Author Topic: Layers  (Read 2549 times)
42
Layers
« on: January 12, 2005, 12:12:55 PM »
2005 ADT
When I select the Layer Properties Manager button the layer dialogue box does not appear. ACad goes into pause mode untill I hit escape. Typing _layer at the conmmand has the same effect. Any thoughts as its driving me nuts.
Alastair
Technical Director
Hunters South Architects
Layers
« Reply #1 on: January 12, 2005, 12:53:49 PM »
Have you tried -layer to see if it is put on the command line? Or try .layer....I think putting the period before ensures that the native acad command is used.
Ron
42
Layers
« Reply #2 on: January 12, 2005, 12:56:50 PM »
That works ok. But have you tried working with the layers this way? Yer yer I know we used to do it this way, but I had hoped that we had moved on somewhat. Thanks.
Technical Director
Layers
« Reply #3 on: January 12, 2005, 12:58:14 PM »
So the -layer work or the .layer works? Is CMDDIA is set to 1?
CADaver
Layers
« Reply #4 on: January 12, 2005, 01:12:09 PM »
If .layer (DOTlayer) works, by that I mean opens the layer manager dialog box, it sounds as if the layer command has been redefined somewhere.
42
Layers
« Reply #5 on: January 12, 2005, 05:06:13 PM »
The -layer works, sorry did not try.layer, Im' at home now. Will try again tomorrow. I am presumining that ddima is set to 1 as all other dialogue boxes open.
Thanks.
Edit Nope .layer has the same effect as above.
Technical Director
