[color=red]([/color][color=blue]acet-ss-drag-move[/color] ss pt [prompt] [highlight [cursor]][color=red])[/color][color=green]Drag a selection set to change location.[/color][color=navy]Arguments[/color]ss: [color=green]The selection set to drag.[/color] pt: [color=green]The base point[/color]. prompt: [color=green]A message to display before dragging is started.[/color] highlight: [color=green]If given, causes a rubber-band line to be drawn from pt to the current cursor position while dragging; this parameter can be nil to draw a rubber-band line in the inverse of the screen color, or non-nil to draw a highlighted line. [/color]cursor: [color=green]The cursor form to display while dragging (0=crosshairs, 1=no cursor, 2=target). [/color][color=navy]Return Values[/color][color=green]Normally returns the selected point, but will honor initget settings and can return arbitrary text or keywords.Returns nil if the dragging operation is aborted.[/color][color=navy]Note:[/color][color=green]The[/color] [color=blue]acet-ss-drag-move[/color][color=green] function does not move the selection set, but allows selection of a new position while showing how the result will appear. [/color]
