Author Topic: manipulating layers in a block  (Read 4129 times)
Re: manipulating layers in a block
« Reply #15 on: January 08, 2011, 11:23:16 PM »
Just so everyone knows ACAD2000 will create a block with the CURRENT layer embedded in the (0 . "ENDBLK") entity.
This will stop it from purging that layer.
See a copy of FixBlock.lsp
Can't recall the AC2000 version Alan, but I have 2 versions by Owen Wengerd ( http://www.manusoft.com ) dated 1996 and 1998 ... from CompuServe era :)
added:
In fact, Owen still has a version on his site
http://www.manusoft.com/software/freebies/lisp.html
« Reply #16 on: January 09, 2011, 08:31:20 AM »
That's the one Kerry. Thanks for the link.
I modified my copy to remove '(71 . 1)   It was in 2004 I think but I could not find the thread.
Not sure when that ACAD bug went away, maybe version 2002?
