Author Topic: Pipe Invert Labels in Profile  (Read 8576 times)
dfarris75
« on: January 05, 2011, 04:15:21 PM »
I am attempting to create a label style to label the inverts of my pipes in profile. I created a component for "flow direction arrow", "up invert", and "down invert". The up invert and down invert use the flow direction arrow begin and end respectively as the anchor. The flow direction arrow is set to use the bottom inner diameter of the pipe (begin and end) as the anchor point.
The problem is that with the pipes that flow from right to left in the profile view it is placing the flow direction arrow on the top inner diameter instead of the bottom...?
Anyone know how to fix that?
jugglerbri
Re: Pipe Invert Labels in Profile
« Reply #1 on: January 05, 2011, 04:38:13 PM »
Perhaps an expression would do the trick. Something along the lines of...
IF({Pipe Start Station}<{Pipe End Station},pi/2,3*pi/2)
and apply that to the rotation of the label.
If you need some more help with expressions, and you have access to it, I did a class at AU2009 on expressions:
http://au.autodesk.com/?nd=class&session_id=5143
« Reply #2 on: January 05, 2011, 04:39:39 PM »
post or send me a copy of what you have...and I'll fold spindle and mutilate it to see what I can advise you to do.
If I understand it is using WRONG anchor/insertion point, not pointing arrow in wrong direction; right?
dfarris75
« Reply #3 on: January 05, 2011, 04:47:51 PM »
The flow direction arrow is pointing the correct direction. It's just placing it at the "top inner diameter" instead of the "bottom inner diameter" for some reason. It appears to only do this on the pipes that flow from right to left within the profile view. I thought it perhaps might have something to do with the flow direction settings in the pipe props, but I'm not so sure... strangeness
« Reply #4 on: January 05, 2011, 05:59:43 PM »
Thought so; just wanted to qualify that before you went down the expression(s) rabbit hole.
You sending me a file yet?
dfarris75
« Reply #5 on: January 06, 2011, 09:13:48 AM »
No. I don't want to get in trouble with the teacher for cheating.
« Reply #6 on: January 06, 2011, 09:24:35 AM »
what teacher would that be?    :wink:
dfarris75
« Reply #7 on: January 06, 2011, 09:33:38 AM »
file is en route...
perhaps there is a better way to accomplish the pipe invert labels? i notice when i have a pipe that spans two profile views the label doesn't work efficiently.
« Last Edit: January 06, 2011, 09:37:46 AM by rustysilo »
« Reply #8 on: January 06, 2011, 09:39:55 AM »
file is en route
Apparemment, ce serait votre professeur de français.
 :lmao:
dfarris75
« Reply #9 on: January 06, 2011, 10:03:39 AM »
Ne pas être un clown.  :-P
« Reply #10 on: January 06, 2011, 10:04:23 AM »
Do you have a particualr Pipe Run and Station where this is happening?
Either I can't see it where it is happening, OR simply opening the file in 2011 'solves' the issue.
And I know that isn't an acceptable answer for your case.
« Reply #11 on: January 06, 2011, 10:06:13 AM »
Je ne suis pas un clown, mais j'ai été pris pour un mime au moins une fois.
dfarris75
« Reply #12 on: January 06, 2011, 10:12:46 AM »
Mieux vaut un mime d'une morue.  :-D
Actually there likely aren't any instances of the label in there unless you add them. I think I had only added a few and then deleted them. Try adding a few in there...
« Reply #13 on: January 06, 2011, 10:16:13 AM »
OH...so I'm looking for labels that ARE NOT even placed on the pipes....nice!
I though I was losing my mind. (or at least my codpiece)
« Reply #14 on: January 06, 2011, 10:22:30 AM »
I think I fixed the issue without knowing....
Before you answered I had changed the order of your components.
you had:
Up Inv
Flow direction
Dn Inv
This produced wrong anchorage
I changed to
Flow direction
Up Inv
Dn Inv
Anchor point appears to be honored
Also you want to look in to using the SPANNING pipes labels when your pipes SPAN profile views.
