Author Topic: Boundary command issues 2010  (Read 1719 times)
57Napco
« on: January 04, 2011, 09:30:44 PM »
I am having these problems when using the boundary command. If you look closely at the cyan and yellow lines you'll notice a gap. The cyan line isn't going out all the way and then it appears the line will bypass the jog in the wall. The yellow lines are regular lines on a trash layer to create the boundary. Has anyone had this prolem and is there a fix or patch available for it?
Re: Boundary command issues 2010
« Reply #1 on: January 09, 2011, 12:22:10 PM »
Check your GAPTOL variable.
or perhaps use MPEDIT>>Join>>and look into the FUZZ distance setting
