Author Topic: Setting a Text Style Current and Making Updates  (Read 6520 times)
MGorecki
« on: January 06, 2011, 01:19:53 PM »
Hello,
I have code that will bring in a text style from another drawing, but it is still raw in that a text hight needs to be set.  How can I find the text style in the style table and make it current, then change the text height?
I know I can change the text height using "myTextSyle = dwgTextHeight", but how do I get the style name (ROMANS) to be current?
Thanks,
gile
  • Marseille, France
Re: Setting a Text Style Current and Making Updates
« Reply #1 on: January 06, 2011, 01:25:12 PM »
Hi
Application.SetSystemVariable("TEXTSTYLE", yourTextStyle);
MGorecki
« Reply #2 on: January 06, 2011, 02:54:47 PM »
Hello Gile,
Thanks, I'll give that a try.
MGorecki
« Reply #3 on: January 06, 2011, 04:10:40 PM »
I tried what you said, but maybe I'm doing it wrong (I'm pretty new to VB.Net, so I wouldn't be surprised).
Here is my code:
    Public Sub UpdateTextStyle(ByVal dwgTextHeight As Double)
        Dim myDWG As ApplicationServices.Document
        Dim myDB As DatabaseServices.Database
        myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myDB = myDWG.Database
        'Locate the text style "ROMANS" in the text style table
        Using styleTrans As Transaction = myDB.TransactionManager.StartTransaction
            Dim txtStyleTbl As TextStyleTable = myDB.TextStyleTableId.GetObject(OpenMode.ForRead)
            For Each objId As ObjectId In txtStyleTbl
                Dim txtStyleTableRec As TextStyleTableRecord = objId.GetObject(OpenMode.ForRead)
                If txtStyleTableRec.Name = "ROMANS" Then
                    Application.SetSystemVariable("TEXTSTYLE", "ROMANS")
                End If
            Next
            styleTrans.Commit()
            styleTrans.Dispose()
        End Using
        'Start a transaction
        Using myTrans As Transaction = myDB.TransactionManager.StartTransaction()
            'Open the current text style for write
            Dim myTSTR As TextStyleTableRecord
            myTSTR = myTrans.GetObject(myDB.Textstyle, OpenMode.ForWrite)
            myTSTR.TextSize = dwgTextHeight
            'Save the changes and dispose of the transaction
            myTrans.Commit()
            myTrans.Dispose()
        End Using
Can you see what I'm doing wrong?
MGorecki
« Reply #4 on: January 06, 2011, 04:30:45 PM »
Never mind, that code works.  I just made a dumb mistake.
kaefer
« Reply #5 on: January 06, 2011, 05:12:40 PM »
Here is my code:
You aren't wrong, and I don't speak VB.  So just a couple of hints:
                End If
            Next
You could use the Has property instead. Database.Textstyle should be settable, too.
               If txtStyleTbl.Has("ROMANS") Then
                    myDB.Textstyle = txtStyleTbl("ROMANS")
                End If
        End Using
The Using statement takes care of disposing, so you don't need to call Dispose(). It wouldn't even be called if there were an exception before it was reached; not so with the implicit Try-Finally of Using.
Cheers
« Last Edit: January 06, 2011, 05:21:32 PM by kaefer »
dan.glassman
« Reply #6 on: January 06, 2011, 06:47:16 PM »
Since you are starting a transaction, you should use the Transaction.GetObject() method instead of the ObjectId.GetObject() method to open the table (which I see you are doing in your second transaction to change the text height).  Mixing ObjectId.GetObject() with transactions is considered harmful [might work okay in this case, but it's good practice to not mix the two.]
You can perform both operations in a single transaction.
Updated [with apologies if I'm getting VB.Net syntax incorrect]:
    Dim txtStyleTbl As TextStyleTable = [color=red]styleTrans[/color].GetObject([color=red]myDb.TextStyleTableId[/color], OpenMode.ForRead)
        Dim romansId as ObjectId = txtStyleTbl("ROMANS")
        Dim romans as TextStyleTableRecord = styleTrans.GetObject(romansId, OpenMode.ForWrite)
        romans.TextSize = dwgTextHeight
        myDb.Textstyle = romansId 'sets current text style -- an alternative to Application.SetSystemVariable
    End If
    styleTrans.Commit
End Using
                End If
            Next
End Using
fixo
« Reply #7 on: January 07, 2011, 02:47:38 AM »
Hi Dan
You're absolutely right
Welcome on board!
Cheers :)
