
 62 >         94 ^        126 ~
 63 ?         95 _        127
128 €    144      160      176 °    192 À    208 Ð    224 à    240 ð
129      145 ‘    161 ¡    177 ±    193 Á    209 Ñ    225 á    241 ñ
130 ‚    146 ’    162 ¢    178 ²    194 Â    210 Ò    226 â    242 ò
131 ƒ    147 “    163 £    179 ³    195 Ã    211 Ó    227 ã    243 ó
132 „    148 ”    164 ¤    180 ´    196 Ä    212 Ô    228 ä    244 ô
133 …    149 •    165 ¥    181 µ    197 Å    213 Õ    229 å    245 õ
134 †    150 –    166 ¦    182 ¶    198 Æ    214 Ö    230 æ    246 ö
135 ‡    151 —    167 §    183 ·    199 Ç    215 ×    231 ç    247 ÷
136 ˆ    152 ˜    168 ¨    184 ¸    200 È    216 Ø    232 è    248 ø
137 ‰    153 ™    169 ©    185 ¹    201 É    217 Ù    233 é    249 ù
138 Š    154 š    170 ª    186 º    202 Ê    218 Ú    234 ê    250 ú
139 ‹    155 ›    171 «    187 »    203 Ë    219 Û    235 ë    251 û
140 Œ    156 œ    172 ¬    188 ¼    204 Ì    220 Ü    236 ì    252 ü
141      157      173      189 ½    205 Í    221 Ý    237 í    253 ý
142 Ž    158 ž    174 ®    190 ¾    206 Î    222 Þ    238 î    254 þ
143      159 Ÿ    175 ¯    191 ¿    207 Ï    223 ß    239 ï    255 ÿ
Edit: Revised code a bit to slay a cockroach.
« Last Edit: January 07, 2011, 11:39:39 PM by MP »
Krushert
« Reply #7 on: January 07, 2011, 04:11:00 PM »
Thanks,   I will try to remember where these decoder rings are buried.   :-)
« Reply #8 on: January 07, 2011, 04:14:57 PM »
Quote from: my slumber was rudely interupted by MP
An excellent example of taking a problem and providing an economical solution with style.
« Last Edit: January 07, 2011, 10:54:02 PM by Kerry »
« Reply #9 on: January 07, 2011, 04:39:11 PM »
Have to do lisp here and there while I study Python lest I lose valuable lispin' skills.
Thanks for the kind words KB.
« Reply #10 on: January 07, 2011, 04:50:36 PM »
Michael .. .your "quickly" penned stuff is leaps and bounds better than my thought out code  :-D
Here's a list from 33 - 255.
33     !
34     "
35     #
36     $
37     %
38     &
39     '
40     (
41     )
42     *
43     +
44     ,
45     -
46     .
47     /
48     0
49     1
50     2
51     3
52     4
53     5
54     6
55     7
56     8
57     9
58     :
59     ;
60     <
61     =
62     >
63     ?
64     @
65     A
66     B
67     C
68     D
69     E
70     F
71     G
72     H
73     I
74     J
75     K
76     L
77     M
78     N
79     O
80     P
81     Q
82     R
83     S
84     T
85     U
86     V
87     W
88     X
89     Y
90     Z
91     [
92     \
93     ]
94     ^
95     _
96     `
97     a
98     b
99     c
100     d
101     e
102     f
103     g
104     h
105     i
106     j
107     k
108     l
109     m
110     n
111     o
112     p
113     q
114     r
115     s
116     t
117     u
118     v
119     w
120     x
121     y
122     z
123     {
124     |
125     }
126     ~
127
128     €
129
130     ‚
131     ƒ
132     „
133     …
134     †
135     ‡
136     ˆ
137     ‰
138     Š
139     ‹
140     Œ
141
142     Ž
143
144
145     ‘
146     ’
147     “
148     ”
149     •
150     –
151     —
152     ˜
153     ™
154     š
155     ›
156     œ
157
158     ž
159     Ÿ
160
161     ¡
162     ¢
163     £
164     ¤
165     ¥
166     ¦
167     §
168     ¨
169     ©
170     ª
171     «
172     ¬
173     ­
174     ®
175     ¯
176     °
177     ±
178     ²
179     ³
180     ´
181     µ
182     ¶
183     ·
184     ¸
185     ¹
186     º
187     »
188     ¼
189     ½
190     ¾
191     ¿
192     À
193     Á
194     Â
195     Ã
196     Ä
197     Å
198     Æ
199     Ç
200     È
201     É
202     Ê
203     Ë
204     Ì
205     Í
206     Î
207     Ï
208     Ð
209     Ñ
210     Ò
211     Ó
212     Ô
213     Õ
214     Ö
215     ×
216     Ø
217     Ù
218     Ú
219     Û
220     Ü
221     Ý
222     Þ
223     ß
224     à
225     á
226     â
227     ã
228     ä
229     å
230     æ
231     ç
232     è
233     é
234     ê
235     ë
236     ì
237     í
238     î
239     ï
240     ð
241     ñ
242     ò
243     ó
244     ô
245     õ
246     ö
247     ÷
248     ø
249     ù
250     ú
251     û
252     ü
253     ý
254     þ
255     ÿ
« Reply #11 on: January 07, 2011, 06:42:20 PM »
And after 20 years I'm still using this:  :-D
David Bethel
« Reply #12 on: January 08, 2011, 06:08:43 AM »
I still like this 1:
http://www.asciitable.com/
I use the html and hex values as well.  -David
R12 Dos - A2K
« Reply #13 on: January 08, 2011, 09:15:46 AM »
Version 2, dumbed down / simplified:
(defun c:ASCII ( / _lset _rset _chr _main )
    (defun _lset ( x len )
            (setq x (strcat x " "))
        x
        x
    (defun _chr ( code / char len )
        (setq len 6)
        (strcat " "
                (   (setq char
                        (nth code
                           '("NUL" "SOH" "STX" "ETX" "EOT" "ENQ" "ACK" "BEL"
                             "BS"  "TAB" "LF"  "VT"  "FF"  "CR"  "SO"  "SI"
                             "DLE" "DC1" "DC2" "DC3" "DC4" "NAK" "SYN" "ETB"
                             "CAN" "EM"  "SUB" "ESC" "FS"  "GS"  "RS"  "US" "SPC")
                    (_lset char len)
                (   (member code '(127 129 141 143 144 157 160 173))
                    (_lset " " len)
                (   t
                    (_lset (chr code) len)
    (defun _main ( / i j k )
        (setq i -1)
        (repeat 32
            (princ "\n")
            (repeat 8
                (princ
                    (strcat
                        (_chr k)
    (_main)
Output:
  0 NUL    32 SPC    64 @      96 `     128 €     160       192 À     224 à
  1 SOH    33 !      65 A      97 a     129       161 ¡     193 Á     225 á
  2 STX    34 "      66 B      98 b     130 ‚     162 ¢     194      226 â
  3 ETX    35 #      67 C      99 c     131 ƒ     163 £     195 à    227 ã
  4 EOT    36 $      68 D     100 d     132 „     164 ¤     196 Ä     228 ä
  5 ENQ    37 %      69 E     101 e     133 …     165 ¥     197 Å     229 å
  6 ACK    38 &      70 F     102 f     134 †     166 ¦     198 Æ     230 æ
  7 BEL    39 '      71 G     103 g     135 ‡     167 §     199 Ç     231 ç
  8 BS     40 (      72 H     104 h     136 ˆ     168 ¨     200 È     232 è
  9 TAB    41 )      73 I     105 i     137 ‰     169 ©     201 É     233 é
 10 LF     42 *      74 J     106 j     138 Š     170 ª     202 Ê     234 ê
 11 VT     43 +      75 K     107 k     139 ‹     171 «     203 Ë     235 ë
 12 FF     44 ,      76 L     108 l     140 Œ     172 ¬     204 Ì     236 ì
 13 CR     45 -      77 M     109 m     141       173       205 Í     237 í
 14 SO     46 .      78 N     110 n     142 Ž     174 ®     206 Π    238 î
 15 SI     47 /      79 O     111 o     143       175 ¯     207 Ï     239 ï
 16 DLE    48 0      80 P     112 p     144       176 °     208 Р    240 ð
 17 DC1    49 1      81 Q     113 q     145 ‘     177 ±     209 Ñ     241 ñ
 18 DC2    50 2      82 R     114 r     146 ’     178 ²     210 Ò     242 ò
 19 DC3    51 3      83 S     115 s     147 “     179 ³     211 Ó     243 ó
 20 DC4    52 4      84 T     116 t     148 ”     180 ´     212 Ô     244 ô
 21 NAK    53 5      85 U     117 u     149 •     181 µ     213 Õ     245 õ
 22 SYN    54 6      86 V     118 v     150 –     182 ¶     214 Ö     246 ö
 23 ETB    55 7      87 W     119 w     151 —     183 ·     215 ×     247 ÷
 24 CAN    56 8      88 X     120 x     152 ˜     184 ¸     216 Ø     248 ø
 25 EM     57 9      89 Y     121 y     153 ™     185 ¹     217 Ù     249 ù
 26 SUB    58 :      90 Z     122 z     154 š     186 º     218 Ú     250 ú
 27 ESC    59 ;      91 [     123 {     155 ›     187 »     219 Û     251 û
 28 FS     60 <      92 \     124 |     156 œ     188 ¼     220 Ü     252 ü
 29 GS     61 =      93 ]     125 }     157       189 ½     221 Ý     253 ý
 30 RS     62 >      94 ^     126 ~     158 ž     190 ¾     222 Þ     254 þ
 31 US     63 ?      95 _     127       159 Ÿ     191 ¿     223 ß     255 ÿ
« Reply #14 on: January 08, 2011, 09:47:55 AM »
If you have DOS Lib (if you don't, dude, wtf) this is hard to beat (pick whatever graphic suits you from the multitudes on the net):
(defun c:ASCII ( )
    (dos_htmlbox
        "Standard ASCII Codes"
        "http://www.tvdsb.ca/webpages/herbertj/files/ASCII1.GIF"
An aside, most IDEs / text editors have built in ASCII charts, Textpad, UltraEdit ...
