Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Layers
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Layers (Read 2571 times)
42
Bull Frog
Layers
on:
January 12, 2005, 12:12:55 PM »
2005 ADT
When I select the Layer Properties Manager button the layer dialogue box does not appear. ACad goes into pause mode untill I hit escape. Typing _layer at the conmmand has the same effect. Any thoughts as its driving me nuts.
Alastair
Logged
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
Needs a day job
Layers
Reply #1 on:
January 12, 2005, 12:53:49 PM »
Have you tried -layer to see if it is put on the command line? Or try .layer....I think putting the period before ensures that the native acad command is used.
Ron
Logged
42
Bull Frog
Layers
Reply #2 on:
January 12, 2005, 12:56:50 PM »
That works ok. But have you tried working with the layers this way? Yer yer I know we used to do it this way, but I had hoped that we had moved on somewhat. Thanks.
Logged
Technical Director
Needs a day job
Layers
Reply #3 on:
January 12, 2005, 12:58:14 PM »
So the -layer work or the .layer works? Is CMDDIA is set to 1?
Logged
CADaver
Guest
Layers
Reply #4 on:
January 12, 2005, 01:12:09 PM »
If .layer (DOTlayer) works, by that I mean opens the layer manager dialog box, it sounds as if the layer command has been redefined somewhere.
Logged
42
Bull Frog
Layers
Reply #5 on:
January 12, 2005, 05:06:13 PM »
The -layer works, sorry did not try.layer, Im' at home now. Will try again tomorrow. I am presumining that ddima is set to 1 as all other dialogue boxes open.
Thanks.
Edit Nope .layer has the same effect as above.
Logged
Technical Director
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
Layers
