I am having these problems when using the boundary command. If you look closely at the cyan and yellow lines you'll notice a gap. The cyan line isn't going out all the way and then it appears the line will bypass the jog in the wall. The yellow lines are regular lines on a trash layer to create the boundary. Has anyone had this prolem and is there a fix or patch available for it?
