Author Topic: open an MS word doc with lisp  (Read 4921 times)
andrew_nao
« on: January 04, 2011, 10:10:50 AM »
im attempting to open an MS word doc with lisp
ndir = "F:/directory name with spaces"
(startapp "\"C:/Program Files (x86)/Microsoft Office/Office/winword.exe\"" ndir)
the issue im having is it opens ms word but pops up with an alert telling me the document path is invalid
can anyone offer some thoughts on what im doing wrong?
Re: open an MS word doc with lisp
« Reply #1 on: January 04, 2011, 10:15:09 AM »
forward slashes nfg?
Matt__W
  • I like my water diluted.
« Reply #2 on: January 04, 2011, 10:19:30 AM »
Maybe? (been a while since I've LSP'ed)
(startapp (strcat "C:/Program Files (x86)/Microsoft Office/Office/winword.exe " ndir))
Autodesk Expert Elite
« Reply #3 on: January 04, 2011, 10:29:39 AM »
try:
ndir = "\"F:\\directory name with spaces\\docname.doc""
(startapp "\"C:\\Program Files (x86)\\Microsoft Office\\Office\\winword.exe\"" ndir)
andrew_nao
« Reply #4 on: January 04, 2011, 11:09:57 AM »
thanks for the replies
but i still get the same error
« Reply #5 on: January 04, 2011, 11:16:09 AM »
Works on my machine:
(setq
    doc_path "\"C:\\docs\\docname.doc\""
    app_path "\"C:\\Program Files (x86)\\Microsoft Office\\Office14\\winword.exe\""
(startapp app_path doc_path)
Check the validity of the paths you're supplying.
« Reply #6 on: January 04, 2011, 11:43:09 AM »
ndir = "\"F:\\directory name with spaces\\docname.doc\""
Missed one  :wink:
« Reply #7 on: January 04, 2011, 11:47:27 AM »
where's my coffee medic?
andrew_nao
« Reply #8 on: January 04, 2011, 12:07:06 PM »
(setq
they paths are good
im thinking because i have spaces in the path with periods and commas?
try your code again but with a directory that has spaces and a peroid and a comma
like "docs\\some name, inc.\\doc file.doc"
« Reply #9 on: January 04, 2011, 12:12:35 PM »
(setq
    doc_path "\"C:\\docs\\stupid path with spaces\\stupid filename with spaces.doc\""
Edit:
punctuation, like commas, in paths / filenames is just asking for trouble IMO
« Reply #10 on: January 04, 2011, 12:16:59 PM »
(setq
    doc_path "\"C:\\docs\\stupid path with spaces, and commas\\stupid filename with spaces, and commas.doc\""
« Reply #11 on: January 04, 2011, 12:23:53 PM »
See if it works with this ... if all else fails post the filepath you're using.
(defun openfile (file / sh)
  (setq sh (vlax-get-or-create-object "Shell.Application"))
  (vlax-invoke-method sh 'open (findfile file))
  (vlax-release-object sh)
(openfile "whateveryourfullfilepathishere")
andrew_nao
« Reply #12 on: January 04, 2011, 01:07:20 PM »
here is the code im using
the code returns the correct info but i just cant get it to open
(SETQ lst (VL-DIRECTORY-FILES "O:/" nil -1))
(defun wcmatch_first ( lst pattern flag / result )
    (setq pattern (if flag (strcase pattern) pattern))
    (vl-some
       '(lambda (str) (if (wcmatch str pattern) (setq result str)))
        (if flag (mapcar 'strcase lst) lst)
    result
(setq dir (strcat "O:/" result))
(SETQ NLST (VL-DIRECTORY-FILES DIR "*.DOC"))
(defun wcmatch_second ( nlst npattern nflag / nresult )
    (setq npattern (if nflag (strcase npattern) npattern))
    (vl-some
       '(lambda (nstr) (if (wcmatch nstr npattern) (setq nresult nstr)))
        (if nflag (mapcar 'strcase nlst) nlst)
    nresult
(setq ndir nresult)
(SETQ var (strcase (GETSTRING "Enter order number: ")))
(if (wcmatch_first lst (strcat "*" var "*") nil)
         ;(alert "yes") ;if found
   (if (wcmatch_second nlst (strcat "*" "MASTER" "*") nil)
  (setq path (findfile (strcat dir "/" ndir)))
              (startapp "\"C:\\Program Files (x86)\\Microsoft Office\\Office\\winword.exe\"" path)
              (alert "no") ; not found
andrew_nao
« Reply #13 on: January 04, 2011, 01:09:33 PM »
Ron
this worked perfectly! with the code i posted
thanks
« Reply #14 on: January 04, 2011, 01:13:12 PM »
Ron
thanks
